11 Pages V « < 6 7 8 9 10 > »
> BUILD-OFF CHALLENGE: Trojanhorsepower's Rusty 74 restoration Mark II, Progress thread to keep me going
Garland
post May 12 2016, 06:41 PM
Post #141
Restoration Fanatic
After review, I think I'm way off on the location of that rusty bolt. In that last post.
trojanhorsepower
post May 12 2016, 07:19 PM
Post #142
Thanks guys!
The gap at the top is not terrible, but bigger than I think it should be. Not that that means anything. The door will not close without forcing it. That said it is not so bad that you cant easily force it to close. It hits in lower corner as pictured and at the latch striker.
trojanhorsepower
post May 30 2016, 07:01 PM
Post #143
Well Doug L. came over and saved the day!
We got the fender realigned. I then had to take it off and beat out some dings and weld up some holes. Any way, onto final fitament. I am screwing the quarter into place. Now I will add the rear deck lid and align it to weld in the hing points. Then I plan to start the welds on the quarter.
trojanhorsepower
post May 30 2016, 07:02 PM
Post #144
Oh yeah, I got the jack point welded on to.
trojanhorsepower
post Jul 19 2016, 04:20 PM
Post #145
Well whiles't I dither, I decided to work on the brakes. I found a few issues:
Both of my adjuster studs have this thread broken off. I guess that is where the lock nut sits.
trojanhorsepower
post Jul 19 2016, 04:21 PM
Post #146
I am ashamed to say I did this one myself:
Is it still usable?
trojanhorsepower
post Jul 19 2016, 04:26 PM
Post #147
The master cylinder dose not look too good.
I was thinking about rebuilding, but I bet it is pitted. Is there a reason not to open it up? I would like to have it for a core if necessary, so if taking it apart means PMB won't want it, I will leave it alone.
trojanhorsepower
post Jul 19 2016, 04:27 PM
Post #148
One more for today. Does anyone know what these are for? I found them in with my brake bits:
trojanhorsepower
post Jul 19 2016, 05:58 PM
Post #149
Deleted
Andyrew
post Jul 19 2016, 06:28 PM
Post #150
Spooling.... Please wait
QUOTE(trojanhorsepower @ Jul 19 2016, 03:27 PM) *
Looks like brake pad retainer pins.
914forme
post Jul 20 2016, 05:01 AM
Post #151
(IMG:style_emoticons/default/agree.gif) exactly what they are and for
trojanhorsepower
post Jul 20 2016, 06:15 AM
Post #152
Do new ones come with a set of pads?
914forme
post Jul 20 2016, 07:20 AM
Post #153
QUOTE(trojanhorsepower @ Jul 20 2016, 08:15 AM) *
no not normally in my experience.
post Jul 20 2016, 07:41 AM
Post #154
Wire brush them. They need to be clean.
trojanhorsepower
post Nov 27 2016, 05:29 PM
Post #155
Well its update time.
I just went ahead and welded the quarter panel on. I am sure it is not perfect, but hopefully it will be good enough.
In the mean time I have been working on a few other little odds and ends like the trailing arms.
I am no diagnostician, but I think this wheel bearing is bad....
trojanhorsepower
post Nov 27 2016, 05:31 PM
Post #156
I have the trailing arms all taped up so when I get some more sand I will blast them and the A arms, then paint and store. A little more welding and I will be ready to blast the whole car.
trojanhorsepower
post Feb 18 2017, 06:03 PM
Post #157
So another update.....
Another problem. I got new door sills but can't seem to make the triangles line up. is it normal to have to modify them?
The tiangles don't really line up with the door sill and they are off the outer rocker by about 1/4 inch.
dlee6204
post Feb 18 2017, 06:11 PM
Post #158
Howdy
QUOTE(trojanhorsepower @ Feb 18 2017, 07:03 PM) *
My replacements on the yellow car had the same issues. I had to modify them to fit.
trojanhorsepower
post Feb 18 2017, 06:27 PM
Post #159
whew! OK I will mod with a clear conscience.
trojanhorsepower
post Feb 21 2017, 07:08 PM
Post #160
Here are the modifications to the triangles.
Results:
- Lo-Fi Version Time is now: 3rd April 2025 - 07:07 PM
