Upgrading the tachometer, to remove that bounce |
ThePaintedMan |
Jan 23 2016, 04:15 PM
Might as well take the chance to give another bump to a great member and an awesome service. Send Tim your gauges for all your needs. Even if you don't do the LEDs, his refresh of the gauges is second to none. And of course, he's an awesome guy who's helped out a lot of folks here.
timothy_nd28 |
May 30 2016, 02:22 PM
I have some bad news as it seems that AutoZone has recently jumped ship with their gauge supplier. They're now stocking a tachometer that looks very much like the Sunpro Super Tach II but internally it's nowhere near the same. AutoZone's replacement tachometer called the EQUUS (picture below) is completely digital as it has a micro-controller. Changing a resistor value will have no desirable effect with this tachometer. The SunPro tach is still available thru eBay and Amazon, but it's just a matter of time before this supply dries up too. So a heads up for those contemplating with the current tach upgrade, I would do it soon.
I will mess around with this EQUUS tach, it's still only 30 dollars. I will make available a new DIY for this tach conversion as soon as everything is figured out. With this said, I'm not a computer programmer. The new tach uses a micro controller called "ATTiny 24a". I would need to find out a way to extract the current code (chip is surface mount), then modify the code to work with our 914 gauge face and with 914s with different engines, and finally write the modified code back to the chip. Any programmers willing to help, please chime in or PM me (IMG:style_emoticons/default/beerchug.gif) |
craig downs |
May 31 2016, 09:07 AM
Senior Member Group: Members Posts: 769 Joined: 25-November 05 From: mira loma ca. Member No.: 5,189 Region Association: Southern California |
I got mine thru Summit a few months back and it was being clearanced for $5.00. I looked at Autozone and they didn't have it so I looked online and found it at Summit. I figured that they were being fazed out. I did the conversion and couldn't find a 490k resister and ended up using a 510k. Seems to work fine.
Optimusglen |
Mar 14 2018, 11:48 AM
Senior Member Group: Members Posts: 921 Joined: 26-February 16 From: Minneapolis Member No.: 19,709 Region Association: Upper MidWest |
Optimusglen |
Mar 14 2018, 12:00 PM
Optimusglen |
Mar 15 2018, 01:01 PM
Taking another approach. Thought I would share.
I was liking the idea of a different color gauge face a'la the Singer Porsches. (er, some of them) I thought that instead of messing around with the resistor, why not change the face to display the lines/numbers in the same orientation and spacing as the aftermarket tach, ya know, since I was changing the face anyway. I measured out the Bosch tachometer in the two previous posts and created a drawing with the lines at the same angles and spacings. The only difference is the face is sized to fit within the VDO tach, and I used VDO style text and lines. I placed my redline where I wanted, from what I could tell this is the proper redline for the engine I'm putting in, from a 1971 911T. Obviously this can be changed easily to match the engine/car. Black (IMG:http://www.914world.com/bbs2/uploads_offsite/c1.staticflickr.com-19709-1521140463.1.jpg) Blue (IMG:http://www.914world.com/bbs2/uploads_offsite/c1.staticflickr.com-19709-1521140463.2.jpg) The workflow here would follow the same steps for removing the selector switch on the rear and routing the wires. It would skip the resistor change. You would still follow the mounting bracket instructions. And you would add the new face. I have a really high quality printer at home, so I'll try printing my gauge face on high quality luster paper first. If that doesn't turn out I'll probably look into having the image printed on aluminum. If anyone else is interested, I can send you the SVG file I made. This is a vector file that you can open using Adobe Illustrator ($$$) or Inkscape (free) With this file you can change your redline, gauge color, line/number color, or even add other graphics. Just shoot me a PM with your email address. |
Mar 16 2018, 10:11 AM
914-6 GT in waiting Group: Members Posts: 19,649 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
I'm giving it a shot. Still have a lot to learn with even the very basic stuff but got a good start thanks to glen.
