saigon71 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,000 Joined: 1-June 09 From: Dillsburg, PA Member No.: 10,428 Region Association: MidAtlantic Region ![]() ![]() ![]() |
That jumper of the yellow wire at the seat belt relay is starting to sound suspect. Here is an easy way to check it. Using a small straight pin, push the pin in the yellow wire from the key switch, take a reading. Then push the pin in after the splice and take another reading. They should be the same. If not, the splice is bad. Tom (IMG:style_emoticons/default/smilie_pokal.gif) Success! (IMG:style_emoticons/default/biggrin.gif) There were multiple problems in the starting system. Wanted to rule out the seat belt logic early on so I ran a jumper wire between the yellow wires and shrink wrapped the entire joint. Went on to find the ignition switch cracked...replaced - no dice. Ran new electrical cables - still no better. Took the relatively new Optima battery in today for a load test - looked great Used Tom's pin method on both sides of my splice. Under load, there was about .7 volt difference. Splice wasn't heavy enough of a gauge wire to handle the current. Hadn't even given it thought. Car is firing up with the key every time now. Thanks for the responses...appreciate the help. (IMG:style_emoticons/default/beerchug.gif) |
jimkelly |
Delaware USA ![]() ![]() ![]() ![]() Group: Members Posts: 4,969 Joined: 5-August 04 From: Delaware, USA Member No.: 2,460 Region Association: MidAtlantic Region ![]() |
nice to hear you got the problem licked.
i'm torn between, butt crimp connectors, and soldering, for wire joining? http://www.youtube.com/watch?v=4y3iCWDpjE8 jim |
Cap'n Krusty |
Cap'n Krusty ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,794 Joined: 24-June 04 From: Santa Maria, CA Member No.: 2,246 Region Association: Central California ![]() |
nice to hear you got the problem licked. i'm torn between butt crimps and soldering? http://www.youtube.com/watch?v=4y3iCWDpjE8 jim Soldering automotive wiring isn't the best of ideas. Bosch, VW/Audi, and Porsche specifically tell you NOT to do it. Use quality non-insulated butt connectors of the appropriate diameter and cover the joint with shrink tubing. Use a proper crimping tool, too. The Cap'n |
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,000 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California ![]() ![]() |
An expert can get solder joints that are appropriate for automotive applications. There are few of us who are experts at that level--and if you have to ask, you're not. For the rest of us, crimped splices are better, assuming you're using a good crimper that applies the right amount of force (hint: It's a lot!) and uses the correct shaped die--usually the one that makes the ends of the crimp lugs curl around and push back into the wire.
The "universal electrical tool" type crimpers you can get at every FLAPS everywhere are very much not the correct tool for the job. --DD |
Tom |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,139 Joined: 21-August 05 From: Port Orchard, WA 98367 Member No.: 4,626 Region Association: None ![]() |
So glad YOU were able to find and fix it. Sometime we all need a little help!
Tom |
saigon71 |
Starter issues returned. It got to the point that I couldn't even get it started with a push button start switch while on a road trip.
After doing some research on 914world, I bought a new hi-torque mini starter from this ebay seller: http://www.ebay.com/itm/PORSCHE-911-MINI-S...=item4ac9f460b4 It came with a shim. The factory starter bolts weren't long enough to use the shim, so I installed it without. Oil leaks have kept me from testing it on the road, but it seems to be working well, cranking every single time. My next step is McMarks relay kit if this doesn't work. ![]() ![]() ![]() |
jimkelly |
as for shims, I don't understand. the only need I can see for shims is if the starter plunger pops out too far, thus past the flywheel teeth. if plunger does not pop out far enough, I see no fix for this.
it is certainly ideal I assume if teeth on starter and teeth on flywheel line up perfectly. I have a renegade hi torque starter (brand model unknown - could be Chinese for all I know) on my v8 but I am definitely going to add a relay, probably a ford unit like mark henry uses, as this unit looks more heavy duty and weather resistant. as I want to ensure my starter is getting full power when in operation. http://www.914world.com/bbs2/index.php?sho...2&hl=relays Attached image(s) ![]() |
Lo-Fi Version | Time is now: 26th June 2024 - 09:59 AM |
