Adjustable Temp Electric Fans, Need help finding a sensor--page 2 |
jimkelly |
Jan 30 2014, 07:17 AM
Delaware USA Group: Members Posts: 4,969 Joined: 5-August 04 From: Delaware, USA Member No.: 2,460 Region Association: MidAtlantic Region |
c1 and c2 represent sensors that when active create ground (relay pin 85)?
does relay 3 have battery hot at pin 30?? in bigkat's graphic. does the high speed and low speed work together or is one off when the other is on? |
76-914 |
Jan 30 2014, 09:06 AM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,662 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
Yes, c1 & c2 are grounds which when are controlled (in my case) by the ECU. They provide the ground at their respective relays. #30 pin on #3 relay is getting it's "hot" from fan #2. The fans run together at hi or low speed. Or, they are off. They do not run independent of one another.
jimkelly |
Jan 30 2014, 09:22 AM
back to graphic. |
computers4kids |
Feb 1 2014, 08:15 PM
Love these little cars! Group: Members Posts: 2,443 Joined: 11-June 05 From: Port Townsend, WA Member No.: 4,253 Region Association: None |
I went ahead and totally rewired my dual electric fan setup using three relays and BigKat's diagram.
The only thing left to do is purchase a thermo switch to screw into my rod simpson radiator where their is an extra port that is capped at the top of the radiator. I brought the plug with me to my FLAPS and they couldn't figure out which one (application) that would screw in...GEEZ! I thought that would be the easy part. Any ideas how to source a 200 degree sensor that is the right size for my radiator? Attached image(s) |
Mike Bellis |
Feb 1 2014, 09:32 PM
Resident Electrician Group: Members Posts: 8,347 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None |
Any ideas how to source a 200 degree sensor that is the right size for my radiator? http://www.summitracing.com/search/departm...size/3-8-18-npt Assuming is is a 3/8" NPT thread... (IMG:style_emoticons/default/smile.gif) |
Lo-Fi Version | Time is now: 28th January 2025 - 04:27 PM |
