3 Pages V < 1 2 3 >
> Upgrading the tachometer, to remove that bounce
McMark
post Oct 15 2013, 09:48 PM
Post #21
914 Freak!
Yeah, I installed mine with the factory connector panel as well. (IMG:style_emoticons/default/wink.gif)
VaccaRabite
post Oct 16 2013, 06:01 AM
Post #22
En Garde!
I'll be ordering one of these tachs today. Awesome.
Zach
McMark
post Oct 25 2013, 10:26 PM
Post #23
914 Freak!
Not particularly interesting, but here's mine in action. I left the glass off and used the sunpro needle because I'm going to install a better gauge face. So this was just testing.
https://www.youtube.com/watch?v=2dV0nrNG57A
timothy_nd28
post Oct 26 2013, 09:21 AM
Post #24
Not bad at all (IMG:style_emoticons/default/beerchug.gif) Is this running off a 5volt pulse?
McMark
post Oct 26 2013, 09:32 AM
Post #25
914 Freak!
Not sure. I'll have to look at how I have the MicroSquirt set up. I just plugged it in and it worked and didn't think about it again. (IMG:style_emoticons/default/wink.gif)
CptTripps
post Nov 1 2013, 04:13 AM
Post #26
:: Punch and Pie ::
Hmmm. Now this has me thinking about gutting the rest of them and making custom faces too.
Great thread, and super helpful for those of us with other computers/engines installed.
timothy_nd28
post Nov 1 2013, 08:06 AM
Post #27
For the price, it's a great project to do. I'm making another one of these this weekend, I'll update this thread with resistor values for a V8
timothy_nd28
post Nov 13 2013, 08:51 PM
Post #28
I just finished a tach conversion for a V-8. R9 needs to be 243k ohms
McMark
post Nov 13 2013, 09:04 PM
Post #29
914 Freak!
Does this mean that the switch on the back is always removed/soldered as in the original instruction (first few posts) regardless of the number of cylinders? The R9 value sets the cylinder count?
timothy_nd28
post Nov 13 2013, 09:05 PM
Post #30
QUOTE(McMark @ Nov 13 2013, 07:04 PM) *
Yes
McMark
post Nov 13 2013, 09:11 PM
Post #31
914 Freak!
Can you edit you original thread at the R9 step and put the values for each setup?
4- 499
6-
8- 243
timothy_nd28
post Nov 13 2013, 09:27 PM
Post #32
Edited the values
Dr Evil
post Sep 20 2014, 10:57 AM
Post #33
Send me your transmission!
Reviving from the dead due to awesomeness! This is great.
Is there a way it could be made for 2cyl motors? I have many motorcycles that would benefit form the ability to customize the gauges.
timothy_nd28
post Sep 20 2014, 12:05 PM
Post #34
Thanks (IMG:style_emoticons/default/smile.gif) Yes, R9 can be configured from a 2 cylinder to a 32 cylinder. With that said, the variable of the equation would be the 914 tach face. In this thread, R9 was computed for the linearity of our 914 tach. New calculations would be needed for a different style tach face with the number of cylinders desired.
tomrev
post Jan 22 2016, 03:23 PM
Post #35
Hi Tim, Reading thru this post, did you decide to do this for folks that wish to send you their tach? (sent a pm but did not hear back). If so, I'd be interested in sending you my tach for the bounce mod, and conversion to six cylinder function. Thanks, Tom
914Bryan
post Jan 22 2016, 04:37 PM
Post #36
This is awesome! Glad to see you are offering this service!
rnellums
post Jan 22 2016, 05:14 PM
Post #37
Professional Enthusiast
Tim's service is great. I had him do high intensity LEDs in my gauges at the same time. He incorporates a cool circuit that controls the lighting as well! My gauges are set to gradually switch over from white to bright red as I approach the redline (I believe it's Tim's avatar). Makes driving at night a LOT of fun.
tomrev
post Jan 22 2016, 06:09 PM
Post #38
QUOTE(rnellums @ Jan 22 2016, 03:14 PM) *
Hope to hear back from him!
timothy_nd28
post Jan 23 2016, 11:29 AM
Post #39
As a HVAC tech, I've been busy with this recent snap of cold weather. Sorry for not replying to your PM. Tom, you mentioned that you are installing a Honda V6 which I'm not familiar with the ECU's tach signal, it may be canbus. It could work but I can't tell you that it will with 100% certainty. You can do a quick test by purchasing the tachometer from AutoZone and temporarily wiring it. Set the slider switch to 6cylinder and try it. If it works, box up your 914 tach along with the Autozone 30 dollar tachometer, and I would be happy to put it together for you. If it doesn't work, simply return the tachometer to the part store (IMG:style_emoticons/default/biggrin.gif)
tomrev
post Jan 23 2016, 01:47 PM
Post #40
QUOTE(timothy_nd28 @ Jan 23 2016, 09:29 AM) *
Thanks Tim, sounds like a good plan, hope it works, and I can send it along to you.
3 Pages V < 1 2 3 >
- Lo-Fi Version Time is now: 26th December 2024 - 05:19 PM
