16 Pages V « < 8 9 10 11 12 > »
> Area51Werks starts another Autotopsy Resurrection of a Factory 6, Welding is Done! Fixtures are removed Onto the cleanup and paint work.
Freezin 914
post Feb 16 2024, 06:12 AM
Post #181
Very impressive! Looking good! (IMG:style_emoticons/default/beerchug.gif)
DRPHIL914
post Feb 16 2024, 07:00 AM
Post #182
Dr. Phil
(IMG:style_emoticons/default/piratenanner.gif) (IMG:style_emoticons/default/welder.gif) wow , huge project, cars like that were crushed not many years ago,
nice that they have become worth enough to put the time and effort into saving.
Cairo94507
post Feb 16 2024, 07:21 AM
Post #183
Michael
Just so pleasing to see a badly damaged car come back from that and look like it did when it was assembled at the factory. (IMG:style_emoticons/default/smilie_pokal.gif)
EdwardBlume
post Feb 16 2024, 07:26 AM
Post #184
Well done Rick!
infraredcalvin
post Feb 16 2024, 07:34 AM
Post #185
Distracted Member
Wow, just wow!
That is such a milestone, love to see those seams so tight and the welds started. You have got to be excited to see this coming back together.
majkos1
post Feb 16 2024, 08:27 AM
Post #186
QUOTE(infraredcalvin @ Feb 16 2024, 08:34 AM) *
Wow, just wow!
(IMG:style_emoticons/default/agree.gif) (IMG:style_emoticons/default/popcorn[1].gif)
it's ART, as you majestically craft the pieces together. (IMG:style_emoticons/default/smiley_notworthy.gif)
You have secret help? (IMG:style_emoticons/default/alien.gif)
TRS63
post Feb 16 2024, 09:30 AM
Post #187
Region Association: Europe
Looking fantastic!
Antoine
rick 918-S
post Feb 16 2024, 11:33 AM
Post #188
Hey nice rack! -Celette
QUOTE(majkos1 @ Feb 16 2024, 08:27 AM) *
Wow, just wow!
Hey Kevin! Wish i had an Alien helping me. When you tack the seam it pulls tight. You need to be able to hold a dolly on the back of the weld and strike the tack. This spreads the seam out again. Otherwise by the time you get 6" the metal is overlapping. I really needed a second set of hands but I figured it out.. (IMG:style_emoticons/default/smash.gif)
rick 918-S
post Feb 16 2024, 11:25 PM
Post #189
Second day welding.
Not the prettiest welding I ever did but tig welding at the bottom of the gas tank well to me is like trying to build a ship in a bottle. I think my auto darkening hood was not working tonight. (IMG:style_emoticons/default/blink.gif) I had a low battery light on. Once I am finished I will flush off the weld.
Note the fixture I made to align hole in the panel.
rick 918-S
post Feb 25 2024, 11:02 PM
Post #190
I haven't posted any progress in a while. This type of repair is victory by millimeters.At this point I have the Frunk Floor welded to the inner wheelhouses. I have the bulkhead and cross support for the strut towers welded. I have the front panel lower supports for the front panel to floor to wheelhouse welded. I used my Lenco Panel spotter so it looks factory.
Here is the bulkhead fit prior to spot welding. Consiering this panel was buckled in half and rwisted this is a remarkable fit.
Here it is after spot welding
Right Brace
Left Brace
The best part of the progress is this right and left fender fit. There is literally dozens of hours in moving the upper body back into alignment. The right fender being the most challenging. As a reminder here is where I started.
The first photo was over a month ago. The second photo was today.
Attached ImageAttached Image
There are about 8 hours of welding left. Granted I only get to work on the car a couple hours an evening if I am lucky. But I am getting close. Even when the welding is finished I will have several hours on correcting work on the right fender that was done prior to this crash.
Victory by Millimeters (IMG:style_emoticons/default/smash.gif) (IMG:style_emoticons/default/sawzall-smiley.gif) (IMG:style_emoticons/default/welder.gif) (IMG:style_emoticons/default/assimilate.gif)
vintage914racer
post Feb 26 2024, 07:46 AM
Post #191
Great work, Rick!
I'm always amazed by the work that you do.
Cairo94507
post Feb 26 2024, 07:58 AM
Post #192
Michael
Man, that fender/hood gap.... (IMG:style_emoticons/default/beerchug.gif)
doug_b_928
post Feb 26 2024, 09:01 AM
Post #193
That quarter gap is amazing!!! I’d be interested to see how you did that.
rick 918-S
post Feb 26 2024, 09:45 AM
Post #194
So much more to do before I can say I am happy keeping the right fender. There was a prior repair involving drilling holes and lots of body filler I don't like using. I will expand on the process later tonight.
rick 918-S
post Mar 1 2024, 06:10 AM
Post #195
Continued working on the right fender. There was a crack in the fender by the Headlight bucket and a kink in the vertical wheelhouse extension where the headlight pivot bolts. The metal eas overlapping at the crack.
After about 3 hours the crack is repaired.
The hood is not bolted. I just wet it on and pushed it up against the cowl panel
Still working on the end of the fender around the running light. There are a few other rips that need attension. I could replace this frnder but I would rather repair the original if it works out.
rick 918-S
post Mar 4 2024, 10:00 PM
Post #196
Finally brought the engine home. Kind of a special engine. I got this from Slits. It's a 73 2.7S
KELTY360
post Mar 5 2024, 07:17 AM
Post #197
914 Neferati
QUOTE(rick 918-S @ Mar 4 2024, 08:00 PM) *
(IMG:style_emoticons/default/beer.gif)
rick 918-S
post Mar 7 2024, 07:41 AM
Post #198
Little more progress on the right fender. This is one of the tools I made to planish out damage. As I started to strip this fender I discovered old damage that was pummeled with pick hammer marks and ground thin and stretched.
I held a slightly curved dolly on the back of the panel and planished out the pick marks we well as I was able. Then I spent about 2 hours with a shrinking disc and various body hammers and dollies working out the stretch.
I have the running/signal light fitting nicely now.
Lots of work to do yet but I am getting closer to saying the original fender will remain with the car.
post Mar 7 2024, 08:28 AM
Post #199
You have the patience of Jobe, Rick. (IMG:style_emoticons/default/beerchug.gif)
SteveL
post Mar 7 2024, 08:32 AM
Post #200
When the metal has been ground thin, how thin can it be and still be usable?
- Lo-Fi Version Time is now: 22nd December 2024 - 07:27 AM
