22 Pages V « < 14 15 16 17 18 > »
> Out with the old and in with the Roo, Out with the 4 and in with the 6!
A&P Mech
post Sep 5 2016, 08:56 PM
Post #301
Thanks! The center console came out way better than expected. I think it looks really cool. I am pretty happy with it.
So far my impression of the SpeedHut gauges is that it was money well spent! I love the GPS speedometer. It is so cool that it does 1\4mile and zero to sixty times. I am looking forward to the altitude read out for the RRC next Thursday.
Chris H.
post Sep 5 2016, 09:14 PM
Post #302
daaaaannnngg that center console is nice. Nice work on the gauge panel too. I need to do that myself. Mine is plastic so I'll cut some slits and epoxy a few tabs in to hold them better.
A&P Mech
post Sep 6 2016, 05:29 AM
Post #303
Thanks Chris! The one criticism I have with the SpeedHut gauges is the threaded body of the gauge is larger than the diameter than interfaces the panel. So if you cut the hole to clear the threads the gauges will float a bit when they are fully seated. (I know that I am being a bit picky) I am sure that this would be a non-issue if I would have use a thicker material for the backing plate. Either way it is time to put some miles on the car. (IMG:style_emoticons/default/driving.gif)
What type of hose did you use for your clutch master cylinder reservoir? I used fuel hose and after a little googling, it turns out that this is a bit of a no-no. I guess fuel hose is not brake fluid compatible. The hose will eventually break down and start to leak. I ordered some tygon tubing to replace it. The nipple on the master cylinder is metic (7mm) and it measures around 0.270" . The closest size I found was 0.250. I am hoping it will stretch a little bit? I plan to replace it tonight.
Chris H.
post Sep 6 2016, 07:33 AM
Post #304
I just went to a flaps and asked for hydraulic hose. Its rubber but very HARD and inflexible compared to fuel hose. If your solution doesn't work out let me know and I can look underneath. Can't see any markings on it topside.
It should definitely stretch .02.
Cairo94507
post Sep 6 2016, 07:42 AM
Post #305
Michael
A&P Mech - That console looks perfect. I like the gauges too. Very nicely done. That console looks as if it should have come from the factory. (IMG:style_emoticons/default/smilie_pokal.gif)
A&P Mech
post Sep 6 2016, 12:13 PM
Post #306
Cairo, thanks for the kind words! (IMG:style_emoticons/default/beerchug.gif)
Andyrew
post Sep 6 2016, 01:15 PM
Post #307
Spooling.... Please wait
Great job on the center console!
JRust
post Sep 6 2016, 02:21 PM
Post #308
QUOTE(A&P Mech @ Sep 5 2016, 07:56 PM) *
LOL! I have the same gauges & didn't even know it had those options. Guess I need to read my manual (IMG:style_emoticons/default/blink.gif) . Very cool looking forward to seeing it in person. We'll have to have a little race as our setup is close to the same (IMG:style_emoticons/default/driving.gif)
A&P Mech
post Sep 6 2016, 08:48 PM
Post #309
QUOTE(JRust @ Sep 6 2016, 02:21 PM) *
I'm looking forward to it! Only 3days to go!
sixnotfour
post Sep 6 2016, 09:06 PM
Post #310
Love your center console and shifter set up. Looks great.
A&P Mech
post Jan 21 2017, 03:09 PM
Post #311
Well I am sure it happens to us all at some point, the quest for more power has me rethinking my current engine choice. The 2.5L 4 cylinder was fun, but it is time for a 3.0L six. (IMG:style_emoticons/default/happy11.gif) Thanks to Ross with his throttle body relocation it is now possible to drop an Subaru EZ30 into a 914 without cutting a hole in the trunk. So the quest is on for a low mileage ez30.
I will be selling my 2.5 ej253 with all of the Outfront bits. I will eventually get it listed in the classifieds.
JRust
post Jan 21 2017, 04:42 PM
Post #312
QUOTE(A&P Mech @ Jan 21 2017, 01:09 PM) *
Good for you man. That six will be sweet
Chris H.
post Jan 22 2017, 04:40 PM
Post #313
That was fast (IMG:style_emoticons/default/biggrin.gif) .
rnellums
post Jan 22 2017, 04:44 PM
Post #314
Professional Enthusiast
QUOTE(Chris H. @ Jan 22 2017, 03:40 PM) *
Haha. It will be (IMG:style_emoticons/default/wink.gif)
A&P Mech
post Jan 22 2017, 05:23 PM
Post #315
Yeah, I might suffer from a short attention span. (IMG:style_emoticons/default/blink.gif)
The truth is my 2.5L is burning a lot of oil. It looks like a freight train on start up. The engine only has 90k on it. I have done head gaskets and valve guide seals and it still continues to go through oil like a 1940's radial engine. (IMG:style_emoticons/default/WTF.gif) I chased it for a while thinking it was a PCV problem but the system now has a catch can installed. The catch can stays dry. The only other thing that I can think of is bad or stuck rings?
I played with the idea of rebuilding the bottom end but I see Ross eveyday at work and his awesome silver 3.0 subaru powered 914. I believe the phrase that comes to mind is " Resistance is futile " or "You will be assimilated" LOL.
So the quest begins for a 3.0 H6.
JRust
post Jan 22 2017, 07:45 PM
Post #316
Apparently it only takes a weekend to do that complete conversion (IMG:style_emoticons/default/blink.gif) so why the heck not. I guess you need to just wait until the week before route 66 & you should be good to go right Ross (IMG:style_emoticons/default/evilgrin.gif)
A&P Mech
post Jan 22 2017, 07:48 PM
Post #317
Laughing my ass off! (IMG:style_emoticons/default/beerchug.gif)
rnellums
post Jan 22 2017, 07:49 PM
Post #318
QUOTE(JRust @ Jan 22 2017, 06:45 PM) *
Week before? All the hard stuff is already done, just need to swap the motor, I'm thinking 3, maybe 4 hours?
A&P Mech
post Jan 22 2017, 07:51 PM
Post #319
Sounds like we could do it the morning of? (IMG:style_emoticons/default/av-943.gif)
JRust
post Jan 22 2017, 07:55 PM
Post #320
QUOTE(rnellums @ Jan 22 2017, 05:49 PM) *
Of course it won't take you that whole week. I said weekend too but I forget your like Jimmy Johns
- Lo-Fi Version Time is now: 7th January 2025 - 01:05 PM
