CV Joint Re-Hab, Done!!!! Down off the Jack Stands- Time to Drive |
wndsnd |
Aug 28 2013, 06:12 AM
You wanted a horse, but got a goat. Nobody wants a goat.... Group: Members Posts: 2,861 Joined: 12-February 12 From: North Shore, MA Member No.: 14,124 Region Association: North East States |
Looks really good.
One of the last jobs I need to do. Thank you for the thread. John |
ChrisFoley |
Aug 28 2013, 06:28 AM
I am Tangerine Racing Group: Members Posts: 7,969 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
1. The Type I's have a recess here shown where the boot mates up against the CV. The fit up isn't great. Should I RTV this side so the boot won't possibly sling grease? 2. Going without the paper gaskets as I have heard stories from others that they will loosen the bolts over time. Any suggestions on the RTV to use? 1) Our modified Type 1 CVs include an o-ring seal for that location. 2) Our modified Type 1 CVs have the exact same step cut as the oem CVs and we include new paper gaskets.They will not loosen up if installed and torqued correctly. No need for RTV if done the way we recommend. (IMG:style_emoticons/default/confused24.gif) |
Aug 28 2013, 06:46 AM
Custom Member Group: Members Posts: 24,680 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
1. The Type I's have a recess here shown where the boot mates up against the CV. The fit up isn't great. Should I RTV this side so the boot won't possibly sling grease? 2. Going without the paper gaskets as I have heard stories from others that they will loosen the bolts over time. Any suggestions on the RTV to use? 1) Our modified Type 1 CVs include an o-ring seal for that location. 2) Our modified Type 1 CVs have the exact same step cut as the oem CVs and we include new paper gaskets.They will not loosen up if installed and torqued correctly. No need for RTV if done the way we recommend. (IMG:style_emoticons/default/confused24.gif) (IMG:style_emoticons/default/agree.gif) Put it back on jack stands...you can't take them off jack stands too fast, its bad for the car. rich |
914_teener |
Aug 28 2013, 09:18 AM
914 Guru Group: Members Posts: 5,250 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
Got it....might relapse! Had I known Dr. Foley had the magic pills instead of the 2 month program.....I would have gone that way. Now I know. Looks like you almost have to go with the type I's now. |
Lo-Fi Version | Time is now: 4th January 2025 - 06:24 PM |
