Strange electrical problem |
914itis |
Mar 29 2014, 12:34 PM
With the ingnition off, when I move the wiper switch to the one position, my horn beeps. If I turn the ignition off, it stops. (IMG:style_emoticons/default/confused24.gif)
mintyish |
Mar 29 2014, 02:04 PM
Newbie Group: Members Posts: 8 Joined: 9-March 12 From: Auckland New Zealand Member No.: 14,235 Region Association: None |
With the ingnition off, when I move the wiper switch to the one position, my horn beeps. If I turn the ignition off, it stops. (IMG:style_emoticons/default/confused24.gif) It could be your steering column upper bearing breaking down - it's Nylon and falls apart with age and then allows the horn circuit to earth through the steering column. Try wiggling the wheel up and down and see if you have any free play in the upper bearing. You can get replacements and it's an easy fix... Good luck John |
Mar 29 2014, 02:45 PM
914-6 GT in waiting Group: Members Posts: 19,702 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Only drink German beer. Otherwise your car will be pissed off and honk at you
messix |
Mar 29 2014, 02:48 PM
AKA "CLUTCH KILLER"! Group: Members Posts: 6,995 Joined: 14-April 05 From: between shit kickers and pinky lifters/ puget sound wa.north of Seattle south of Canada Member No.: 3,931 Region Association: Pacific Northwest |
With the ingnition off [ok], when I move the wiper switch to the one position, my horn beeps. If I turn the ignition off [ I thought you said it was off already?], it stops. (IMG:style_emoticons/default/confused24.gif) this post doesn't make any sense. please read edit above |
Mar 29 2014, 03:02 PM
Resident German Group: Admin Posts: 41,972 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
With the ingnition off, when I move the wiper switch to the one position, my horn beeps. If I turn the ignition off, it stops. (IMG:style_emoticons/default/confused24.gif) Did you cross any wires from the horns and the parking lights? With the ignition off, the parking lights are operated with the turn signal lever ... (IMG:style_emoticons/default/idea.gif) |
914itis |
Mar 29 2014, 03:07 PM
With the ingnition off [ok], when I move the wiper switch to the one position, my horn beeps. If I turn the ignition off [ I thought you said it was off already?], it stops. (IMG:style_emoticons/default/confused24.gif) this post doesn't make any sense. please read edit above Correction, when I turn the ignition on., it stops. |
914itis |
Mar 29 2014, 03:12 PM
With the ingnition off, when I move the wiper switch to the one position, my horn beeps. If I turn the ignition off, it stops. (IMG:style_emoticons/default/confused24.gif) Did you cross any wires from the horns and the parking lights? With the ignition off, the parking lights are operated with the turn signal lever ... (IMG:style_emoticons/default/idea.gif) That's the first thing that came to mind but it's not the signal lever. I didn't do any electrical work. Just reinstalling my dash gauges . |
Lo-Fi Version | Time is now: 15th January 2025 - 01:00 AM |
