4 Pages V  1 2 3 > »
> recent Sebring Abuse, Oil system help
Jetsetsurfshop
post Dec 17 2013, 10:32 AM
Hey Everyone (IMG:style_emoticons/default/biggrin.gif)
Here's what I'm running
2258cc
10.5 to 1 compression
40 webers
494 web cam
type 1 oil pump
mocal oil cooler 25 row
mocal sandwich w/thermostat adapter
accusump 2 quart
Brad Penn Air-cooled oil 15-50 (5 1/2 quarts)
Let me explain my set-up
The oil cooler is a rear mount under the car on the passenger side rear. I made some duct work and its almost vertical to catch the most air as possible.
Track conditions
Sunny, low 80s, 30min sessions
question 1) With that cooler I didn't expect to run in the 230f oil temps. Is 230f acceptable?
question 2) I also have some oil on the top of the case /engine tin pooling. 1-2 side.
It only happens under WOT. Any ideas?
question 3) I never set-up an accusump and I don't like it so far.
It over fills the case at shut-off. Do I have to much air in it (9lbs)?
Other then my oil questions, I had a great time. Ran a 2:51. My new best time.
brant
post Dec 17 2013, 10:41 AM
you really need a front cooler to improve efficiency on the track
I know Chris at Tangerine and others have wonderful rear cooler systems that work... I'm not taking anything away from them
but frontal air is going to be more efficient
and I have always found front coolers to be more effective
(I did put a rear cooler into one car, and was never pleased with it's results)
regarding the accusump... I assume you have a shut off valve?
you have to contain the oil into the sump for shut off
without the valve the over-full condition blows valve cover gaskets
possibly the source of your oil pooling too.
brant
Jetsetsurfshop
post Dec 17 2013, 10:57 AM
I didn't like the idea of running the oil lines all the way up there in fear of the oil pressure falling off to much.
Also worried about creating lift with the bottom exit of air.
I'm I stressed about nothing?
The accusump is a mystery to me. (IMG:style_emoticons/default/WTF.gif) I pull in to the pits, car is at idle and I shut off the accusump. It seems to me that the oil viscosity is thinner at temperature and won't travel back up the pump? Once the oil temp has dropped to 160ish I can fill it back up. I just don't like all that oil sitting in the crankcase.
brant
post Dec 17 2013, 11:32 AM
Back when we ran an accusump. We used to close the valve on the cool down lap by reving the motor under load to redline. (Building the most oil pressure possible with a hot engine)
ThePaintedMan
post Dec 17 2013, 07:15 PM
Hey Shane,
I don't know much about Accusumps, but I have an idea about your oil pooling. Do you have head vents and a breather box? If so, check the connection from the hose at the head. FourBlades has vented heads and he popped one of the hoses off, spewing oil all over the place when we were at Sebring. Mostly at WOT though.
Jetsetsurfshop
post Dec 17 2013, 08:14 PM
QUOTE(brant @ Dec 17 2013, 09:32 AM) *
I was thinking the same thing. Kinda wish I didn't install it.
Thanks
Jetsetsurfshop
post Dec 17 2013, 08:15 PM
QUOTE(ThePaintedMan @ Dec 17 2013, 05:15 PM) *
Hey Shane,
I think its coming out of the dipstick (IMG:style_emoticons/default/WTF.gif)
brant
post Dec 17 2013, 09:29 PM
if you don't want to use it, just shut the valve and make sure the oil level in the motor is correct...
but these cars have a significant oiling problem in stock trim during cornering....
I installed a 2nd large oil pressure warning light on a 15lb pressure switch and could light it easily when I forgot to turn on the accusump.
you need some kind of additional oil modifications over stock for track work.
brant
Woody
post Dec 17 2013, 10:03 PM
Sandbox Rabblerouser and head toilet scrubber
Get rid of the head vents. Plug em off. Drill the chimney straight through and run it to a breather tank like this http://www.summitracing.com/parts/mor-85400/overview/
Pooling may be caused by a bad chimney gasket.
post Dec 17 2013, 11:09 PM
Resident German
QUOTE(Jetsetsurfshop @ Dec 17 2013, 08:57 AM) *
Does your class allow for a hood vent?
