16 Pages V « < 7 8 9 10 11 > »
> Mark's ADHD/ADD/DWD 3.0 /6 conversion thread, Woohoo! It runs awesome, but it's never done....
Mark Henry
post Mar 5 2014, 12:13 AM
Post #161
that's what I do!
Now you have to drill the hole to size, you use the drill bit included in the kit with just a hand tap handle. the Aluminium is soft so this goes easy.
I use a guide to keep the drill bit square with the port. You can buy this guide for $40..but you know...I'm cheap...so I made this one myself. (IMG:style_emoticons/default/rolleyes.gif) (IMG:style_emoticons/default/shades.gif)
Mark Henry
post Mar 5 2014, 12:17 AM
Post #162
that's what I do!
Then you use this tool to cut a countersunk relief for the head of the timesert. Again important that you bottom this tool out so that the relief cut is deep enough
Mark Henry
post Mar 5 2014, 12:20 AM
Post #163
that's what I do!
Then you tap the hole, try to keep the tap as square as possible.
The finished hole ready for the insert.
Mark Henry
post Mar 5 2014, 12:22 AM
Post #164
that's what I do!
Thread the oiled insert in as far as you can by hand.
Mark Henry
post Mar 5 2014, 12:26 AM
Post #165
that's what I do!
Then use the driver to drive in the insert.
Really important that the driver is well oiled. This is because the driver expands the insert as it drives it home.
Mark Henry
post Mar 5 2014, 12:30 AM
Post #166
that's what I do!
The finished repair, better than new. The other hole the threads are fine so I'll leave it alone.
That's one exhaust port, I have a few more of these to do tomorrow.
CptTripps
post Mar 5 2014, 03:54 AM
Post #167
:: Punch and Pie ::
Great work!
My dad and I had to do about 10 of those on my first car. (1985 Saab 900 Turbo) I got REAL good at those after the 3rd or 4th one.
Mark Henry
post Mar 6 2014, 08:44 AM
Post #168
that's what I do!
DING!
Balancing shop phoned! (IMG:style_emoticons/default/piratenanner.gif)
Road trip! (IMG:style_emoticons/default/driving.gif)
wobbletop
post Mar 6 2014, 10:32 AM
Post #169
I used a Timesert to fix a bolt that pulled the threads out of the block in my Subaru. Worked very well. Fairly easy to do and should prevent the steel-aluminum issue in the future (at least for that bolt).
/thread hi-jack
mrbubblehead
post Mar 6 2014, 08:05 PM
Post #170
Twodollardoug
i really like timeserts. i have most of the popular metric size kits. i dont know how i got along with out them.
r_towle
post Mar 6 2014, 08:10 PM
Post #171
Custom Member
Did you buy that tap handle?
Jeffs9146
post Mar 6 2014, 08:14 PM
Post #172
Ski Bum
QUOTE(r_towle @ Mar 6 2014, 06:10 PM) *
Old School! My dad left me a bunch of those when he died!
Mark Henry
post Mar 6 2014, 08:41 PM
Post #173
that's what I do!
QUOTE(r_towle @ Mar 6 2014, 09:10 PM) *
It didn't come with the kit, I bought it years ago.
r_towle
post Mar 6 2014, 08:54 PM
Post #174
Custom Member
My son made me mine..... (IMG:style_emoticons/default/aktion035.gif)
Mark Henry
post Mar 6 2014, 08:57 PM
Post #175
that's what I do!
I do make a lot of my own tools, but I didn't make that one. (IMG:style_emoticons/default/smile.gif)
You should see the tool I'm making right now...oh wait... if you follow this thread you will be seeing it soon (IMG:style_emoticons/default/biggrin.gif)
Mark Henry
post Mar 11 2014, 07:20 AM
Post #176
that's what I do!
I had to Time-Sert a few of my exhaust studs now for another stud repair, this time the case. The one bell-housing mounting stud hole had a very sketchy helicoil repair. They didn't even drill the stud right out, plus it was only helicoiled in about a half inch. This would possibly be "OK" as a dirty repair, but I have to hang this half out on the engine stand for the build....not cool. (IMG:style_emoticons/default/unsure.gif)
So I didn't want to buy another timesert kit, a regular Time-Sert wouldn't work anyways because it's been helicoiled, it would need a Big-Sert.
But I do have lots of 10mm VW case savers. These ones have an odd coarse standard outer thread and I didn't have a tap, so I got one from China, $10 delivered to my door.
This doesn't show the 3/4 hour spent yanking the helicoil, drilling out the rest of the old stud and tapping for the case saver but you get the idea....
Note the homemade insert driver. (IMG:style_emoticons/default/smile.gif)
I think this is a good solution and I'm confident hanging my build from it. (IMG:style_emoticons/default/shades.gif)
Mark Henry
post Mar 11 2014, 09:18 AM
Post #177
that's what I do!
Next job, a few of my piston oil squirters weren't up to snuff. Most of the time these are stuck shut and a bit of Seafoam or MEK will free them up. These were odd in that they wouldn't close.
The little freaking things cost $40 each.
I read some how to's and they dremal the peens, then drill and tap the squirter. Seemed like a waste of time.
A drill bit (A 1/4" is the same OD as the squirter) took off the peens then a bit smaller bit to open up the squirter. A couple came right out with the bit, one I jammed in a coarse screw and yanked out with a slide hammer. They all came out real easy.
bulitt
post Mar 11 2014, 10:05 AM
Post #178
Achtzylinder
Dr Evil time serted a speedo angle drive hold down at the clinic. I'm sold!
Mark Henry
post Mar 11 2014, 10:57 AM
Post #179
that's what I do!
This is the busness end of the squirter, it's just a ball bearing on a spring.
Mark Henry
post Mar 11 2014, 11:03 AM
Post #180
that's what I do!
If you have the old peening removed correctly the new squirter will just pop in. I used a bit of Loctite on the OD of the squirter only, you don't want to go crazy here because loctite in the squirter would likely be bad.
Then you have to peen the squirter in, I picked 3 new spots.
Another homemade tool. (IMG:style_emoticons/default/smile.gif) We need a bench grinder smiliey
And there you have it, relatively an easy job.
- Lo-Fi Version Time is now: 20th April 2025 - 12:45 AM
