Rear trunk hinge rollers, Need how to replace instructions. |
green914 |
Aug 20 2013, 11:35 AM
Senior Member Group: Members Posts: 1,467 Joined: 29-March 11 From: Sacramento, California Member No.: 12,874 Region Association: Northern California |
Just getting ready to replace the rollers on the rear trunk hinges (IMG:style_emoticons/default/smile.gif) . (IMG:style_emoticons/default/idea.gif) It looks like removing the trunk lid might make the job a bit easier. (IMG:style_emoticons/default/confused24.gif) Any thing that I should know about before I start?
Jeffs9146 |
Aug 20 2013, 12:24 PM
Do you have a long adjustable wrench ??
I cut a notch just big enough to pass the torsion bar thru and "hook it". The length of the wrench will give you the leverage you need and it wont hurt the "round" end of the wrench. You can still hang it on the wall. I cut mine with a cutoff wheel. |
green914 |
Aug 20 2013, 12:35 PM
Do you have a long adjustable wrench ?? I cut a notch just big enough to pass the torsion bar thru and "hook it". The length of the wrench will give you the leverage you need and it wont hurt the "round" end of the wrench. You can still hang it on the wall. I cut mine with a cutoff wheel. Good (IMG:style_emoticons/default/idea.gif) I tried a stout box end wrench that works, it's okay. A notch in the eye-let of the wrench sounds like it will make things a little less shaky; I just happen to have a couple of extra long adjustable end wrenches. (IMG:style_emoticons/default/smile.gif) Thanks, Jerry |
TheCabinetmaker |
Aug 20 2013, 01:34 PM
I drive my car everyday Group: Members Posts: 8,325 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
A 10mm deep socket on a 4" extension will slip over the end of the rod. Pull up slightly. Slip old one off and new one on.
02loftsmoor |
Aug 20 2013, 02:27 PM
Senior Member Group: Members Posts: 577 Joined: 26-June 11 From: Ft. Worth TX Member No.: 13,243 Region Association: Southwest Region |
Work smarter not harder..
A 10mm deep socket on a 4" extension will slip over the end of the rod. Pull up slightly. Slip old one off and new one on. (IMG:style_emoticons/default/agree.gif) |
Jonathan Livesay |
Aug 20 2013, 03:40 PM
Senior Member Group: Members Posts: 745 Joined: 13-March 10 From: La Canada CA Member No.: 11,461 Region Association: None |
Work smarter not harder.. A 10mm deep socket on a 4" extension will slip over the end of the rod. Pull up slightly. Slip old one off and new one on. (IMG:style_emoticons/default/agree.gif) I made my own tool for that. (IMG:http://www.914world.com/bbs2/uploads_offsite/i41.tinypic.com-11461-1377034836.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i39.tinypic.com-11461-1377034836.2.jpg) |
SLITS |
Aug 20 2013, 04:37 PM
For my money, I cut the torsion bars out and installed a gas shock kit.
Eliminates strain on hinge mounts so they won't rip off the inner rear wheelhouse. Once was more than enough. |
etcmss |
Aug 21 2013, 03:54 AM
etcmss Group: Members Posts: 183 Joined: 20-April 06 From: Lancaster, Ky Member No.: 5,899 Region Association: Upper MidWest |
link to previous thread on torsion bars---shows method and another link
http://www.914world.com/bbs2/index.php?showtopic=39320 |
rhodyguy |
Aug 21 2013, 06:27 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,193 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
socket and extension. raise the rear trunk lid and prop it open with a stick first to help ease the pressure on the spring.
nihil44 |
Aug 22 2013, 03:30 AM
Member Group: Members Posts: 157 Joined: 28-January 12 From: Brisbane, Australia Member No.: 14,058 Region Association: None |
I agree with The Cabinetmaker.
10mm deep socket placed over the end of the bar, drop the lid a little to get a little more purchase on the bar, press down, old roller off, new roller on. Safe and quick David |
green914 |
Aug 22 2013, 08:17 AM
For my money, I cut the torsion bars out and installed a gas shock kit. Eliminates strain on hinge mounts so they won't rip off the inner rear wheelhouse. Once was more than enough. Can you show me a picture of how you mounted the gas shocks? This sounds like a very good idea. (IMG:style_emoticons/default/smile.gif) Thanks for the input guys - I think the 10 mm deep socket method makes the job easy. Thanks |
monkeyboy |
Aug 22 2013, 08:21 AM
Senior Member Group: Members Posts: 808 Joined: 8-June 08 From: Los Angeles, Ca Member No.: 9,147 Region Association: None |
Camp914 makes a trunk shock kit for the front and rear. Nice setups.
green914 |
Aug 22 2013, 06:40 PM
Camp914 makes a trunk shock kit for the front and rear. Nice setups. I like the way they look, and the cost is not a problem. (IMG:style_emoticons/default/smile.gif) I would like to hear some reviews from the folks who are using them - or not. |
monkeyboy |
Aug 23 2013, 08:54 AM
I am using them front and rear.
They work well, and aren't hard to install. Only problem I had is in the front. They attach to the spring holders in the front. First time I closed my trunk they bent. I got a small aluminum tab and bolted it to the spring holder to thicken up and reinforce the mount. No flex since then. |
Rob-O |
Aug 23 2013, 10:46 AM
Senior Member Group: Members Posts: 1,256 Joined: 5-December 03 From: Mansfield, TX Member No.: 1,419 Region Association: Southwest Region |
Does the roof still fit in the trunk with the shocks of the Camp 914 kit in place?
rhodyguy |
Aug 23 2013, 12:03 PM
yes.
Aug 24 2013, 09:00 AM
Custom Member Group: Members Posts: 24,658 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
Yes, the shocks work great, just like every modern car out there.
They mount to the hinge bracket on one end and to the rain gutter (with an additional bracket) on the other end. They fold down out of the way. Then you can remove the torsion springs if you want. Rich |
green914 |
Aug 24 2013, 11:36 AM
(IMG:style_emoticons/default/sad.gif) After taking a close look at the hinge and the pressure that the torsion bar puts on it, and the welds that attach it (IMG:style_emoticons/default/barf.gif) I can see the weld is starting to break loose on the right side.
The struts look like a real good (IMG:style_emoticons/default/idea.gif) idea. |
Rob-O |
Aug 24 2013, 02:58 PM
I pulled the torsion springs from a 914 once...once. Dang near killed myself. Is there a safe method for removing them after installing a the Camp 914 kit?
Ian Stott |
Aug 24 2013, 03:09 PM
Senior Member Group: Members Posts: 907 Joined: 28-January 08 From: Moncton/Canada Member No.: 8,635 Region Association: Canada |
I removed my torsion bars and installed the Camp 914 kit, very happy with everything. Roof still fits as per normal, trunk stays up all the way instead of half way or hitting you in the head when there is a slight wind. I also found the gentleman from Camp 914 was a pleasure to deal with, bought his flasher/pilot light kit and it works perfect as well.
Ian Stott Moncton Canada |
Lo-Fi Version | Time is now: 26th December 2024 - 10:01 AM |
