CMXIV |
Newbie ![]() Group: Members Posts: 13 Joined: 21-July 12 From: Washington DC Member No.: 14,706 Region Association: MidAtlantic Region ![]() |
For tailshift, remove the seatpad and cointray between the seats and remove the coverplate (one sheetmetal screw) - the shift shaft adjustment is just under the cover. thanks michael. the adjustment screw is right where you said it was. i am one bushing away from a smooth shifting ride, for a tail shifter, of course. |
CMXIV |
Another possibility--an unpleasant one--is that the clutch tube has come loose inside the center tunnel, and the bottom of the shifter is hitting it before it can move over far enough to select the 4/5 plane. --DD that sounds quite unpleasant. it turns out the bushing just rear of the shifter it gone! it should be arriving at my house in a week. thank you pelican parts. |
CMXIV |
For tailshift, remove the seatpad and cointray between the seats and remove the coverplate (one sheetmetal screw) - the shift shaft adjustment is just under the cover. thanks michael. the adjustment screw is right where you said it was. i am one bushing away from a smooth shifting ride, for a tail shifter, of course. That adjustment bolt may be causing problems. the bolt that goes through the clamp is rubbing on the drivers side of the tunnel. although it is making it all pretty and shiny in there, this cant be good for anything. i think if i flip the bolt all will be well in there and the adjustment can proceed. |
914itis |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,892 Joined: 9-October 10 From: New York City Member No.: 12,256 Region Association: North East States ![]() |
The bad bushing may be the cause of the rubing.
CMXIV |
walterolin |
Senior Member ![]() ![]() ![]() Group: Members Posts: 685 Joined: 30-November 11 From: Louisville, Ky Member No.: 13,838 Region Association: South East States ![]() |
If you haven't installed the bushings before, you should be aware of a little trick to get them in. They are hard as a rock out of the package, but if you drop them into boiling water for a few minutes, they'll slide right in.
CMXIV |
CMXIV |
the bushing arrived so much faster than anticipated! it has been installed, the shifter rod adjusted, and 4th and 5th are back! I really want to thank all who responded and helped with this problem. without your volumes of knowledge, i don't that i could have gotten this done. thanks again, you awesome group wrenchers!
Lo-Fi Version | Time is now: 1st July 2024 - 06:41 AM |
