1.7L with carbs dizzy question |
rmital |
Mar 19 2014, 12:14 PM
Northeast optimist Group: Members Posts: 1,953 Joined: 12-December 05 From: Park Ridge, NJ Member No.: 5,268 |
got a rebuilt 1.7L I'm dropping in my runaround daily driver 914.
It will have 34icts delivering fuel. Currently has a 009 dizzy. Should I find an original distributor that went with the 1.7L??? or better dizzy suggestions??? (IMG:style_emoticons/default/confused24.gif) currently in the 914 in question, I have a 2.0L with the original FI dizzy and the 34icts. I had the 009, it didn't advance well. it was suggested on this site to utilize the original FI dizzy, and, believe it or not, the car runs fine with the FI dizzy. The problem is, once cylinder's compression is low and taking the engine out for a rebuild, hense replacing with the 1.7L while doing the work myself. FYI, I also have a '73 2.0L, all original. So the above situation will be for running around town, not worrying about mall parking lots, ball fields, etc. I'm enjoying real performance with my '73 2.0L |
jaxdream |
Mar 19 2014, 06:39 PM
Senior Member Group: Members Posts: 974 Joined: 8-July 08 From: North Central Tennessee Member No.: 9,270 Region Association: South East States |
Personaly I would try the oem 1.7 D-jet distributor. Advance is setup for that engine , 009 won't get you there. Also I would remove the Fuel Injection points from the bottom of the distributor ,put them up where you will remember where they are, no since running them with the carbs - wear & tear . The other option is the distributor from the 1.8 , suppose to be great with carbs. Please keep this thread updated , I have a brand new set of 34 ICTs in a box I got long ago for a VW T3 , just need to source the intake manifolds , iffen yours work out good.
Jack |
r3dplanet |
Mar 19 2014, 09:26 PM
Senior Member Group: Members Posts: 679 Joined: 3-September 05 From: Portland, Oregon Member No.: 4,741 Region Association: None |
The easiest thing to do is to get a distributor from a 1.8 liter. Those have a different advance curve more likeable to the carbs. Or you can spend some money and get a Mallory.
brant |
Mar 19 2014, 09:56 PM
914 Wizard Group: Members Posts: 11,831 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
050
rmital |
Mar 20 2014, 06:19 AM
.......Please keep this thread updated , I have a brand new set of 34 ICTs in a box I got long ago for a VW T3 , just need to source the intake manifolds , iffen yours work out good. Jack will do...going to Hershey in a few weeks for the swap. Hopefully find a 1.8L dizzy or an 050. anyone reading this and attending the Hershey meet that has a 1.8L dizzy or an 050 for sale, please PM me. Thanks..... (IMG:style_emoticons/default/flag.gif) |
rmital |
Mar 30 2014, 11:11 AM
I found an excellent 050 dizzy....good price.
again, this will be used with a 1.7L, 34icts, daily beater. not looking for racing performance, but do want "normal" behavior. don't want to as Jake mentioned in an earlier thread, "fry the heads and pistons with higher engine temps". what you say before I pull the trigger???? thanks, Ray (IMG:style_emoticons/default/flag.gif) |
Lo-Fi Version | Time is now: 14th January 2025 - 10:41 PM |