Attached thumbnail(s) |
timothy_nd28 |
Mar 16 2018, 02:03 PM
Wow, i thought the sunpro's were long gone. Thanks for doing the leg work with the Bosch tach. Keep posting pics, I love to see your twist on this conversion.
Bartlett 914 |
Mar 16 2018, 05:17 PM
Advanced Member Group: Members Posts: 2,218 Joined: 30-August 05 From: South Elgin IL Member No.: 4,707 Region Association: Upper MidWest |
This is a good approach. This would also work with the Equus Tach wouldn't it?
Taking another approach. Thought I would share. I was liking the idea of a different color gauge face a'la the Singer Porsches. (er, some of them) I thought that instead of messing around with the resistor, why not change the face to display the lines/numbers in the same orientation and spacing as the aftermarket tach, ya know, since I was changing the face anyway. I measured out the Bosch tachometer in the two previous posts and created a drawing with the lines at the same angles and spacings. The only difference is the face is sized to fit within the VDO tach, and I used VDO style text and lines. I placed my redline where I wanted, from what I could tell this is the proper redline for the engine I'm putting in, from a 1971 911T. Obviously this can be changed easily to match the engine/car. Black (IMG:http://www.914world.com/bbs2/uploads_offsite/c1.staticflickr.com-19709-1521140463.1.jpg) Blue (IMG:http://www.914world.com/bbs2/uploads_offsite/c1.staticflickr.com-19709-1521140463.2.jpg) The workflow here would follow the same steps for removing the selector switch on the rear and routing the wires. It would skip the resistor change. You would still follow the mounting bracket instructions. And you would add the new face. I have a really high quality printer at home, so I'll try printing my gauge face on high quality luster paper first. If that doesn't turn out I'll probably look into having the image printed on aluminum. If anyone else is interested, I can send you the SVG file I made. This is a vector file that you can open using Adobe Illustrator ($$$) or Inkscape (free) With this file you can change your redline, gauge color, line/number color, or even add other graphics. Just shoot me a PM with your email address. |
Bartlett 914 |
Apr 7 2018, 08:15 AM
I purchased the Bosch 7904 and it does look like the the right one. I did the full mod and it went real well....until I went to install the pointer. The 914 tach shaft is .5mm and this one is 1mm! A solution will be to drill out the 914 pointer but this will be tricky ans I may end up gluing it onto the shaft.
Were all the 914 tachometers the same. Has anyone run into this? I have a couple more tachometers I could tear into but I don't want to if they are all the same An thanks Tim for showing us this. I also did the LED lights (IMG:style_emoticons/default/smilie_pokal.gif) |
Montreal914 |
Mar 6 2022, 03:52 PM
Senior Member Group: Members Posts: 1,725 Joined: 8-August 10 From: Claremont, CA Member No.: 12,023 Region Association: Southern California |
Added small detail to this excellent thread (IMG:style_emoticons/default/smilie_pokal.gif)
This is a screenshot of Bosch webpage showing the 3 variations of that tachometer. FST 7906 (black face) happens to be in the mid $30 range on Amazon. I couldn't find the FST 7904 (white face) on Amazon, and it was in the $50 range on other websites. Order placed (IMG:style_emoticons/default/sunglasses.gif) |
Dominic |
Oct 29 2023, 09:54 AM
Dominic Group: Members Posts: 993 Joined: 14-January 03 From: Vacaville, CA Member No.: 149 Region Association: Northern California |
FlacaProductions |
Oct 29 2023, 10:00 AM
Senior Member Group: Members Posts: 1,845 Joined: 24-November 17 From: LA Member No.: 21,628 Region Association: Southern California |
It appears that Tim hasn't logged on here since 20th June 2022.
fiacra |
Oct 29 2023, 01:06 PM
Person.Woman.Man.Camera.TV Group: Members Posts: 478 Joined: 1-March 19 From: East Bay Region - California Member No.: 22,920 Region Association: Northern California |
Lo-Fi Version | Time is now: 26th December 2024 - 05:19 PM |
