9 Pages V « < 4 5 6 7 8 > »
> Another 914 goes under the knife, UPDATE: IT'S ALIVE....FINALLY
rick 918-S
post Feb 28 2014, 10:17 PM
Post #101
Hey nice rack! -Celette
I have been working on this car but just finishing little details that don't really photo. I should have some photos in a couple days. Adding seam sealer and finishing welds. I have a patch cut for the front floor almost fit.
Still have to do the left side. (IMG:style_emoticons/default/sawzall-smiley.gif) (IMG:style_emoticons/default/smash.gif) (IMG:style_emoticons/default/welder.gif)
pete000
post Feb 28 2014, 11:16 PM
Post #102
Such impressive work !! (IMG:style_emoticons/default/welder.gif)
rick 918-S
post Mar 5 2014, 08:08 PM
Post #103
Couple progress photos. I have all the structural welding done of the right side. I am starting the left side this week.
euro911
post Mar 6 2014, 09:45 AM
Post #104
Nice work, Rick (IMG:style_emoticons/default/beerchug.gif)
rick 918-S
post May 11 2014, 11:15 PM
Post #105
I was side tracked with a 911 project but I'm back on Ben's cars. Here are a couple photos of the progress.
I cut out the left side jack post and examined the inside of the rail. It was really nice. I washed it out and clean it up then sprayed some Eastwood encapsulator inside and closed it up.
I only had to remove one triangle and the sill. When I went to install the triangle I realized the ones I have are for the right side. I called Restoration Design and was informed they only make the right side. I was told to face the flange backwards to install it on the left side. I couldn't bring myself to do that so I made a left side triangle.
Here the jack post and long all closed up.
I'm only painting the areas I repaired for now. I'll have it finished this week.
relentless
post May 12 2014, 01:32 PM
Post #106
This is a great educational thread to read! Your work is outstanding and attention to detail ditto. I especially appreciate that you are taking the time to make things right and not taking shortcuts.
rick 918-S
post May 12 2014, 06:57 PM
Post #107
QUOTE(relentless @ May 12 2014, 02:32 PM) *
Thank you. It has to be fun or I wouldn't do it. I was cleaning out the tunnel and found a penny. It's was under the shift console. I just had a feeling I should try to clean it off and check the date. I soaked it in some rust dissolver and gave it a quick buff so I could read the date. Sure enough...
abnrdo
post May 12 2014, 08:04 PM
Post #108
Nice work Rick! I love your wheel stands! How the heck did you get the car up there?
rick 918-S
post May 12 2014, 08:26 PM
Post #109
QUOTE(abnrdo @ May 12 2014, 09:04 PM) *
I have a custom built floor jack. I'll take a photo of it when the car comes down.
vintage914racer
post May 12 2014, 08:32 PM
Post #110
Looking good, Rick. I'm looking forward to seeing the car this weekend.
rick 918-S
post May 14 2014, 07:09 PM
Post #111
The welding is officially finished. The only real issue with the left floor pan was some holes through the reinforcements under the driver seat. I was going to try to plug weld the holes but changed my mind last minute.
The passenger side floor was rusted through at the cross member and at the engine bulkhead. But the reinforcement ribs were clean as was the metal around them under the seat area. I recycled the good parts of the right side pan, made a repair panel and replace the left side under the seat.
Here is the repair panel fit and ready to weld.
Here is the section I cut out laid over the finished repair.
I used Eastwoods frame encapsulator spray in all the places I couldn't reach to clean. I used it in inside the longs, inside the tunnel, inside the lower engine bulkhead and inside the seat hinge stands. I flooded the areas and used my blow gun the move the excess. Then wiped up the excess. Here is the finished floor.
Still some work to do before paint.
sixnotfour
post May 14 2014, 07:31 PM
Post #112
Lookin Good.. (IMG:style_emoticons/default/welder.gif)
jmill
post May 14 2014, 07:57 PM
Post #113
Green Hornet
Beautiful work as usual!
pete000
post May 14 2014, 09:54 PM
Post #114
Wow I wish the repair patches in mine were done as nicely as this one is!
Jealous ! (IMG:style_emoticons/default/hissyfit.gif)
rick 918-S
post May 16 2014, 08:26 AM
Post #115
Almost ready for paint.
rick 918-S
post May 16 2014, 07:49 PM
Post #116
vintage914racer
post May 16 2014, 08:15 PM
Post #117
QUOTE(rick 918-S @ May 16 2014, 05:49 PM) *
(IMG:style_emoticons/default/w00t.gif)
rhodyguy
post May 17 2014, 06:17 AM
Post #118
very nice. good work rick.
Cairo94507
post May 17 2014, 07:25 AM
Post #119
Michael
Just beautiful work as always. Adriatic Blue? Very nice color indeed.
r_towle
post May 17 2014, 06:08 PM
Post #120
Custom Member
Your "lift" looks like a challenge to get a car up there...
- Lo-Fi Version Time is now: 24th November 2024 - 07:27 PM
