My 2.4 Six Engine, Manufacturing prototype intake adapters. |
JmuRiz |
Jul 19 2013, 09:15 PM
914 Guru Group: Members Posts: 5,488 Joined: 30-December 02 From: NoVA Member No.: 50 Region Association: MidAtlantic Region |
Carbs for up to 3.0 are typically 40, but this size will work well with EFI, as the computer can better control the fuel delivery. Seems like a good size, from the little bit I've heard.
McMark |
Jul 26 2013, 08:08 PM
Okay, time for another thought/question. The engine is a bit unknown on the inside. Here's the story that came with it.
QUOTE 70T p &c's E cams 1969 Factory "S" heads a. Port size 36X35 38mm intake b. Valve size 45X39 1972 engine case Engine right side below shroud: *6123464 Question is, should I pull the heads off and check what all I've got? Maybe a valve cleanup job? |
Mike Bellis |
Jul 26 2013, 09:40 PM
Resident Electrician Group: Members Posts: 8,346 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None |
Open it! You know you want to. DO IT!!!
Mark Henry |
Jul 26 2013, 09:51 PM
Okay, time for another thought/question. The engine is a bit unknown on the inside. Here's the story that came with it. QUOTE 70T p &c's E cams 1969 Factory "S" heads a. Port size 36X35 38mm intake b. Valve size 45X39 1972 engine case Engine right side below shroud: *6123464 Question is, should I pull the heads off and check what all I've got? Maybe a valve cleanup job? Slippery slope. (IMG:style_emoticons/default/unsure.gif) |
rick 918-S |
Jul 26 2013, 10:02 PM
Hey nice rack! -Celette Group: Members Posts: 20,680 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
Do a leak down first and make sure you "need to"
McMark |
Jul 27 2013, 02:58 AM
It's more about knowing what heads, cams, pistons and compression ratios.
I have been dying to build another six engine. This isn't exactly a build and I don't have the funds to actually change anything so it can't get too crazy, other than possibly adding spacers to lower compression so I can run dual turbos. (yeah, I have the disease) |
Gary |
Jul 27 2013, 04:00 AM
Senior Member Group: Members Posts: 744 Joined: 12-January 03 From: Mount Airy, MD Member No.: 134 Region Association: MidAtlantic Region |
Hey Mark - is this the motor I dropped off? If so, I have details on the build.
Eric_Shea |
Jul 27 2013, 10:14 AM
PMB Performance Group: Admin Posts: 19,289 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
What does this mean?
a. Port size 36X35 38mm intake 36 intake 35 exhaust 38? Only two ports per head. |
sixnotfour |
Jul 27 2013, 10:33 AM
914 Wizard Group: Members Posts: 10,525 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
that configuration only has about 8-1 compression.
sell the 69 S heads and buy find some 2.2-2.4 heads. T and E heads have the same port size. You will get easy to find valves, 40/46 and get back the .5 compression they are easy to port to 36mm intake, Well depending on how you do it.. Or just run it, since you want to TURBO |
Dr Evil |
Jul 27 2013, 11:22 AM
Send me your transmission! Group: Members Posts: 23,032 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region |
Trekkor |
Jul 27 2013, 10:16 PM
Bolt on a set of carbs and run it on the test stand.
KT |
McMark |
Aug 5 2013, 11:30 PM
The $2500 carbs I don't have? (IMG:style_emoticons/default/blink.gif) Life is so simple when you're spending someone else's money. (IMG:style_emoticons/default/laugh.gif) Plus, what do I learn from bolting on carbs. I'm not building a car. I'm building an education.
I've been wanting to start familiarizing myself with AutoCAD and this seemed like a good project for this since the intake adapters I'll need are relatively simple. I started with an intake gasket and scanned it. Then cheated and drew the outline in Illustrator since I can bang that out in about 2 minutes. Then imported that into AutoCAD and did the extrusion. It's pretty boring at this point. Gotta measure my actual intake port size, the OD of the throttle bodies, and decide on the height of the adapters I need/want. Then I'll start working on the actual tapered tube portion. Attached image(s) |
McMark |
Aug 9 2013, 01:15 AM
Finished the intake drawing (I think). Now I need to find someone who can print a prototype for me.
jimkelly |
Aug 9 2013, 06:48 AM
Delaware USA Group: Members Posts: 4,969 Joined: 5-August 04 From: Delaware, USA Member No.: 2,460 Region Association: MidAtlantic Region |
will those Polaris fuel injectors provide enough fuel?
McMark |
Aug 9 2013, 10:39 AM
The injectors are pretty standard. So I was already planning on swapping them, I just haven't done any research into finding what I want to use. Something high impedance is certain, but I also need to find out what flow rate I need.
polo classic |
Aug 9 2013, 12:33 PM
Newbie Group: Members Posts: 32 Joined: 7-October 11 From: Oslo Member No.: 13,650 Region Association: Scandinavia |
Do you know what distance is from the throttle body to the valve on the OEM Porsche high butterflies throttle bodies?
From looking at the Rothsport versions, it looks like the manifolds are around twice the height of the throttle bodies (IMG:http://www.914world.com/bbs2/uploads_offsite/rothsport-racing.com-13650-1376073558.1.jpg) |
McMark |
Aug 9 2013, 01:59 PM
Not sure. I drew up 'shorties' because once I looked at the room in the 914 engine bay, there's only about 11" overall of space from the cylinder head mounting to the top of the engine bay. The TBs are about 4.5" and short, individual K&N filters are about 2", which leaves 4.5" of room for the adapters. And that's if I use all the available space. So I decided to just design the shorts ones and get a prototype made so I can hold it in my hand and see how it looks.
Trekkor |
Aug 9 2013, 03:25 PM
The $2500 carbs I don't have? (IMG:style_emoticons/default/blink.gif) Life is so simple when you're spending someone else's money. (IMG:style_emoticons/default/laugh.gif) Plus, what do I learn from bolting on carbs. I was under the impression that this was an unknown condition motor that you were trying to determine whether or not it needed rebuilding. I have a set of carbs/manifolds you could borrow for testing off my 2.6 race motor. I still have that 6 into 1 tee pee off road exhaust for full effect... KT |
McMark |
Aug 9 2013, 04:29 PM
Ahhh, thats makes more sense. (IMG:style_emoticons/default/wink.gif) I expect it runs. I'm just planning on pulling it apart to know for sure what's inside and what the compression is, etc
McMark |
Aug 9 2013, 07:28 PM
Prototype printing underway (not by me). (IMG:style_emoticons/default/boldblue.gif)
Attached thumbnail(s) |
Lo-Fi Version | Time is now: 27th September 2024 - 06:51 AM |
