SIX engine tin- question |
Trekkor |
Dec 2 2004, 09:48 PM
About ready to do this.
Is it easier to get the motor in and then install the tin or put it on first? Do the tabs that attatch to the sides of the motor bend above the tin or under? Thanks KT |
sixnotfour |
Dec 2 2004, 10:10 PM
914 Wizard Group: Members Posts: 10,695 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
Tin on first , when take the motor back out the side pieces are tight on the inner pivot bolt. carefull , going in is pretty easy.
What sheetmetal do you have? factory, repo, root,other ? Red your your post again , Tabs bend down Jeff |
Lo-Fi Version | Time is now: 2nd January 2025 - 05:55 PM |
