9 Pages V « < 3 4 5 6 7 > »
> I hope to be returning, 914 Less for about 2 years
speed metal army
post Mar 18 2014, 09:15 PM
Post #81
Waiting for the rain to stop...
This is going to rule! Nice Job. (IMG:style_emoticons/default/beerchug.gif)
drive-ability
post Mar 20 2014, 09:49 PM
Post #82
Started wiring up the fans and P/S pump. Using 1 gauge battery cable and 10 gauge for the fans and last 9 gage for the P/S pump. The 250 amp fuse is a bit too big but I found a 100 amp to install later. Those relays are good for 80 amps or so.
(IMG:http://www.914world.com/bbs2/uploads_offsite/i60.photobucket.com-3782-1395373763.1.jpg)
Jeff Hail
post Mar 20 2014, 11:38 PM
Post #83
QUOTE(drive-ability @ Mar 20 2014, 08:49 PM) *
You never really left and your new project is Bitch'n !
drive-ability
post Mar 24 2014, 01:09 AM
Post #84
(IMG:http://www.914world.com/bbs2/uploads_offsite/i60.photobucket.com-3782-1395644981.1.jpg)
(IMG:http://www.914world.com/bbs2/uploads_offsite/i60.photobucket.com-3782-1395644982.2.jpg)
drive-ability
post Mar 25 2014, 11:45 PM
Post #85
I found an extra Mercedes fan resistor set laying around the garage. Its a quality unit and will use it as a low speed cooling fan option. I going to mount it on the other side of the fan shroud. It will likely need some cooling and I would hate to place my hand on it when its doing its thing.
(IMG:http://www.914world.com/bbs2/uploads_offsite/i60.photobucket.com-3782-1395812744.1.jpg)
drive-ability
post Mar 25 2014, 11:54 PM
Post #86
Question,
My fans and electric power steering pump are wired as seen in the previous pictures have a main fuse (for now 100 amp) should I fuse the fans and pump using individual fuses ? For example, keep the 100 amp main and use a fuse for the fans and one for the pump ?
(IMG:http://www.914world.com/bbs2/uploads_offsite/i60.photobucket.com-3782-1395813242.1.jpg)
speed metal army
post Mar 26 2014, 12:02 AM
Post #87
I would fuse them separately for sure. You want to know if your fans aren't running, the PS you will notice right away.
drive-ability
post Mar 27 2014, 12:30 AM
Post #88
yes that's a good point ! I still have a ton of work to do !!!!!
drive-ability
post Mar 28 2014, 06:11 PM
Post #89
Installed some fuses to the fans & power steering systems. Good advise considering my last V8 914 had a electrical fire. (IMG:style_emoticons/default/poke.gif)
(IMG:http://www.914world.com/bbs2/uploads_offsite/i60.photobucket.com-3782-1396051875.1.jpg)
(IMG:http://www.914world.com/bbs2/uploads_offsite/i60.photobucket.com-3782-1396051876.2.jpg)
(IMG:http://www.914world.com/bbs2/uploads_offsite/i60.photobucket.com-3782-1396051876.3.jpg)
I found some nice hose 1.25" & 1.50" for only 6 dollars a foot. Its Called ValuFlex GS It says good to 212 degrees a bit low but I'm sure in reality likely fine for much more. My build is designed to keep coolant temps below 200 degrees at al times.
sixnotfour
post Mar 29 2014, 05:03 PM
Post #90
That's Quite a 914. (IMG:style_emoticons/default/smilie_pokal.gif)
drive-ability
post Apr 19 2014, 10:37 PM
Post #91
More Progress (IMG:style_emoticons/default/smile.gif)
I decided to run larger coolant hoses this time as I may build a much bigger engine. Now just a 400 hp unit. the lines are 1 1/2 & 1 1/4 and I had to open up the center tunnel as I'm running them in the car.
