HELP!! broke chopsticks in combustion chamber, anyone for chinese? |
IronHillRestorations |
Jan 3 2005, 08:35 PM
I. I. R. C. Group: Members Posts: 6,777 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
Yea...that's the ticket.... Don't know you DJsRepS, but you've got to be joking right? If not that's a contender for the bad advice of the year! You might break it in enough pieces to get it out the exhaust valve, and maybe not! You could bend a valve, break a piston, all kinds of BAD STUFF! Injection moulded plastic isn't very compressable. Are you trying to sell him an engine???? You made a mistake, don't make it worse. You either fish the thing out with a piece of tape on some stainless tie wire, or one of the other methods suggested here; or you drop the engine and take the head off. |
tracks914 |
Jan 3 2005, 09:12 PM
Canadian Member Group: Benefactors Posts: 2,083 Joined: 15-January 03 From: Timmins, Ontario, Canada Member No.: 153 Region Association: None |
(IMG:http://www.914world.com/bbs2/html/emoticons/laugh.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/laugh.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/laugh.gif) LOL LOL (IMG:http://www.914world.com/bbs2/html/emoticons/laugh.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/laugh.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/agree.gif) or better yet, guys that dismantle ships from a bottle. |
Series9 |
Jan 3 2005, 09:13 PM
I totally agree. If you start that engine, you're likely going to hurt it very badly. Either get the chop stick out or remove the head. |
Maltese Falcon |
Jan 3 2005, 09:27 PM
Advanced Member Group: Members Posts: 4,851 Joined: 14-September 04 From: Mulholland SoCal Member No.: 2,755 Region Association: None |
best / quickest solution is Tracks914. A cool tool would be sumtin like a colonoscopy probe, about 9mm in dia. w/ camera/ light and various attachments for grabbing !
Know any GI doctors (IMG:http://www.914world.com/bbs2/html/emoticons/headbang.gif) ? |
tracks914 |
Jan 3 2005, 09:33 PM
The doctors I know don't hang in the 914 crowd.
They're too rich for that, they drive new 911's. |
mharrison |
Jan 3 2005, 09:56 PM
Why do I bother???? Group: Members Posts: 633 Joined: 8-September 03 From: Madison, MS Member No.: 1,123 |
Maybe a gynecologist could get it !!!
Think about this. Get another chopstick, see if it floats in water. IF it floats, fill the cylinder with water....I know, I know, relax it's TEMPORARY...float the chopstick to the top, snag it and pull it out. Syphon the water out. Change the oil, run it, change the oil again. No harm done.... If you don't like the water, test other fluids that you would be more comfortable with and see if the chopstick floats.... Hey, if it doesn't work, you're planning to pull the head anyway..... |
newdeal2 |
Jan 3 2005, 10:12 PM
Unregistered |
Turn the car upside down and shake it!
Sorry, I couldn't resist. |
Carl |
Jan 3 2005, 10:32 PM
Ummm ... what? Group: Members Posts: 781 Joined: 17-January 03 From: San Jose, CA Member No.: 163 Region Association: Northern California |
Clever idea, Mike. I'm not familiar with TIV engines so can the valve spring on the uppermost valve in the cylinder be removed so that the valve can be (carefully) lowered further into the cylinder? With a larger opening, many of the other ideas mentioned here would be possible. Retrieval with a claw, float it out, vacuum it out, flypaper on a stick, etc. |
SGB |
Jan 3 2005, 10:46 PM
the engine is in the car, cylinder sideways.... The chopstick has to be down at the bottom. Could you bend a springy wire like a Y with the bottom bent 90 degrees, so you could reach the low side of the cylinder with the upper prongs of the Y hopefully on each side of the stick, then rotate the handle end so that the stick is brought up between the two prongs.... Could be that once it is flipped uo, pulling it back out will cause the stick to get pinched between the wires too.....
good luck, whatever you do. |
bryanthompson |
Jan 3 2005, 10:54 PM
Check it out... 3 loops! Group: Members Posts: 208 Joined: 23-April 04 From: elwood, ne Member No.: 1,970 |
I can't believe you haven't gotten it out yet! Are you *sure* it's actually in there? I remember one time I couldn't find my wallet and I wondered around the house for an hour looking… only to find out it was in my pocket the whole time. (IMG:http://www.914world.com/bbs2/html/emoticons/slap.gif)
bperry |
Jan 4 2005, 12:58 AM
Lurker Group: Members Posts: 477 Joined: 16-February 04 From: Dallas, Tx Member No.: 1,661 |
What about using compressed air pushed in from the exhaust?
