Rear Trunk - I did a very stupid thing |
wndsnd |
Oct 10 2013, 01:50 PM
You wanted a horse, but got a goat. Nobody wants a goat.... Group: Members Posts: 2,861 Joined: 12-February 12 From: North Shore, MA Member No.: 14,124 Region Association: North East States |
I could not have restored my car without the search function on the World. I use it many times a day
I find what works best for me is using quotes "Open Trunk" or "trunk latch" John |
flipb |
Oct 10 2013, 02:00 PM
Senior Member Group: Members Posts: 1,734 Joined: 2-September 09 From: Fairfax, VA Member No.: 10,752 Region Association: MidAtlantic Region |
Someone made this custom Google tool. I have found it useful and have it bookmarked: https://www.google.com/cse/home?cx=00240834...772:ajvfxschcgc Paul You can also/instead just put the following into the Google search field in addition to your search terms: site:914world.com |
JamesM |
Oct 10 2013, 02:09 PM
Senior Member Group: Members Posts: 1,933 Joined: 6-April 06 From: Kearns, UT Member No.: 5,834 Region Association: Intermountain Region |
I had a friend who had the same setup of electronic latch and Porsche reflector. He drilled a 1/8 hole in exactly the right place to stick a long allen wrench in there and push open the latch. You really could not see it at all, but it was a good idea for insurance to get in there when needed. I suspect if you are game, someone can get you some accurate measurement...then its just drill a hole, stick in a stiff piece if steel (not a coat hanger) and push. Allen wrench was one of the T handle long ones... Rich (IMG:style_emoticons/default/agree.gif) I have the same thing on mine, along with a thin steel rod on my keychain to open it. |
lsintampa |
Oct 10 2013, 02:15 PM
Senior Member Group: Members Posts: 520 Joined: 28-January 13 From: Tampa, FL Member No.: 15,441 Region Association: South East States |
I could not have restored my car without the search function on the World. I use it many times a day I find what works best for me is using quotes "Open Trunk" or "trunk latch" John Yeah, I tried "open trunk" and found a great thread about BMW calipers. Guys, enough with the search lessons already. It works for most of you, but I really haven't had much success. I'll take all the good suggestions to heart and try harder. Meanwhile, I searched my soul for a miracle and one showed up! My magnet finally worked. (IMG:style_emoticons/default/clap56.gif) Now on to installing a fail safe fall back. Thanks to all for your help on how to be a better search guru! Appreciated! Len (IMG:style_emoticons/default/huh.gif) |
lsintampa |
Oct 10 2013, 02:19 PM
Someone made this custom Google tool. I have found it useful and have it bookmarked: https://www.google.com/cse/home?cx=00240834...772:ajvfxschcgc Paul This is the bomb! Thanks.... will use this often!!!! (IMG:style_emoticons/default/beerchug.gif) |
green914 |
Oct 10 2013, 05:25 PM
Senior Member Group: Members Posts: 1,467 Joined: 29-March 11 From: Sacramento, California Member No.: 12,874 Region Association: Northern California |
I just put the stock push-button back in mine (IMG:style_emoticons/default/smile.gif) Repairing the rust that formed behind the plastic-lenses, and filling in the holes - $900 - having a working trunk latch - priceless.
turk22 |
Oct 10 2013, 05:56 PM
Treetop Flyer Group: Members Posts: 735 Joined: 27-July 12 From: Cincinnati OH Member No.: 14,725 Region Association: Upper MidWest |
Someone made this custom Google tool. I have found it useful and have it bookmarked: https://www.google.com/cse/home?cx=00240834...772:ajvfxschcgc Paul This is the bomb! Thanks.... will use this often!!!! (IMG:style_emoticons/default/beerchug.gif) (IMG:style_emoticons/default/agree.gif) This is the best, no "+" signs needed... |
bulitt |
Oct 10 2013, 06:59 PM
Achtzylinder Group: Members Posts: 4,188 Joined: 2-October 11 Member No.: 13,632 Region Association: South East States |
The threads really don't expound on the process Eric mentioned. I only listed a few out of two pages of search results i got with a quick search that took all of 5 seconds to do. I was not trying to provide links to threads that i knew had the best answer. Is it really so hard to type 3 words in the search box and read through two pages of results all by yourself? (IMG:style_emoticons/default/confused24.gif) Andy- I was just trying to say that after searching and reading the threads Eric had already covered the process pretty well. |
rick 918-S |
Oct 10 2013, 07:17 PM
Hey nice rack! -Celette Group: Members Posts: 20,512 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
Just did the same thing. I ended up removing the hinge bolts, lifting the lid as high as it would go, Removed the gasket across the trunk bulkhead and made up an extension from 1/4" rod to get to the 10mm bolts. I now have a safety wire on the latch that comes down between the muffler heat shield and rear body panel.
PanelBilly |
Oct 10 2013, 07:33 PM
914 Guru Group: Members Posts: 5,824 Joined: 23-July 06 From: Kent, Wa Member No.: 6,488 Region Association: Pacific Northwest |
I spent more time repairing the holes I had drilled in the car for the reflector than I did installing it and rigging the extensions to "break in" when it failed to let me in the trunk. Lesson learned. I still like the look of the reflector.
Lo-Fi Version | Time is now: 26th June 2024 - 07:26 AM |