(IMG:http://www.914world.com/bbs2/uploads_offsite/i60.photobucket.com-3782-1397968657.1.jpg)
(IMG:http://www.914world.com/bbs2/uploads_offsite/i60.photobucket.com-3782-1397968657.2.jpg)
(IMG:http://www.914world.com/bbs2/uploads_offsite/i60.photobucket.com-3782-1397968657.3.jpg)
(IMG:http://www.914world.com/bbs2/uploads_offsite/i60.photobucket.com-3782-1397968658.4.jpg)
(IMG:http://www.914world.com/bbs2/uploads_offsite/i60.photobucket.com-3782-1397968658.5.jpg)
The pedal setup is Wilwood and I adapted the Corvette DBW to the Wilwood set up.
We will see how it works, after I was told the Corvette calibration is sensitive and it may be hard to modulate the power. The large black cable is to feed the electrical stuff around the radiator, running that through the tunnel as well. Its getting crowded in the area. Still need fuel, brake and other electrical to fit. OH A/C lines (IMG:style_emoticons/default/dry.gif)
(IMG:http://www.914world.com/bbs2/uploads_offsite/i60.photobucket.com-3782-1397968658.6.jpg)
Here's a look at the drive belt, I didn't think the tensioner would fit with the Toy-Jet coolant manifold but got lucky (IMG:style_emoticons/default/biggrin.gif)
(IMG:http://www.914world.com/bbs2/uploads_offsite/i60.photobucket.com-3782-1397968658.7.jpg)
r_towle
post Apr 20 2014, 05:53 AM
Post #92
Custom Member
Damn.....
Did not read the whole thread, good to see you back, but damn...
Think about hard lines in the tunnel....stainless tubing or some other metal tubing....might be easier to replace the rubber lines if they are only on either end.
Mike Bellis
post Apr 20 2014, 09:20 AM
Post #93
Resident Electrician
I had hoses in the tunnel on my first conversion car. It will get very hot in the cabin unless you insulate the lines. (IMG:style_emoticons/default/smile.gif)
I do like the location. I have been thinking about raising the tunnel, creating a void under the car to run hoses.
2mAn
post Apr 20 2014, 09:48 AM
Post #94
trying to see how long I can go without a 914
thats why he is going to have A/C (IMG:style_emoticons/default/poke.gif)
veekry9
post Apr 20 2014, 05:57 PM
Post #95
OldMember
Group: Retired Members
Since I sampled the pix some time ago,you have done an incredible amount of work.And just as I have envisioned it.those wide fenders look great.
An inspiration to us all,proof in metal.Integrating the latemodel part#'s is ingenious.You are way ahead of me.
I messed around with it a little recently in my own efforts to evolve the 914.
Some radical raising of the trunkline,to receive 944-like glass/plexi.
drive-ability
post May 1 2014, 12:11 AM
Post #96
The car is about 5 inches wider in the back. I would like to add a more modern
type tail light assembly but haven't seen anything yet. Doing this can open a huge can of worms and would be likely much harder to make it look right. Waiting on parts, clutch kit and some other parts. I'm wiring the engine now, basically re-working the factory LS1 wiring harness. Got a new ECM, setup one removing most
of the factory emission, and VATS etc.
drive-ability
post May 2 2014, 01:43 AM
Post #97
Here is a picture of the engine and the water pump manifold I picked up. It is a pain to install because of real hard to get to fasteners but worth it.
(IMG:http://www.914world.com/bbs2/uploads_offsite/i60.photobucket.com-3782-1399016621.1.jpg)
veekry9
post May 2 2014, 06:03 PM
Post #98
OldMember
It seems the latest rage is the euro look,with the amber lens.
A Volvo taillight assy is similar to the 944 lens,wider+taller.
Some VW tails are also eurostyle.
I'm surprised it's only 2.5"/s,looks good though.
Man,the work is terrific.
Belay those electrical gremlins.
r_towle
post May 2 2014, 06:57 PM
Post #99
Custom Member
What is the standard solution for heat and defrost in a water cooler conversion car?
drive-ability
post May 4 2014, 11:33 PM
Post #100
California !
I don't know ? I made a trip up to the snow in WA. from Ca. and I just piped in a big oil cooler W/ a fan in the passenger foot well. Worked great but was noisy. (IMG:style_emoticons/default/beerchug.gif)
- Lo-Fi Version Time is now: 26th December 2024 - 07:28 AM
