mrbubblehead |
Twodollardoug ![]() ![]() ![]() Group: Members Posts: 1,155 Joined: 17-December 10 From: calimesa ca. Member No.: 12,492 Region Association: Southern California ![]() |
mark, i have been using aircraft stripper on engine cases and gearbox cases. mag and aluminum. works fast and does not harm or etch the metal. little expensive. but its just so easy its worth it. just brush it on with a cheap chip brush.
Mark Henry |
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada ![]() |
Been feeling like shit...figured as much but it looks like I'm passing a kidney stone...oh well, I'll keep trying to carry on with the projects.
Just a tad bitchy.... (IMG:style_emoticons/default/mad.gif) |
balljoint |
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,001 Joined: 6-April 04 Member No.: 1,897 Region Association: None ![]() |
Mark Henry |
Planning to visit you soon.... to pick up my new penguin.... (IMG:style_emoticons/default/smile.gif) |
Mark Henry |
dp
Attached image(s) ![]() ![]() |
Mark Henry |
Working a bit slow today, but stiff upper lip got some towers to get done.
Need to tap for the new plugs, not much different than doing a type 4 galley plug. You have to be careful not to distort the bearing bore, pipe plugs use a taper and you don't want the plug (or tap) to be jammed in too tight. You have to tap it deep enough so the plugs sits slightly below the surface. Do not use Teflon as it slippy enough to allow you to over torque the plug. Use something like loctite instead. I'm using a 1/8" NPT steel pipe plugs with a hex head. |
Mark Henry |
The plug and the fresh tapped hole.
This is how it must sit just below the surface when done. Attached image(s) ![]() ![]() |
Mark Henry |
While doing this it's a good time to chase the other threads.
Attached image(s) ![]() |
Mark Henry |
Now....you're asking yourself why the hell is he doing all this work? Just to make the cam towers look pretty??
This is why, look at these burrs in the holes of the spray bars! Maybe they won't come off...maybe they will...do you feel lucky? Attached image(s) ![]() ![]() ![]() ![]() |
Mark Henry |
So I've been using Dr Evils favorite cleaner LA Awesome and I found this little brushes at the dollar store. They worked great.
Attached thumbnail(s) ![]() Attached image(s) ![]() |
Mark Henry |
Guess what I'm making (IMG:style_emoticons/default/smile.gif)
Mark Henry |
First hint it's not finished...damn belt for my lathe broke (IMG:style_emoticons/default/sad.gif)
Yep it's leather. Attached image(s) ![]() |
PanelBilly |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,879 Joined: 23-July 06 From: Kent, Wa Member No.: 6,488 Region Association: Pacific Northwest ![]() ![]() |
HE for /6s?
Mark Henry |
HE for /6s? (IMG:style_emoticons/default/laugh.gif) Another hint other side of the head and what is that part sitting on? (IMG:style_emoticons/default/smile.gif) |
Mark Henry |
next..
Mark Henry |
bigkensteele |
Major Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,199 Joined: 30-August 04 From: Cincinnati, OH Member No.: 2,660 Region Association: South East States ![]() ![]() |
ITB adapters? |
gms |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,718 Joined: 12-March 04 From: Chicagoland Member No.: 1,785 Region Association: Upper MidWest ![]() ![]() |
Mark Henry |
Close.....custom phenolic spacers (IMG:style_emoticons/default/smile.gif)
The jig will be for finish cutting them on my router table. Center hole will be bigger, once I get a new belt on the lathe. |
Justinp71 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,629 Joined: 11-October 04 From: Sacramento, CA Member No.: 2,922 Region Association: None ![]() ![]() |
Nice thread! A carbed 3.0 is an awesome engine for a 914...
Have you given any thought to what you are using to seal the case? I used triple bond 1184, great stuff and it seals very well. Have a very good understanding as to how thick you want it and where you want it before starting. Also make sure your case has the chamfers on both sides for the thru bolt o-rings and dont use rtv on the o-rings like wayne calls out!!! I had to pull my case back apart from doing that one... good luck... |
Lo-Fi Version | Time is now: 20th April 2025 - 02:37 AM |
