Lawrence |
Senior Member ![]() ![]() ![]() Group: Benefactors Posts: 1,661 Joined: 5-February 03 Member No.: 244 Region Association: None ![]() ![]() |
I've only done one valve adjustment on my /6, and that was under the watchful eye of Wes Hildreth.
The valves are a bit noisy when cold. I've checked the archives and have an old copy of the PP tech article for the 911. Tricks or helpful tips, anyone? -Rusty |
Rusty |
Wanted: Engine case GA003709 ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 7,943 Joined: 24-December 02 From: North Alabama Member No.: 6 Region Association: Galt's Gulch ![]() ![]() ![]() |
bump.
ArtechnikA |
rich herzog ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,390 Joined: 4-April 03 From: Salted Roads, PA Member No.: 513 Region Association: None ![]() |
there doesn't seem to be any magick, other than making sure you've drained the oil and got a new set of silicone-bead gaskets. i don't have a lot of stick time on this procedure myself, personally, as in hands-on. some people swear you -have- to pull the heat exchangers "to do the job properly" -- and some are just as adamant you don't. i guess it's a personal issue on 'properly' - i donno. put some penetrating oil on the studs & nuts ahead of time just in case, have some spare studs, and a new set of exhaust port gaskets standing by is what i'd do...
i -do- know that having the appropriate feeler gauge - the hook-shaped one that has a place for fingers to grab and a teeny blade where the dot would be on a question mark ( ? ) is the preferred tool for the job. |
J P Stein |
Irrelevant old fart ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,797 Joined: 30-December 02 From: Vancouver, WA Member No.: 45 Region Association: None ![]() |
Most of my "tricks" concern finding TDC of each cylinder. One can mark the front pully with each cyl that comes to TDC at each 120deg mark. AIR, 1 and 4 are at the Z1 mark, but 360 deg apart. Twice around and you've covered them all.
To turn the motor, block one wheel so it won't turn, put it in gear, and turn the other wheel. One can go fwd and backwards to get it right on. I don't even take out the plugs....unless I'm gonna replace em". I always have a .005 feeler gauge as a "no go". I've got it down to a 4-5 hour job. |
mskala |
R ![]() ![]() ![]() Group: Members Posts: 1,925 Joined: 2-January 03 From: Massachusetts Member No.: 79 Region Association: None ![]() ![]() |
It was/is a pain in the butt before I started removing the heat
exchangers to do it. Remember to have 6 exhaust gaskets on hand. I don't think they should be reused. Why would you mark the pulley, which can't be seen, when the flywheel already has 120 degree marks on it? |
J P Stein |
Ever recourceful 6er conversion guys DO have access to the pully (visual & physical) but DON'T have marks on their flywheel.
If you're fortunate enuff to have a "real"(slow (IMG:style_emoticons/default/cool_shades.gif) ) 6, I would advise putting numbers by the 120 deg marks. The CW judges will ding ya tho (IMG:style_emoticons/default/laugh.gif) |
Rusty |
Thank you for the tips, everyone.
I have headers on the car, so I'll have a bit more room than the last time I had to work on the valves. It was so long ago, that I figured I'd ask for tips. JP, you mentioned marking the flywheel. 1 and 4 should be at Z1. I remember that. Will watching distributor position make any difference at all? I have the appropriate feeler gauge, with extra blades. IIRC, Wes Hildreth apparently buys blade material in long strips, and dispenses with even using the holder. I haven't found a source for those strips yet. -Rusty (IMG:style_emoticons/default/smoke.gif) P.S. I've got a storage area rented, and will move the /6 there tonight. Tomorrow I'll start screwing with the valves, after I lay down plastic and drain all the oil out. Any other ideas between now and then will be welcome! |
Rusty |
I thought about something... if this is a stupid question, slap me - but answer it first.
If I dont have 120 degree marks on my flywheel, how am I to know when I reach 120 degrees, when I'm turning a tire? -Rusty (IMG:style_emoticons/default/smoke.gif) |
J P Stein |
The marks are on the pully.....mirrors are gud. It does involve mooving around a bit. If you leave the plugs in, you can feel it come up on the compression stroke. I bit of practice and it's a pice of pie (IMG:style_emoticons/default/blink.gif)
Why can I still remember the Chebbie firing order(18436572) but not the 9eleben? We have the strip shims at work.....various thicknesses, but only the .004 jobbies ever follow me home....go figure. |
ArtechnikA |
QUOTE(Lawrence @ Sep 2 2003, 11:52 AM) If I dont have 120 degree marks on my flywheel, how am I to know when I reach 120 degrees, when I'm turning a tire? crankshaft pulley; bring a mirror, be prepared to jump and down a lot. or you can use the Larson / Thoruson method, which (oversimplified) says when one side's valve is open, the same valve on the other side is closed. since most of the cam (duration degrees-wise) is base circle, ultra precision in determining TDC is not really required... and be happy you don't have an AC pulley on your crankshaft pulley ... |
ArtechnikA |
QUOTE(J P Stein @ Sep 2 2003, 12:13 PM) why can I still remember the Chebbie firing order(18436572) but not the 9eleben? 1-6-2-4-3-5 |
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,000 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California ![]() ![]() |
The Larson/Thorusen method depends on the 914-4 motor having the cylinders on the opposite sides of the motor using the same cam lobes. You can probably get away with it on a DOHC motor like the 911 one, but I wouldn't want to be the first to do so...
BTW, I talked to some 914-6 owners (and 75+ 911 owners) locally, and they all agreed that there was only one trick to it: "Pay someone else to do it!" (No, I'm not really kidding....) --DD |
Rusty |
I wish I could pay someone to do it... but the valves are starting to sound a bit loud, and I don't trust anyone here in central Kansas.
Yep. 16-24-35. Lousy measurements, but all were great ages when I was 19. (IMG:style_emoticons/default/smile.gif) |
ArtechnikA |
QUOTE(Dave_Darling @ Sep 2 2003, 02:42 PM) The Larson/Thorusen method depends on the 914-4 motor having the cylinders on the opposite sides of the motor using the same cam lobes. Larson's said it works on 911 engines and i haven't worked through the firing order on paper to verify that it does (or doesn't) work -- but i tend to believe him. i -think- it depends only on the firing order intrinsic to a boxer engine. |
scotty |
The Fun Never Stops ![]() ![]() ![]() Group: Members Posts: 773 Joined: 20-May 03 From: Portland. Oregon (SW) Member No.: 718 Region Association: None ![]() |
QUOTE I wish I could pay someone to do it... Awwww, c'mon...it's fun and relaxing (except for that up/down part)! And when you get it right, *sweet* (IMG:style_emoticons/default/laugh.gif) |
Lo-Fi Version | Time is now: 30th June 2024 - 01:06 PM |
