trojanhorsepower |
Senior Member ![]() ![]() ![]() Group: Members Posts: 867 Joined: 21-September 03 From: Marion, NC Member No.: 1,179 Region Association: None ![]() |
At this point we decided to cut out for the day. We were getting burned out. We had been grinding away at this project for hours.........
TargaToy |
-NONSOLIS RADIOS SEDIOUIS FULMINA MITTO- ![]() ![]() ![]() Group: Members Posts: 708 Joined: 26-March 10 From: DelMarVa Peninsula Member No.: 11,509 Region Association: MidAtlantic Region ![]() ![]() |
(IMG:style_emoticons/default/sawzall-smiley.gif) Keep it up! Making real progress there. (IMG:style_emoticons/default/welder.gif)
trojanhorsepower |
Thanks Conrad!
It has been really nice to get back to work on this. I could not have done much of it with out Doug. |
trojanhorsepower |
Well it has been a while since my last update, but I have not been totally slack. After Doug left I have been filling in the welds and I made three plates to help strengthen all the welded joints. I have been welding these in a little at a time.
Attached image(s) ![]() ![]() ![]() |
trojanhorsepower |
For now I am out of wire so it is time to grind some welds and clean house. I have my helpers all working hard.
Attached image(s) ![]() ![]() |
trojanhorsepower |
With the holidays over it is time to get back to work. Thanks to my Dad and Father-in-Law, I got some new parts and new supplies. I got a big shipment from RD, a nice autodark helmet and switched my welder over to 10lb. spools.
With the welder up and running I decided to start working on one of the cross braces. Attached image(s) ![]() ![]() ![]() ![]() ![]() ![]() |
FourBlades |
From Wreck to Rockin ![]() ![]() ![]() ![]() Group: Members Posts: 2,056 Joined: 3-December 07 From: Brevard, FL Member No.: 8,414 Region Association: South East States ![]() ![]() |
trojanhorsepower |
Did a little more today. I have started working on the inner and outer fire wall bits. I started working on the outer section and realized there was no reason for it to be in the right place in relation to the long. After measuring and adjusting I am thinking about welding in the inner part first, but how in the heck am I going to locate that stupid dimple?
Attached image(s) ![]() ![]() ![]() ![]() |
trojanhorsepower |
I went back to working on the out firewall, because I have not decided what to do about the dimple. After a long time the two sides of my car are connected at the firewall!
trojanhorsepower |
I have been picking away at the inner firewall. The patch did not have the dimple, so I cut my old dimple out and welded it in to the patch panel. I have been tacking it in over the last few days.
trojanhorsepower |
I have been pecking away at the project.
I got the inside coated with copperweld and the seat belt nut in. Now I am test fitting the outer cover. I can't believe I am actually getting close to closing this long up. I know I still have tons to do, but this will be a nice milestone to cross. Attached image(s) ![]() ![]() ![]() ![]() |
trojanhorsepower |
OK so I have started to test fit the outer long parts. When that is right and welded on, when do the experts think I can remove some of the bracing. Not the main brace, but some of the other bits. I need to remove some of it to start fitting the upper firewall.
trojanhorsepower |
dlee6204 |
Howdy ![]() ![]() ![]() ![]() Group: Members Posts: 2,162 Joined: 30-April 06 From: Burnsville, NC Member No.: 5,956 ![]() |
I wouldn't remove any of it until the long is closed. After that I might keep a simple door brace while it's still on the rotisserie being welded on.
cary |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,900 Joined: 26-January 04 From: Sherwood Oregon Member No.: 1,608 Region Association: Pacific Northwest ![]() ![]() |
Nothing can come off until the outer rocker is welded in.
My .02c. |
trojanhorsepower |
OK, thanks guys.
trojanhorsepower |
The outer long parts clamped/screwed on.
Edit: Not sure what happened here. Attached image(s) ![]() |
trojanhorsepower |
trojanhorsepower |
While I wait for some expert double checking on the outer long, I have moved on to some other bad spots.
trojanhorsepower |
This spot is much harder. I am really struggling to fabricate a patch. Does anyone have a parts car they can cut this bit out of?
Lo-Fi Version | Time is now: 2nd April 2025 - 02:07 AM |
