trojanhorsepower |
Senior Member ![]() ![]() ![]() Group: Members Posts: 867 Joined: 21-September 03 From: Marion, NC Member No.: 1,179 Region Association: None ![]() |
The next problem is the engine shelf. Do most folks have trouble fitting it in place? Do most people have to trim it or cut it in half? I have messed around a little and I can not get it to set right.
dlee6204 |
Howdy ![]() ![]() ![]() ![]() Group: Members Posts: 2,162 Joined: 30-April 06 From: Burnsville, NC Member No.: 5,956 ![]() |
The engine shelf usually takes a little persuasion and fiddling but you definitely don't have to cut it in half.
trojanhorsepower |
Doug, can you be a little more specific? The firewall end of the shelf bends down slightly, but it is not folded 90 degrees like the back of the self. Is this just butt welded to the firewall or folded and spot welded?
Should I put the upper firewall in before I fit the engine shelf? |
dlee6204 |
The front end should have a 90 degree bend and spot welded. At least that's how I've always done it.
trojanhorsepower |
It was a good day today at the Lamb house hold. Doug Leehr came over again and we made some major progress. We got the engine shelf situated and the main firewall welded in! After Doug left I pulled the engine shelf, primed and drilled it and started to weld it back in. The engine bay is seriously starting to look put together.
This puts me back on track. With the floor next I have lots to keep me busy. Thanks again Doug! Attached image(s) ![]() ![]() |
trojanhorsepower |
Been chipping away at it. Removed the last of the old rear floor pan.
Attached image(s) ![]() ![]() ![]() ![]() |
trojanhorsepower |
Then I went back and filled the holes left from cutting out the spot welds.
Attached image(s) ![]() |
dlee6204 |
Looks good! Time to cut out that other crossmember! (IMG:style_emoticons/default/sawzall-smiley.gif)
trojanhorsepower |
Yup. Maybe I will get that done tomorrow.
trojanhorsepower |
Been a little busy with firewood, but I did get a little bit done. I cut out the last seat crossmember, and removed all the old floor material. Then I decided to clean up as much of the belly pan as I could.
Attached image(s) ![]() ![]() ![]() |
trojanhorsepower |
I was focusing on removing seam sealer. That went well until I got to a good stopping point.
trojanhorsepower |
Tonight, with Hugh on the oil can we made some holes in the new floor.
trojanhorsepower |
I need to clean up the backs of the holes, clean off the oil and spray on some weld-through primer and then the floor will be ready to weld into place.
FourBlades |
From Wreck to Rockin ![]() ![]() ![]() ![]() Group: Members Posts: 2,056 Joined: 3-December 07 From: Brevard, FL Member No.: 8,414 Region Association: South East States ![]() ![]() |
Great progress! (IMG:style_emoticons/default/smilie_pokal.gif) Stopping point... (IMG:style_emoticons/default/av-943.gif) (IMG:style_emoticons/default/av-943.gif) (IMG:style_emoticons/default/av-943.gif) John |
trojanhorsepower |
I know that it has been a while (its cold out there), but I promise that I have not been totally inactive. I finished welding in the floor!
trojanhorsepower |
It was nice and warm today so I got a little more done on the car. The bottom is really starting to shape up. I still need to add the reinforcement parts and the floor will be done. Then it is onto the inside of the cabin, rear quarter and rear trunk floor.
dlee6204 |
saigon71 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,011 Joined: 1-June 09 From: Dillsburg, PA Member No.: 10,428 Region Association: MidAtlantic Region ![]() ![]() ![]() |
You are making some great progress! Keep plugging away and keep the pics rolling in. (IMG:style_emoticons/default/beerchug.gif)
dlee6204 |
Is this car done yet? (IMG:style_emoticons/default/poke.gif) |
trojanhorsepower |
(IMG:style_emoticons/default/sad2.gif) No... I have done a little. I got the new cross member, but have not welded it in yet. I hope to have an update Sunday.
Doug; When are you going to bring something over to work on? Welcome anytime. |
Lo-Fi Version | Time is now: 3rd April 2025 - 01:12 AM |
