2056 Valvetrain question |
worn |
Sep 26 2013, 10:56 AM
can't remember Group: Members Posts: 3,348 Joined: 3-June 11 From: Madison, WI Member No.: 13,152 Region Association: Upper MidWest |
QUOTE If the adjusters are as you describe, the pedestals are too high, or the pushrods too short or the cam and tappet length is too short. Dont you mean: pedestals to low, pushrods too long, or tappet length too long? Well, I couldn't be sure. I took the description to mean that the screws were driven into the rocker until the slot was buried. But my first thought about the problem is as you describe, with the adjuster screwed out as far as possible - you can run out of swivel room with the elephant's feet that way. In that case I *might* shim the pedestals. I did with my 2056 but it was to obtain the valve pushrod geometry that I wanted - I cut my own push rods after I shimmed the pedestals and used the adjustable pushrod. |
stugray |
Sep 26 2013, 11:06 AM
Advanced Member Group: Members Posts: 3,825 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None |
QUOTE Well, I couldn't be sure. I took the description to mean that the screws were driven into the rocker until the slot was buried. Ahh... I think you are right. I was originally picturing that he could not get the feet far enough IN to get any valve lash. Now I think you are right. |
flipb |
Sep 26 2013, 11:21 AM
Senior Member Group: Members Posts: 1,766 Joined: 2-September 09 From: Fairfax, VA Member No.: 10,752 Region Association: MidAtlantic Region |
Any confusion is my fault - I was furiously scribbling notes while on the phone with my mechanic. He had in fact suggested 1.7 Rockers and Swivel Feet adjusters from a 911. That got lost in my confused transcription.
We're pretty much all set now. Thanks to all who helped me figure out what I needed. Again, this guy's a very experienced builder but with flat sixes, not T4s. |
Sep 26 2013, 11:31 AM
Custom Member Group: Members Posts: 24,645 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
Is your mechanic local to you?
How close to DC metro is your engine builder? Rich |
flipb |
Sep 26 2013, 11:41 AM
worn |
Sep 27 2013, 11:02 AM
QUOTE Well, I couldn't be sure. I took the description to mean that the screws were driven into the rocker until the slot was buried. Ahh... I think you are right. I was originally picturing that he could not get the feet far enough IN to get any valve lash. Now I think you are right. To finish this off. I drove my 2056 914 to work today again, and it runs like a top. It wouldn't have but for the advice of people who responded here and others on the board. Thanks!! |
Jake Raby |
Sep 28 2013, 03:34 PM
Engine Surgeon Group: Members Posts: 9,398 Joined: 31-August 03 From: Lost Member No.: 1,095 Region Association: South East States |
The valve train aspect of the -4 is the biggest difference that people will experience when they are typically working with -6 engines.
This engine can't be treated like something else. |
Lo-Fi Version | Time is now: 26th November 2024 - 11:14 AM |
