3 Pages V < 1 2 3
> No power to wipers 1973-SOLVED
0396
post Apr 13 2015, 09:27 PM
Post #41
Off topic, what ever become of your " master cylinder" tread?
This is where you wanted to retread one of the ports on the M/C.
Did you have success or?
theleschyouknow
post Apr 14 2015, 08:04 AM
Post #42
QUOTE(Dave_Darling @ Apr 13 2015, 09:18 PM) *
The horn relay is on top of the fuse panel. The positions sometimes changed over the course of production (the socket just plugs into a hole in the panel) so it's best to check the wire colors going to the socket against the wiring diagram.
Look for red, red/white, black/yellow, and brown/white wires.
--DD
thanks dave will look
cjl
Tom
post Apr 14 2015, 12:21 PM
Post #43
HalfMoon,
That relay is J 13 and is called the fresh air blower relay, but is really just a power relay. Mine was intermittent and drove me crazy until I cleaned both the sockets and the relay prongs. If it acts up again, if you already cleaned the sockets and prongs, try slightly spreading the prongs a bit. Makes for a tighter electrical connection.
Tom
theleschyouknow
post Apr 14 2015, 05:06 PM
Post #44
QUOTE(theleschyouknow @ Apr 14 2015, 09:04 AM) *
--DD
cjl
ok I am not a very smart man - am I looking in the cabin at the fuses just forward of my left knee and shin when I am driving (I don't see any relays there -do I have to remove something to see it) or am I looking at the relay board under the plastic cover on the drivers side in the engine compartment?
and once I locate it, I can swap out one from the headlight motors to test?
Haynes shows a relay plate (what I think is in the engine compartment) and the fuse box relays (which is what I think I am looking for but have no idea where it is)
tia
cjl
theleschyouknow
post Apr 14 2015, 06:32 PM
Post #45
QUOTE(theleschyouknow @ Apr 14 2015, 06:06 PM) *
--DD
cjl
tia
cjl
wait a minute I think I see them like somebody said earlier in this thread or another ABOVE the fuse panel
I see two outboard larger screw heads 1 looks to be original cheese head & 1 phillips with a domed head (obviously a replacement) and two smaller inboard screws both phillips I assume since the outboard screws are mismatched those are the ones i need to remove?
cjl
Dave_Darling
post Apr 14 2015, 09:47 PM
Post #46
914 Idiot
Yes, those. The whole thing will hang down by the wiring harness when you do that; the relays are on the top side of it.
--DD
3 Pages V < 1 2 3
- Lo-Fi Version Time is now: 27th December 2024 - 04:04 AM
