trojanhorsepower |
Senior Member ![]() ![]() ![]() Group: Members Posts: 867 Joined: 21-September 03 From: Marion, NC Member No.: 1,179 Region Association: None ![]() |
914forme |
Times a wastin', get wrenchin'! ![]() ![]() ![]() ![]() Group: Members Posts: 3,896 Joined: 24-July 04 From: Dayton, Ohio Member No.: 2,388 Region Association: None ![]() ![]() |
Just read thru the entire post, that is some great work, and dedication. Makes some of my patches look like I did them in kindergarten.
Olympic 914 |
![]() ![]() ![]() Group: Members Posts: 1,727 Joined: 7-July 11 From: Pittsburgh PA Member No.: 13,287 Region Association: North East States ![]() ![]() |
Also got the little seat adjuster bracket that welds to the cross member. Slowly moving forward, very slowly. I used the seat mount to locate the hinge parts that weld to the floor. After I broke one off trying to loosen it up. Looks good. wish I could weld like that... |
trojanhorsepower |
Thanks Guys,
It is a learning experence and I could not have gotten here with out Doug's help. |
trojanhorsepower |
Worked on prepping the rear quarter to test fit with door.
Attached image(s) ![]() ![]() ![]() ![]() |
trojanhorsepower |
Got it all ready and test fit.
Wah wah (IMG:style_emoticons/default/hissyfit.gif) This is not good. The measurements seem OK, so maybe some fiddling and I can make it work. If not I will be the first competitor out. So far staring at it has not helped...... Attached image(s) ![]() |
trojanhorsepower |
It's weird, but I put the old quarter on and it fit OK, not perfect, but the door will close. I wonder if this means that the new quarter can be made to fit?
JoeDees |
Senior Member ![]() ![]() ![]() Group: Members Posts: 515 Joined: 10-November 14 From: Northern Kentucky Member No.: 18,106 Region Association: None ![]() |
For some reason it is reminding me of the time I helped replace the doglegs on a VW bus. We absolutely couldn't get the door to fit right. Double check your prepwork where it sits and make sure the quarter is sitting flush. Is it warped from removal maybe?
I definitely don't think you're done. I'm betting and hoping it's something fairly simple. |
trojanhorsepower |
Well, I figured I should press on while I think about this fender issue. I have been picking away at the small spots that remain. Got most of the spots on the front end worked fixed, but will have to add after pics tomorrow.
Attached image(s) ![]() ![]() ![]() ![]() ![]() ![]() ![]() |
cary |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,900 Joined: 26-January 04 From: Sherwood Oregon Member No.: 1,608 Region Association: Pacific Northwest ![]() ![]() |
Subscribe
trojanhorsepower |
More pics of the weather stripping repairs.
Still some more work to do, but it was not as bad as I though it would be. Attached image(s) ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() |
trojanhorsepower |
Got some more done today, but no pics. I will add some soon.
I have (I think) finished the patching on the front end. I fiddled with the replacement fender and found that it was hanging a little on the fresh air vent in the door jam. I trimmed a little more and got it to fit, so I am going ahead with the build. I may end up shaving the door a little, but at this point I am confident that I can make one of the fenders work. So, on to the back end. All I have done here is scour out the seam sealer from around the plug. I also found more rust! (IMG:style_emoticons/default/piratenanner.gif) (IMG:style_emoticons/default/mad.gif) Oh well it looks manageable. |
trojanhorsepower |
Took some time this weekend to pull out some more seam sealer.
trojanhorsepower |
Started on the rear trunk pan.
trojanhorsepower |
So my patch panel does not have the threaded hole seen in the last picture at about 12:05. What is this for?
Chris H. |
Senior Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,054 Joined: 2-January 03 From: Chicago 'burbs Member No.: 73 Region Association: Upper MidWest ![]() ![]() |
Spare tire tie down? There is a threaded hole in the rear trunk that allows you to mount the spare tire.
trojanhorsepower |
How does this joint come apart?
914forme |
![]() Remove this screw (Blue Arrow) Pull Cap off (Red Arrow) Pull Swap bar out (Green Arrow) {Optional Step in Reality, I do it to check them} Pull Arm (Pinkish Purplish arrow) Hope that helps |
trojanhorsepower |
Thanks Stephen,
I would not have guessed that was all that holds it together. What about the cap on the other end of the a arm? Does it just slide off as well? |
cary |
Still some more work to do, but it was not as bad as I though it would be. Some where I read you finish those repairs with JB Weld. I used it on my white car. Makes a nice smooth channel to install the new seal in. |
Lo-Fi Version | Time is now: 3rd April 2025 - 07:05 PM |
