Best Distributor for Dual 44 IDF 2056 Engine |
'70PVW914 |
Jan 9 2014, 07:18 PM
Newbie Group: Members Posts: 29 Joined: 1-November 13 From: Boulder, Co Member No.: 16,594 Region Association: Rocky Mountains |
Hey folks.....Been poking around my 914 and will be replacing various parts over the weeks here.
For the distributor, which on mine is an old, pointless Allison model, I wanted to replace it with a Bosch and put in pertronics...then I found this "SVDA" thing on ebay...just wondering if its a good value, as it seems to be a brand new bosch, with the pertronics already installed. Good? http://www.ebay.com/itm/321275352048?ssPag...984.m1423.l2648 |
McMark |
Jan 9 2014, 10:36 PM
I use the mechanical advance Mallory (4554101).
Jonathan Livesay |
Jan 9 2014, 10:44 PM
Senior Member Group: Members Posts: 745 Joined: 13-March 10 From: La Canada CA Member No.: 11,461 Region Association: None |
Bosch 050 is very good with or without Pertronics I don't think that a 009 has enough advance for the Porsche version of the type4. There are probably some other newer ones that are made with more advance than the 009 but I don't know which ones are best.
finchmunoz |
Jan 9 2014, 11:23 PM
Newbie Group: Members Posts: 37 Joined: 3-July 11 From: Manila, Philippines Member No.: 13,272 Region Association: None |
Try CB performance black box:
http://www.cbperformance.com/ProductDetail...roductCode=2013 You may use any dizzy but it'll give you the qualities of a mechanical advance at the top end and svga advance at the low end. . . So at idle, you can set your timing to 0 deg. Cooler engine in traffic. |
Lo-Fi Version | Time is now: 26th December 2024 - 07:26 AM |
