New 'Hobby' Project, carb tuning gone high tech |
ww914 |
Nov 17 2013, 09:00 AM
914 Convert Group: Members Posts: 435 Joined: 29-September 11 From: Central Coast, CA Member No.: 13,621 Region Association: Central California |
McMark |
Nov 17 2013, 10:33 AM
(IMG:style_emoticons/default/headbang.gif)
I can't believe I'm still getting the 'use the tube and water method' posts. I thought I was pretty clear. I'm not asking how to sync carbs. I'm sharing my project that I've already decided to build and am nearly halfway done with. (IMG:style_emoticons/default/rolleyes.gif) From Post #12 QUOTE I have one of those I've never used because it's so impractical. I'm sure it would work just fine, but I'm hoping for something that can be used while driving as well. |
euro911 |
Nov 17 2013, 11:57 AM
Retired & living the dream. God help me if I wake up! Group: Members Posts: 8,860 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California |
Stick to your guns, Mark (IMG:style_emoticons/default/aktion035.gif)
ConeDodger |
Nov 17 2013, 12:14 PM
Apex killer! Group: Members Posts: 23,853 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
(IMG:style_emoticons/default/headbang.gif) I can't believe I'm still getting the 'use the tube and water method' posts. I thought I was pretty clear. I'm not asking how to sync carbs. I'm sharing my project that I've already decided to build and am nearly halfway done with. (IMG:style_emoticons/default/rolleyes.gif) From Post #12 QUOTE I have one of those I've never used because it's so impractical. I'm sure it would work just fine, but I'm hoping for something that can be used while driving as well. For the record, Mark has one of those tube and water methods leaning against the wall. He's been there, done that... (IMG:style_emoticons/default/dry.gif) |
Nov 17 2013, 12:48 PM
Resident German Group: Admin Posts: 41,945 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
I can't believe I'm still getting the 'use the tube and water method' posts. Can't you just sprinkle some water on your circuit board? That should work ... (IMG:style_emoticons/default/rolleyes.gif) |
gothspeed |
Nov 17 2013, 02:41 PM
Senior Member Group: Members Posts: 1,539 Joined: 3-February 09 From: SoCal Member No.: 10,019 Region Association: None |
Started working on this project this weekend. Got the board soldered, ran the test code to make sure it worked, then started working out the layout. Runs pretty fast and seems like it'll work well. This is just with random values. https://www.youtube.com/watch?v=3pBbAG4x0P0 Now I need to start working on averaging. Feel free to post detailed averaging formula/code/links. This is a great idea McMark (IMG:style_emoticons/default/smilie_pokal.gif) ! It would be useful for any engine using individual butterflies per cylinder or per cylinder bank not just carbs (IMG:style_emoticons/default/smile.gif). I currently use individual vacuum gauges for each cylinder but I know there is some variation to each of the bellows inside of each gauge. So something like this should theoretically have less variation. What do you think the price point would be on a 4 channel sensor system? (IMG:style_emoticons/default/idea.gif) |
02loftsmoor |
Nov 17 2013, 08:11 PM
Senior Member Group: Members Posts: 577 Joined: 26-June 11 From: Ft. Worth TX Member No.: 13,243 Region Association: Southwest Region |
I used Mercury Sticks to balance my Motor cycle carbs works great.. it's only about 24" long
Nov 17 2013, 10:00 PM
Custom Member Group: Members Posts: 24,663 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
Cool project.
To bad the sensors are so large... Would be nice to have the whole system hidden. |
ConeDodger |
Nov 17 2013, 10:29 PM
Cool project. To bad the sensors are so large... Would be nice to have the whole system hidden. He plans on hiding it in a tool cabinet. Tuning tool... (IMG:style_emoticons/default/smile.gif) |
Nov 17 2013, 10:33 PM
914 Idiot Group: Members Posts: 15,063 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
I'm still really liking Mike B's idea of using multiple air-flow meters...
--DD |
gothspeed |
Nov 17 2013, 10:37 PM
Andyrew |
Nov 17 2013, 11:15 PM
Spooling.... Please wait Group: Members Posts: 13,377 Joined: 20-January 03 From: Riverbank, Ca Member No.: 172 Region Association: Northern California |
That is awesome! Would be great for bikes... Hard to do many things at once, especially with 4 carbs..
McMark |
Cool project. To bad the sensors are so large... Would be nice to have the whole system hidden. I found small sensors I'm going to try. Not my hands. (IMG:style_emoticons/default/icon8.gif) Attached image(s) |
Nov 18 2013, 07:34 PM
Can you use an airflow sensor for what you are doing?
At the end of the day, it's a wire suspended across a tube/cylinder. Seems you could cut that down to an inch or less in height.. Or incorporate it into a velocity stack. I do love the idea... |
Spoke |
Nov 18 2013, 09:37 PM
Jerry Group: Members Posts: 7,104 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
Looks pretty cool.
We've used Arduino for several projects. I did an interface board to Arduino for a customer. Let me know if you need any help with a design or a PCB. |
ww914 |
Nov 19 2013, 08:24 AM
QUOTE Are those 4 temp readings air intake temps? No they are aircraft cylinder head temps gauges with a sensor under each spark plug. This is an old photo. I now have an oil temp gauge as well on the bottom. Sorry, I messed this post up. |
stugray |
Feb 9 2014, 01:03 PM
Advanced Member Group: Members Posts: 3,825 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None |
Mark,
I thought about another excellent use for your arduino project: http://www.arduino.cc/en/Tutorial/KnockSensor & http://www.ebay.com/itm/E46-bmw-m3-s54-kno...093&vxp=mtr Your arduino should have 6 Analog inputs. SO you should have two left. You could put one knock sensor on each head. I am also playing with a arduino that could be used for variable ignition timing. It would have a programmable advance curve based on RPM. Then you could make it change timing based on:RPM Manifold pressure (load) and input air temperature. If you had the knock sensor, it could retard timing if knock is detected. |
AE354803 |
Feb 10 2014, 11:44 AM
Member Group: Members Posts: 232 Joined: 13-August 12 From: Southern California Member No.: 14,801 Region Association: Southern California |
Cool project. To bad the sensors are so large... Would be nice to have the whole system hidden. I found small sensors I'm going to try. Not my hands. (IMG:style_emoticons/default/icon8.gif) Nice project. I'm surprised how well it is reading the individual vacuum pulses. Just a thought, if you are having issues with filtering/averaging the vacuum waveform into a stable value, adding a length of tubing between the manifold and the sensors should help equalize the pulse, especially if there is a reservoir of some sort in that line. |
jfort |
Feb 10 2014, 12:22 PM
Senior Member Group: Members Posts: 1,143 Joined: 5-May 03 From: Findlay, OH Member No.: 652 Region Association: Upper MidWest |
interesting. and I had as a winter project an attempt to tune the Webers on my six. Now I think I should wait and watch this thread.
McMark |
Feb 10 2014, 03:52 PM
Haven't had a carb'd car in to do any more testing with it. I added some filtering by throwing out values that are some percentage different than the last 'real' value. So it would basically limit the indication from moving beyond a relatively small range.
I really need a daily driver with carbs on it to really test this out. |
Lo-Fi Version | Time is now: 27th December 2024 - 11:25 AM |
