seanery |
waiting to rebuild whitey! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 15,854 Joined: 7-January 03 From: Indy Member No.: 100 Region Association: None ![]() |
What cams would/do YOU use?
Doing some research for a new cam. Low mileage motor (20K in 10 years) Thanks for the info. |
Brad Roberts |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 19,148 Joined: 23-December 02 Member No.: 8 Region Association: None ![]() |
Cam 914 = Single. 911 = Plural.
B |
Brad Roberts |
Brad Roberts |
Here you go:
.435 290 252 86a Strong mid range and top end for high performance mech. street engines. Valve springs recommended. N/A N/A 00-232 $155.00 |
Brad Roberts |
Oops..
I vote for the 494 the 86A is good.. but we need torque. B |
Aaron Cox |
Professional Lawn Dart ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 24,541 Joined: 1-February 03 From: OC Member No.: 219 Region Association: Southern California ![]() |
what are your drivin habits / techniques?
i have a cam (mixed w/ weber 44's that have slightly too big of idle jets) that the power band is from 1700 - 6000 rpm. has solid lifters etc, sometimes a pain to get off the line... |
seanery |
the plural in the listing refers to the people posting and their "cams".
What kind of other "surprises" might we expect inside the case when doing the cam? |
Brad Roberts |
Rust..... just kidding.
Cam/lifters/F+R main seals/cam bearings/oil/filter. It sounds *tight* I think the bottom end is fine. B |
seanery |
lifters and valve springs from webcam looked like 260 more.
So, about 500 in parts? |
seanery |
Brad Roberts |
Eagle is good.
I have used: WEB Engle Eagle Crane WebCam is the only one I have had problems with... but I have also used them the most. Yes. About 500$ in parts. Typically.. you can reuse the pushrod tube seals and some of the other small ones. 2.0 tin: 150$ The passenger side 2.0 tin is 100$ the drivers side is 50$. A ton of the 2.0 cars had the passenger side tin cut for AirCon. So.. I/everybody who sells parts... gets more for the right side tin piece. I can repair a 2.0 tin piece cut for AC.. but the time it takes me to do it..... could have bought a good 2.0 piece. B |
cgnj |
Senior Member ![]() ![]() ![]() Group: Members Posts: 627 Joined: 6-March 03 From: Medford, NJ Member No.: 403 Region Association: None ![]() ![]() |
Hey,
Try this link. ImportPerformance.Net Your in the middle so shipping would be a wash. Cam, lifters and gear you could save 30-40 bucks. CGNJ 76 2270 (I could have had a flat 6) |
Brad Roberts |
Actually... he is in the middle.. the car is on the left. ha ha.
B |
cgnj |
Come to think of it, I think they had them dropshipped from Web. Still save 30-40 bucks
CGNJ |
seanery |
cgnj.
is the link good? wouldn't go for me. |
cgnj |
Opps,
Import Performance Good customer service, Interesting accent, if it doesn't work, go to http://www.importperformanceparts.net Carlos |
seanery |
00-232 $155.00 .465 288 244 494 Designed for increased torque with added RPM power. Less top end than the 86a. 00-682 $155.00 My question on the 494 is how much top end do you give up? And how much extra torque will it produce? What kind of RPM's can we expect from my motor? |
Brad Roberts |
Dont expect anything usable over 6k RPM with any of these cams.
I know this is your street car.. so..I'm up for the torque in the mid range and sacrifice the top end (just like a stock cam)... but more torque. I can save you the few dollars... I think I get everything out the door for 220.00 (with tax and shipping) The springs will be a different story. B |
seanery |
This is probably one of those things that whichever way we go I'll be happy,so I'll let you decide.
This car probably won't see more than 4 or 5 de's max, so streetability is the higher concern. Should I get the heads fixed? (I know the answer) |
Brad Roberts |
What is wrong with the heads ?? OH.. YES. The spark plug holes.. I'll try to keep the pain to a minimum.
I picked up the control arm ear today (230$) << OUCH. We will drop the engine/trans on Sunday after I return from LA on Saturday. B |
Lo-Fi Version | Time is now: 4th July 2024 - 12:51 PM |
