CptTripps' Restoration 2 - The Grey Matter Build, Back in Doug’s garage |
CptTripps |
Sep 12 2013, 04:06 PM
:: Punch and Pie :: Group: Members Posts: 3,584 Joined: 26-December 04 From: Mentor, OH Member No.: 3,342 Region Association: Upper MidWest |
A bunch of perforated metal showed up today.
Getting closer to build time! Attached thumbnail(s) |
Chris H. |
Sep 12 2013, 04:18 PM
Senior Member Group: Members Posts: 4,053 Joined: 2-January 03 From: Chicago 'burbs Member No.: 73 Region Association: Upper MidWest |
Dude those calipers look like candy. Wow.
CptTripps |
Sep 12 2013, 09:10 PM
Dude those calipers look like candy. Wow. They look MORE like candy in person. I've got some cleanup to do around the edges though. I've got to give props to Jason at Cleveland Powder Coating. I called today about the missing seal. He told me that he had it, but that someone threw it away by accident. Offered to discount my next order by $40 to cover the cost of a new seal. That's pretty awesome. |
CptTripps |
Sep 14 2013, 04:26 PM
Started working on the flares today. Marked everything out before I take it to a friend's to weld them up.
Took the rockers off and the car lost about 11lb. Holy crap. Oh...and I added a horn. Discovered I didn't have one and about bit it earlier! Attached image(s) |
CptTripps |
Sep 19 2013, 08:15 AM
Flares are on...time for some banging and bondo this weekend!
Chris H. |
Sep 19 2013, 10:16 AM
Wow that looks great. Did you do those yourself?
bulitt |
Sep 19 2013, 10:47 AM
Achtzylinder Group: Members Posts: 4,188 Joined: 2-October 11 Member No.: 13,632 Region Association: South East States |
Flares on 8 days after taking possession. You guys must be drinking water from the cuyahoga. (IMG:style_emoticons/default/lol-2.gif)
BIGKAT_83 |
Sep 19 2013, 10:59 AM
Senior Member Group: Members Posts: 1,798 Joined: 25-January 03 From: Way down south Bogart,GA Member No.: 194 Region Association: South East States |
Great job....At this rate you should be able to make it to Okteenerfest next month.
(IMG:style_emoticons/default/welder.gif) Bob |
CptTripps |
Sep 20 2013, 03:34 AM
If I hadn't JUST driven from ATL to Cleveland 2 weeks ago...I'd happily drive down for Okteenerfest. The car will certainly be on the road.
I was planning on doing the brakes this weekend, but I got screwed by someone that sold me a set of struts...that never arrived. (Nor has the refund.) I'll be concentrating on bodywork for a bit. Just wanting to get it to primer. I'll have all winter to make the bodywork perfect. |
CptTripps |
Sep 20 2013, 06:59 AM
Flares on 8 days after taking possession. You guys must be drinking water from the cuyahoga. (IMG:style_emoticons/default/lol-2.gif) That's how we roll here in the 216! I tend to get into a build quickly, and push through a lot of the stuff until I find the right answer. Helps me clear my head. I like progress...and don't like leaving something half-done for very long. Going over to the shop where we did the flares in a little bit so I can replace the U-Joint bushings in the shift linkage so I can drive it home. I replaced them last week with rubber grommits from a skateboard truck...just to get my by. |
strawman |
Sep 21 2013, 10:44 PM
Senior Member Group: Members Posts: 885 Joined: 25-January 08 From: Los Osos, CA Member No.: 8,624 Region Association: Central California |
As someone who has done the trailing arm reinforcements you have pictured above, I'd like to suggest you scrap that idea -- it makes 'em uber-heavy. Eric Shea's notion of welding in tubes laterally makes a lot more sense (I shamelessly copied his idea!). Not sure he's still providing that service, but it is much lighter; I ended up practically giving away the "clam-shelled" trailing arms.
Good luck with your project; you're making way better progress than I. I am almost five years into my turbo'd Suby project and keep getting sidetracked with other projects... |
Sep 21 2013, 11:03 PM
Custom Member Group: Members Posts: 24,688 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
If you can break a pinion gear clean off the shaft, you may want to think hard about going to a Subaru and look for a transmission that can handle that motor...
I like pinion gear breaking off.....cool power |
CptTripps |
Sep 22 2013, 06:31 AM
Interesting call on the trailing arms. Hadn't thought of it like that...but I guess it would make sense.
I'll be doing the Subie Trans as well. Already bought the EJ20 and MT5 out of a wrecked 07 WRX. Today's delima: Should I weld all these gaps, or use AllMetal to fill them? Attached thumbnail(s) |
jimkelly |
Sep 22 2013, 06:48 AM
Delaware USA Group: Members Posts: 4,969 Joined: 5-August 04 From: Delaware, USA Member No.: 2,460 Region Association: MidAtlantic Region |
I think the consensus will be to fully spot the entire perimeter.
is this the width gap most have to deal with when installing steel flares??? are you backing this gap with copper plate when you MIG it? nice work (IMG:style_emoticons/default/wub.gif) grey black is nice, not sure I am fully sold on it, not sure I am sold on satin finish in general, this grey red combo is somewhat appealing too? (IMG:http://www.914world.com/bbs2/uploads/post-224-1379205042.jpg) |
McMark |
Sep 22 2013, 07:12 AM
(IMG:style_emoticons/default/ohmy.gif) Weld it all.
CptTripps |
Sep 22 2013, 07:13 AM
Most of the gaps between welds are under 1/2", so it would just be another pass to get it solid. I need to hit it with primer pretty quick before it starts to rain. (I really need to get the garage cleaned out!)
I'm moving towards snow-white, or dark grey. I can wrap a satin vinyl later if I want. The look if this 918 is pretty cool. I could do a white/green GT3 type theme like you have pictured. Either way, I already have the calipers for it. (IMG:style_emoticons/default/biggrin.gif) Attached image(s) |
CptTripps |
Sep 22 2013, 04:25 PM
Worked on welding up the gaps today. My welder took a shit after about an hour, so I'll need to get it fixed before I can weld anything else.
Also discovered that I can't use the 1" wheel spacers, because the bolts hit the inside of the rim. Someone suggested 110mm builds from the hub, and I may just do that. Seems easier. Making progress though. Attached thumbnail(s) |
jimkelly |
Sep 22 2013, 04:34 PM
what wire are you using?
.025 easy grind? gloss silver/grey and black, can't go wrong with that. jim |
CptTripps |
Sep 22 2013, 07:20 PM
I was using .23-eg, but honestly, I found .30 easier to weld with. (It's all about the settings.)
I'm really not that pleased with the job I'm doing. I think it has something to do with the motor going kaput on me. It was skipping which really messed me up a few times. I'm going to go over the whole thing and grind it all down to smooth. I won't sleep well until I know it's right. The more I look at it, the more I like "Sport Classic Gray" as a paint choice...kinda like this. Attached thumbnail(s) |
Cairo94507 |
Sep 22 2013, 09:01 PM
Michael Group: Members Posts: 10,160 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California |
Terrific work and I love that sport classic grey.
Lo-Fi Version | Time is now: 10th January 2025 - 04:05 AM |
