1.7L F.I. on a 2.0??, Will it work? |
aylanco |
Dec 9 2004, 12:35 PM
Member Group: Members Posts: 106 Joined: 19-July 04 From: Ann Arbor, MI Member No.: 2,371 |
Will the Fuel Injection from the 1.7 that came with my car work on the 2.0 with carbs that was transplanted into my car?
The carbs work alright but not great and I would like to go with F.I. |
John |
Dec 9 2004, 01:10 PM
I think it might work, but....
The fuel delivery will be off as it would be calibrated for the 1.7 and not the 2.0. Because of this the car will probably run hotter (leaner). May not be a good thing for a Type IV. The heads are different and you will need to adapt the runners to the 2.0 heads somehow or obtain 2.0 runners. The pressure sensor was calibrated for the 1.7 and this may be your biggest problem (but I'm not sure about this one). After all the farting around that you will undoubtedly will end up doing, it would probably be easier to just obtain a 2.0 fuel injection system. I don't mean to discourage, I'm just giving my free advice. |
Joe Ricard |
Dec 9 2004, 02:09 PM
You need 2.0L injectors (more fuel flow) MPS can be recalibrated WITH THE RIGHT INSTRUMENTS Runners are different ID the 1.7L are smaller the throttle body is smaller The computor may work ????? So yes you can do it but it will be a major pain inthe ass and only have marginal results. |
Mueller |
Dec 9 2004, 02:13 PM
914 Freak! Group: Members Posts: 17,150 Joined: 4-January 03 From: Antioch, CA Member No.: 87 Region Association: None |
The motor I have right now (a 1.8) was running 1.7 injection with 1.7 injectors with a "tweaked" MPS......last week I installed 2.0 injectors with a stock unmolested MPS (1.7) and it seems to be running fine, I have yet to hook up my O2 sensor to get any air/fuel readings.
7391420 |
Dec 9 2004, 02:19 PM
Member Group: Members Posts: 353 Joined: 6-August 03 From: boston, ma Member No.: 988 |
What year 1.7 FI is it? the wiring harness may be different as well depending on the year.
Jeff Bonanno |
Dec 9 2004, 02:20 PM
il dottore Group: Members Posts: 421 Joined: 30-April 03 From: San Diego, CA Member No.: 636 |
aylanco |
Dec 9 2004, 04:24 PM
Think I'll just hold out for a good 2.0 FI (IMG:style_emoticons/default/smilie_pokal.gif)
Dec 9 2004, 06:00 PM
914 Idiot Group: Members Posts: 15,063 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
Do you know which cam is in your 2.0? If it's not the stock cam, it'll be tough to make any flavor of D-jetronic FI work well on the motor. If it's any more aggressive than the Web #73 grind, it'll be practically impossible...
--DD |
DJsRepS |
Dec 10 2004, 07:04 AM
Member Group: Members Posts: 431 Joined: 4-November 04 From: Sarasota Florida Member No.: 3,060 |
Assuming the cam is OEM for a 2.0 like Dave said you would need a set of 2.0 injectors and MPS sensor off known good runner or get the 1.7 MPS recalabrated to work. I like my OEM 1.7 Djet.
Lo-Fi Version | Time is now: 21st December 2024 - 08:15 AM |
