SMDs in the fog light housing, Final iteration using 90mm circles of SMD 5050 leds |
dangrouche |
Feb 2 2014, 05:30 PM
dangrouche Group: Members Posts: 550 Joined: 1-May 04 From: San Francisco Bay Area Member No.: 2,012 Region Association: None |
White 2x 90mm 24Led Bright SMD 5050 3Chip Car Led Angel Eyes Halo Ring Light AW5 that is the correct seller; but I was targeting the 5050 SMD; I believe they can be gotten from Amazon, for maybe two dollars more; the ones I have here cost $14 delivered from China. The ones you get from Amazon were probably also from China originally. I believe 100mm would fit in the fog lite lens as well. |
euro911 |
Feb 2 2014, 11:45 PM
Retired & living the dream. God help me if I wake up! Group: Members Posts: 8,860 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California |
I wonder what would happen if you mounted them on a ring with a large center opening and facing them towards the reflector?
Would they then emulate (pattern wise) stock fog lights with the incandescent lamps? |
dangrouche |
Feb 2 2014, 11:49 PM
great idea; give me a couple of weeks to do that one now that you've brought that up. I'll project it from the length of the garage and see if it lights up more. Update Feb 15, It works poorly. If anyone can find a LED SMD bulb that fits the bulb socket, I think this could give the illumination of a daytime running light.
dangrouche |
Feb 16 2014, 02:22 AM
that is correct and the same vendor where I got them |
Lo-Fi Version | Time is now: 30th December 2024 - 09:53 AM |