If so, create some extra downforce and vent out the hood ...
http://www.914world.com/bbs2/index.php?s=&...t&p=1898832
carr914
post Dec 18 2013, 05:48 AM
Racer from Birth
QUOTE(Jetsetsurfshop @ Dec 17 2013, 11:57 AM) *
When I had my 4 Cylinder Track car I Always ran the Accusump and had a Front Cooler, but my Temps were always High. I think it is because Sebring is such a Long Track & the RPMs are always High.
As Far as Routing the Air from the Front Cooler, you can run it out the Front Wheel Wells
carr914
post Dec 18 2013, 05:59 AM
Racer from Birth
Here's another Duct to Wheel Well
brant
post Dec 18 2013, 07:27 AM
The exit must be larger or less restrictive than the intake
I changed my front cooler exit twice on an old 914 race car. Each time I hanged to a less restrictive exit I dropped another 10-15 degrees of oil temp. This was with the same cooler on the same car and same motor.
The tubes to the wheel wells are to restrictive. Air won't flow through the cooler with that much resistance
nolift914
post Dec 18 2013, 02:22 PM
Autoxer
QUOTE(Jetsetsurfshop @ Dec 17 2013, 07:15 PM) *
Hey Shane,
Sounds like you have a FAT 2258 which is same setup that I have. I have 11 to 1 compression which caused positive pressure in the case resulting in the dipstick being pushed out and oil spraying from the tube. I use a rubber cap to close the tube when I am running. In addition I run a tangerine racing breather can.
ChrisFoley
post Dec 18 2013, 07:30 PM
I am Tangerine Racing
An accusump is an engine saver if its set up correctly.
It's important to shut the valve while the oil pressure is high so the accusump is fully charged.
The system should incorporate a check valve to force the accusump to feed the bearings and not the oil pump.
230F oil temp is ok if your pressure is good.
A front mounted cooler may be necessary if the temp goes any higher.
In that case use dash 12 lines to keep pressure loss to a minimum.
Jetsetsurfshop
post Dec 18 2013, 09:38 PM
QUOTE(SirAndy @ Dec 17 2013, 09:09 PM) *
I'm just doing DE's right now and I don't worry about class stuff to much. I enjoy engineering my car as much as running it. (IMG:style_emoticons/default/driving.gif)
A hood vent would be my first choice though.
Jetsetsurfshop
post Dec 18 2013, 09:47 PM
QUOTE(nolift914 @ Dec 18 2013, 12:22 PM) *
Hey Shane,
Sounds like you have a FAT 2258 which is same setup I have. I have 11 to 1 which caused positive pressure in the case resulting in the dipstick being pushed out any oil spraying from the tube. I use a rubber cap to close the tube when I am running. I addition run a tangerine racing breather can.
Have a tangerine breather can already, but I like your rubber cap idea. Ill try that at the next event. If theres still oil there it could be from the oil filler cap.
Seabird
post Dec 19 2013, 02:08 PM
QUOTE(brant @ Dec 17 2013, 07:29 PM) *
brant
A little bit of a highjack here, sorry. Brant when you say stock trim you mean without the tunacan/larger sump? Or am I to understand that a accusump is necessary equipment for track applications?
Miguel
nolift914
post Dec 19 2013, 02:47 PM
Autoxer
QUOTE(Jetsetsurfshop @ Dec 17 2013, 09:32 AM) *
2258cc
40 webers
494 web cam
type 1 oil pump
accusump 2 quart
Track conditions
What type fuel are you running with the 10.5 to 1 compression ? I have been running 110 leaded sunoco race gas but the location I have buying it from recently closed. The only race gas within 50miles of me is 100 unleaded.
post Dec 19 2013, 04:39 PM
Resident German
QUOTE(nolift914 @ Dec 19 2013, 12:47 PM) *
Pump gas, 91 octane. The twin plug setup helps with that ...
4 Pages V  1 2 3 > »
46 User(s) are reading this topic (46 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 9th January 2025 - 02:37 PM
