McMark |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 20,179 Joined: 13-March 03 From: Grand Rapids, MI Member No.: 419 Region Association: None ![]() |
All done an ready to ship to me. (IMG:style_emoticons/default/boldblue.gif)
Attached thumbnail(s) ![]() ![]() |
euro911 |
Retired & living the dream. God help me if I wake up! ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,851 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California ![]() ![]() |
Cool.
What is the material, Mark? |
jimkelly |
Delaware USA ![]() ![]() ![]() ![]() Group: Members Posts: 4,969 Joined: 5-August 04 From: Delaware, USA Member No.: 2,460 Region Association: MidAtlantic Region ![]() |
why the groove seen from top? is it a two piece part glued together?
so the printer does not cut material away from a block of material - instead - it builds material up and up and up till a part is done ? |
jpnovak |
They call me "Nanoman" ![]() ![]() Group: Members Posts: 231 Joined: 26-August 09 From: Austin TX Member No.: 10,736 Region Association: Southwest Region ![]() |
I hope Mark doesn't mind my response. I am printing the prototypes for him.
I am many have seen/heard about 3D printing. It is a pretty cool process. The process starts with a 3D CAD file. There are many ways to get one of these but the process involves modeling in a CAD program. The CAD file is then transformed to a "surface" file that is a map of the external surfaces of the part. The printer software then slices this into invidividual layers. These are cross-sections cut to the plane of the base substrate. Its kinda like a stack of Pringles Chips. Once the software knows what each layer looks at it starts the printing process. The printer is a hot filament extruder. There is a feed stock roll of plastic wire filament. There is a pinch roller and toothed gear that forces the plastic through the hot extruder tip (230 deg C). The tip is then numerically controlled via a standard coordinate system. Its like putting a tube of toothpaste on a XYZ positioning system. The part prints the inner and outer perimeter first and then fills in the void space with a criss-cross pattern. The density of the fill is adjustable. The grove in the top is a software glitch where two perimeter lines close together do not get adequate fill due to the narrow space between them. If you look at the part you can see the individual layers that are stacked. This is the concentric surface finish. There are ways to smooth this easily. The pictures just show the raw part off the printer to check for dimensional fit. I printed these parts in ABS plastic. This does not print as smooth as the other common filament , PLA. The prototyping process is VERY fast with one of these printers even if the print process is slow. This part took about 3 hours of print time. Material cost is just a few $. The process creates an accurate part for mock up and test fit. It is easy to modify parts without spending a lot of machine time and cost at an outside vendor. Compared to prototyping in a machine shop there is no cost comparison. Cheaper. Faster. Simpler. PM me if anyone has an interest in having parts made. I have very reasonable rates. I hope Mark likes the part. I plan to ship it out today. |
Krieger |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,733 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None ![]() ![]() |
Very cool to see the
McMark |
Thanks for chiming in Jamie. I didn't know if you wanted to be identified.
Apparently this ABS plastic is suitable for actually running on the car, but once I have a design that works, I'll be researching aluminum CNC production. |
polo classic |
Newbie ![]() Group: Members Posts: 32 Joined: 7-October 11 From: Oslo Member No.: 13,650 Region Association: Scandinavia ![]() |
Did you ever consider using Boxster/997/996 parts, seeing the port spacing is similar, although the water stuff have oval ports
http://forums.pelicanparts.com/porsche-911...rt-spacing.html http://www.ebay.com/itm/OBX-ITB-INDIVIDUAL...3d8&vxp=mtr (I know some, if not all OBX parts suck) |
McMark |
Cool! Hadn't seen that. I'd like to try that sometime. (IMG:style_emoticons/default/idea.gif)
tscrihfield |
Drive Fast and Take Chances ![]() ![]() ![]() Group: Members Posts: 643 Joined: 8-September 10 From: Amelia Ohio Member No.: 12,156 Region Association: None ![]() ![]() |
This looks very cool! What are you going to have them cast/molded out of?
What is your plan for engine management? (IMG:style_emoticons/default/poke.gif) Thomas |
McMark |
If the prototype adapters work ill send the CAD files out to mill from billet aluminum.
I'll be using a MegaSquirt system I picked up. Still have to modify it for COP. |
jcd914 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,081 Joined: 7-February 08 From: Sacramento, CA Member No.: 8,684 Region Association: Northern California ![]() |
If the prototype adapters work ill send the CAD files out to mill from billet aluminum. I'll be using a MegaSquirt system I picked up. Still have to modify it for COP. When you get to the "ill send the CAD files out to mill from billet aluminum" part of this project my brother works for a machining company, programming, running and supervising their mills. They have at least 2 monster 5 axis mills. I don't know if he can save you money but it is worth asking. Jim |
edwin |
Member ![]() ![]() Group: Members Posts: 321 Joined: 20-May 09 From: Australia Member No.: 10,384 Region Association: Australia and New Zealand ![]() |
This part has "home cast aluminium" written all over it
You know you want to try it Mark |
rhodyguy |
Chimp Sanctuary NW. Check it out. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 22,115 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch ![]() |
home cast? as in a garage?
McMark |
Actually I do. Casting has been on my todo list for a long time now. (IMG:style_emoticons/default/boldblue.gif)
jbyron |
Jamie ![]() ![]() Group: Members Posts: 128 Joined: 17-July 07 From: Ballwin, MO Member No.: 7,916 Region Association: Upper MidWest ![]() |
Looking at the pic, I'm concerned whether or not there's clearance to thread a nut onto the stud.
GeorgeRud |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,725 Joined: 27-July 05 From: Chicagoland Member No.: 4,482 Region Association: Upper MidWest ![]() |
Yeah, it does look like you might have to lift it, start the nuts, then tighten it down. Then again, they do make shorter studs!!
McMark |
George is thinking along the same lines as me. (IMG:style_emoticons/default/wink.gif)
The walls on the adapter are pretty thick too, I could probably add some clearance. |
McMark |
Quick update...
Intake manifolds are at the machine shop getting carved from aluminum. (IMG:style_emoticons/default/happy11.gif) |
tscrihfield |
Quick update... Intake manifolds are at the machine shop getting carved from aluminum. (IMG:style_emoticons/default/happy11.gif) Awesome! Can't wait to see them! |
veekry9 |
OldMember ![]() ![]() ![]() ![]() Group: Retired Members Posts: 3,068 Joined: 17-June 13 From: TO Member No.: 16,025 Region Association: Canada ![]() |
This is Great.
Thanks for showing the World the latest in NewFangled Tech. An Idea to Part in hours and not days,the response time of CadCam system Integration in Manufacturing Systems. You too can have your very own Protype shop in your garage. Just like the Mechanix Illustrated BluePrints of the 60's. Time to fire up your [4valve head prototype investment casting pattern] [transaxle housing] ....anything you can dream up. the Future is Here Now. Try the Rhino4 or 5 Cad. Synergy by Weber is a cost effective Cam. EMC2 is an OpenSource Machine Control System. There is a lot of competition in the machining industry for large systems.50K is likely beyond the pricepoint for the home user. You have to look around and test,then make the decision that suits you best for the most you wish to spend.There is a fellow here doing a custom oil scavenge pan for his V8 conversion,inhouse or subcontracted? It is possible to do it inexpensively,however,the labour intensity rises accordingly. A good example of the technology available today. https://www.youtube.com/watch?v=r7V57_7H9zw A 20yr old Hardinge retrofit. https://www.youtube.com/watch?v=35tHYaDUmZQ A Large 5axis from the 60's retrofit If they can do it,so can we. |
Lo-Fi Version | Time is now: 25th June 2024 - 08:49 PM |
