11 Pages V « < 8 9 10 11 >
> BUILD-OFF CHALLENGE: Trojanhorsepower's Rusty 74 restoration Mark II, Progress thread to keep me going
trojanhorsepower
post May 5 2021, 06:51 PM
Post #181
Thanks!
trojanhorsepower
post May 5 2021, 06:53 PM
Post #182
Rebuilt the blower.
trojanhorsepower
post May 5 2021, 06:55 PM
Post #183
And the fresh air blower.
trojanhorsepower
post May 5 2021, 07:00 PM
Post #184
Redid the suspension.
trojanhorsepower
post May 5 2021, 07:01 PM
Post #185
Wiring fun.
trojanhorsepower
post May 5 2021, 07:02 PM
Post #186
Added more bits and bobs.
trojanhorsepower
post May 5 2021, 07:04 PM
Post #187
And its a roller again!
Can't seem to get beyond this point though. So, it's off to Doug's as soon as I can manage it. With his help maybe I can get back on track.
dlee6204
post Jun 11 2021, 05:34 PM
Post #188
Howdy
Peter brought me his car a couple weeks ago in an effort to get it as much as assembled as possible before paint so I will be adding to this thread as I/we make progress.
Worked to route some wiring on the front. Some of the wrap had been removed so I replaced a section for the harness in the front trunk.
Added some grommets and got the wiring for the fogs/horns routed through. Also added the front body plugs.
And then some misc items.
Engine lid drain tunnel
dlee6204
post Jun 11 2021, 05:42 PM
Post #189
Howdy
Began work on the dash area.
The defrost vents were heavily discolored so I taped them off and gave them a coat of paint.
And then I began upholstering the upper dash area. Got the foam on, then the vinyl, and loosely bolted the dash.
bbrock
post Jun 12 2021, 02:50 PM
Post #190
Just catching up here. Thanks for the updates. Your build provided me a lot of inspiration for my own and I'm glad to see the progress continuing. I love that color! (IMG:style_emoticons/default/beerchug.gif)
trojanhorsepower
post Jun 12 2021, 06:27 PM
Post #191
Thanks! I finally admitted to myself that it was not getting done. Funny enough, now that Doug is helping I have been able to get more work done myself. I have been prepping parts to take to Doug. I got the seat mechanism blasted and treated. I'll paint stuff tomorrow. It is really nice to be getting stuff done.
dlee6204
post Jul 21 2021, 07:15 PM
Post #192
Howdy
I've been making some progress on some of the wiring on the car. I've been rewrapping the harness where needed, installing heat shrink over the tabs that hold the wiring and getting it routed into place. The rear harness that goes from the engine bay to the trunk is one example...
Trunk light
dlee6204
post Jul 21 2021, 07:26 PM
Post #193
Howdy
I've also been working on getting the dash in order. I applied the vinyl on the dash face, got the glove box door in working order, made a radio delete plate, and got the switches cleaned up and installed. Peter will likely add a radio down the road but a radio is low priority in the grand scheme of this build.
I then proceeded to install the assembled unit into the car.
And one of the big hurdles was completing the front fresh air system. Peter had a grab-bag of parts for the system so I had to sort through what was still needed, rob parts from my parts car, get all the cables routed correctly and adjusted properly and to get it back in the car without breaking any of the 50 year old plastic. This wasn't too bad of a job, just tedious. I'm waiting on two heater hoses to arrive that go from the mixing valves down to the longitudinals and then this will be 100%.
sixnotfour
post Jul 22 2021, 08:34 PM
Post #194
looks Great ,,double check, did the bearing retainer get in place ?
dlee6204
post Aug 29 2021, 04:51 PM
Post #195
Howdy
QUOTE(sixnotfour @ Jul 22 2021, 10:34 PM) *
Bearing retainer got installed. Must have just been missing for the picture.
dlee6204
post Aug 29 2021, 04:56 PM
Post #196
Howdy
I haven't updated in about month but progress has been slow and steady.
Dash has been completed with the exception of the under dash pad.
Peter also brought his engine and transmission for me to go over. He rebuilt the long block almost 20 years ago and it has been sitting in storage since. Everything external still needed to be cleaned up and verified though. We made the decision to get all the tin powder coated which came out great and at a very reasonable price.
dlee6204
post Aug 29 2021, 05:03 PM
Post #197
Howdy
With the tin freshly coated, assembly of the engine could begin
Peter was also very wise to purchased a brand new ignition harness and FI harness.
The engine still needs a few things. It needs vacuum hoses, fuel lines, and the valve clearances to be set. After that it will be ready to be mated up and installed.
dlee6204
post Aug 29 2021, 05:08 PM
Post #198
Howdy
The transmission also needed some work. Peter had Dr. Evil rebuild it but the tailcone got damaged during shipping and needed replacing. Speedo drive gear, ground strap, clutch cable mount, rear mounts, clutch fork and throwout bearing were also installed. A rebuilt starter will compliment the install.
Dion
post Aug 30 2021, 04:40 AM
Post #199
RN
Nice progress. Slow and steady for the win.
The dash and engine look fantastic!
trojanhorsepower
post Sep 22 2021, 06:55 PM
Post #200
Dr. Evil hooked me up with a tail cone!
Went to Doug's yesterday and we installed and fired the engine. It was too late to run or brake it in, but it was very exciting to see some signs of life.
- Lo-Fi Version Time is now: 3rd April 2025 - 01:12 AM
