Engine Rebuild, Installing Accessories |
d7n7master |
Nov 28 2004, 07:56 PM
Gary# Group: Members Posts: 663 Joined: 13-March 03 From: The O.C, Ca. Member No.: 421 |
H All,
Ready to install the accessories on my rebuilt longblock. And I'm wondering, is there a torque spec that I should follow - determined by fastener size??? Like M6=X inch pounds / foot pounds, M8=, etc? Or are there exceptions to the rule...??? (IMG:style_emoticons/default/w00t.gif) (IMG:style_emoticons/default/blink.gif) Like say, ohhh - the oil cooler fastener torque??? I just bought a new torque wench - I mean wrench & I wanna use it (IMG:style_emoticons/default/smile.gif) (IMG:style_emoticons/default/mueba.gif) And, of course - then there's to loctite or not to loctite??? That's another question. What to loctite... I've got a new bottle of "red" & I'm not afraid to use it!!! (IMG:style_emoticons/default/idea.gif) Any other exceptions / tips / stuff I should be aware of??? BTW - I hate oil leaks! Thanks, Gary |
d7n7master |
Nov 29 2004, 11:21 AM
Thanks, Gary |
skline |
Nov 29 2004, 11:30 AM
I have found that if you dont put oil in it, it doesnt leak at all. (IMG:style_emoticons/default/biggrin.gif)
On another note, When you refer to accessories, you mean like fan shroud and stuff? I usually just put it together and tighten it up till I think the bolt is about to break off and then leave it. I check everything after about 100, then 500 miles to make sure everything is still tight. I never had a problem. |
d7n7master |
Nov 29 2004, 12:31 PM
Now there's a thought... (IMG:style_emoticons/default/cool.gif) (IMG:style_emoticons/default/beerchug.gif)
But seriously folks - I'm taking my time, using my torque wrench, checkin' it twice. I'm mostly concerned with the oil cooler fastener torque. I haven't found a specific torque call-out in the book. I don't want to over-torque & possibly crack the cooler. Help me!!! (IMG:style_emoticons/default/pray.gif) (IMG:style_emoticons/default/pray.gif) (IMG:style_emoticons/default/lol2.gif) |
Deano |
Nov 29 2004, 01:43 PM
Member Group: Members Posts: 83 Joined: 13-October 04 From: Des Moines, Iowa Member No.: 2,942 |
I looked in my books and found nothing. Since you are tightening into the aluminum case, I would tighten them about the same as other bolts going into aluminum. 14-21 ft/lbs.
Lo-Fi Version | Time is now: 2nd January 2025 - 04:03 PM |