Make sure the intake valve is closed, open the exhause valve then attach your air hose to the exhaust and increase pressure as needed until it blows out the spark plug hole. Sealing your air hose to the exhaust will be easier if you have header stub tubes. I'd think that a few quick blasts of air might just do the trick. --- bill |
Trekkor |
Jan 4 2005, 11:47 AM
It's pushing four days now. (IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif)
What did you do "O.G."? My guess is that you tore it down. ( not what I'd have done ) Please tell me you didn't. If you didn't,( please ) I'd say you found some way to vacuum it out of there. Give it up, we're waiting. (IMG:http://www.914world.com/bbs2/html/emoticons/poke.gif) KT |
scooter311 |
Jan 4 2005, 02:12 PM
Member Group: Members Posts: 231 Joined: 22-October 04 From: Upstate NY Member No.: 2,986 |
that poky-smiley made me laugh a chicken mcnugget out my nose. And I haven't eaten a mcnugget in, like 3 days
I wonder what happened also? I hope he was able to do it without an engine drop, but if he did, it would be the best time for cleaning things up while it was out (IMG:http://www.914world.com/bbs2/html/emoticons/sad.gif) |
rick 918-S |
Jan 4 2005, 05:50 PM
Hey nice rack! -Celette Group: Members Posts: 20,785 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
(IMG:http://www.914world.com/bbs2/html/emoticons/lol2.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/lol2.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/lol2.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/lol2.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/lol2.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/lol2.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/icon_bump.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/poke.gif) |
tracks914 |
Jan 4 2005, 06:32 PM
Me thinks he might have tried the "start the engine trick"....burned the engine and doesn't want to talk about it.
But I hope not (IMG:http://www.914world.com/bbs2/html/emoticons/headbang.gif) |
TheCabinetmaker |
Jan 4 2005, 07:04 PM
I drive my car everyday Group: Members Posts: 8,319 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
Doug, I hope you are wrong. That would suck!!!!!
d7n7master |
Jan 4 2005, 09:51 PM
Gary# Group: Members Posts: 663 Joined: 13-March 03 From: The O.C, Ca. Member No.: 421 |
I have a wood magnet right next to my left handed skyhook that I could let you borrow... or you could pull the head.
swood |
Jan 4 2005, 10:07 PM
Senior Member Group: Members Posts: 1,839 Joined: 6-February 03 From: Strong Beach Member No.: 251 Region Association: None |
Next to the gynocological method, I'd suggest the following. Similar to the filling the cylinder with water (why would anyone do that on purpose (IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif) ) put the motor on a turnable stand, fill the cylinder with oil which would suspend the piece of plastic, then turn the engine on the stand to pour it back out of the plug hole. This should work well if the piece is not jammed in between the p&c.
I've done alot of things that I would never post on this board for fear of major imbarrasment (ie - motor together with tin...hmmm wheres that cht under that hole in the tin...) (That was a freebie) |
mr_machines |
Jan 4 2005, 10:56 PM
Newbie Group: Members Posts: 2 Joined: 4-January 05 From: gainesville FL USA Member No.: 3,407 |
shop vac with home-made quarter-inch OD soft copper tubing as the 'suction nozzle'. easily bendable to 'fit the job', and get around obstacles, but stiff enough. you'll have to hold it in place in the 'suction end' of the bigger vac tube, to get it to act as a 'magnet' sort of....shop vac will ;-) need to be running :-) of course
now might be a good time to sell me your engine DIRT cheap, too, though :-) 'cause I need a 2.0...if that's what it is.... good luck (IMG:http://www.914world.com/bbs2/html/emoticons/givemebeer.gif) |
wheelo |
Jan 5 2005, 01:12 AM
Dude Group: Members Posts: 265 Joined: 19-March 04 From: San Rafael, Ca Member No.: 1,818 |
(IMG:http://www.914world.com/bbs2/html/emoticons/splat.gif)
Someone's too busy, doing tear-down, to give-up the final chapter! I have some "Bent" chopsticks, that bamboo is some tough-stuff, from doing the same exact "Trick".That's what you get for using plastic ones ! Mucho Brittle. (IMG:http://www.914world.com/bbs2/html/emoticons/cool_shades.gif) |
Lo-Fi Version | Time is now: 24th November 2024 - 05:04 PM |
