Kaeferfreund |
Member ![]() ![]() Group: Members Posts: 125 Joined: 28-July 13 From: Germany Member No.: 16,172 Region Association: Germany ![]() |
madmax914 |
Member ![]() ![]() Group: Members Posts: 204 Joined: 16-February 14 From: Salem, Oregon Member No.: 17,007 Region Association: Pacific Northwest ![]() |
Any updates Eric? Love this build!
Eric_Shea |
PMB Performance ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 19,299 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains ![]() ![]() |
I realized this hasn't been updated in a while so here's a batch of new pictures to keep you all entertained.
Matt has been busy making the engine look new. He finally got an edict from the goofy owner as to what he wants it to become. This 3.0 will remain CIS and get Euro HC pistons and Elgin Mod CIS cams. I think the FI will help with the multitude of elevation changes here on Planet Utah and should prove itself to be "set it and forget it" reliable. Others have reported stock 3.2 figures from this configuration. What we're looking for here is "torque": ![]() ![]() ![]() The transmission is getting ready for the 3.0 power with 108mm CV flanges to accommodate off road CV and axle combinations. ![]() The rear hubs are early 911 with longer studs and, again 108mm stub axles installed: ![]() ![]() ![]() As seen earlier in the thread, we're using our own PerformancePoly bushings (hardest durometer) to test their worthiness in the off road environment. These were again, glued into the mounts after being machined for the arm races. ![]() ![]() After a bit of welding, we were finally able to test mount the rear suspension. The factory ears were extended by 28mm by utilizing a good set of ears off a donor car. Chris Foley at Tangerine Racing made a custom pair of inner control arm mount stiffening plates that tied everything together. We then had a pair of custom 28mm spacers machined for the outside mount.: ![]() ![]() ![]() ![]() ![]() |
Eric_Shea |
Panels were fitted all around. We've chosen Dzus fasteners for easy access and, to allow for a quick change if we have a rock accident etc.
![]() ![]() ![]() ![]() Trunk Monkeys in place to emulate the weight of the motor in the chassis: ![]() ![]() ![]() |
Eric_Shea |
The front suspension was (obviously) fitted and checked for ride height:
![]() ![]() ![]() We also mocked up the location for the front light panel: ![]() ![]() Lovin' the roof rack! The spare fits perfectly: ![]() And... we spent a little time on the doors and getting the fiberglass skin put on them. The metal skin is just wrapped anound the frame and welded at the top and bottom so, grind off the edges, make a few cuts, test fit the skin, apply the adhesive and let it dry. We used every clamp in the house: ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() |
Eric_Shea |
As you can see from some of the above pictures, the cage is in. Chris Foley and the Tangerine crew to the rescue again. Tangerine makes one of the best roll cages in the business for a 914. Every piece was there and, it just fit.
![]() ![]() ![]() More welding was done in the form of motor mounts and a basic front to back approach to holes and any rust issues. ![]() We also made some holes and fitted the oil tank. We used a factory tank for fittment but, we'll be using one of Ben's new tanks for the updated oil filter and more capacity. We special ordered a custom 111mm hole punch for the filter console: ![]() ![]() ![]() The suspension is back off and the body is now on our body dolly. This means we're wrapping up the rough body work and it should go off for final prep and paint next! Starting to look more and more like a 914 every day! ![]() |
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 42,171 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California ![]() |
Mike Bellis |
Resident Electrician ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,347 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None ![]() ![]() ![]() |
This is an awesome build!
rhodyguy |
Chimp Sanctuary NW. Check it out. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 22,236 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch ![]() |
I think your recip saw blade is long enough.
Eric_Shea |
siverson |
Advanced Member ![]() ![]() ![]() ![]() Group: Benefactors Posts: 2,458 Joined: 5-May 03 From: San Diego, CA Member No.: 654 Region Association: Southern California ![]() ![]() ![]() |
Very cool!
Cory M |
Newbie ![]() Group: Members Posts: 19 Joined: 31-March 06 From: san diego Member No.: 5,798 ![]() |
Love this project. You should put some fender liners or foam in the wheel wells so the paint won't get thrashed from rock/debris impact.
restore2seater |
Future 914 copilot. ![]() ![]() Group: Members Posts: 312 Joined: 30-October 04 From: Dunlap,IL Member No.: 3,037 Region Association: None ![]() |
Hard to tell from the MIG flash, what type of engine mount is that being welded on?
pete000 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,886 Joined: 23-August 10 From: Bradenton Florida Member No.: 12,094 Region Association: South East States ![]() |
How much weight savings with the fiberglass door skins over stock doors?
Eric_Shea |
How much weight savings with the fiberglass door skins over stock doors? None because I opted to keep the guard rails in the late doors for the off road protection. (IMG:style_emoticons/default/biggrin.gif) We did a set for another car and it was "substantial". Mount is a Maddog copy of a Vellious mount from back in the day. I tend to like those mounts the best for six installs. |
Elliot Cannon |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Retired Members Posts: 8,487 Joined: 29-December 06 From: Paso Robles Ca. (Central coast) Member No.: 7,407 Region Association: None ![]() ![]() ![]() |
Not sure I like the idea of the Dzus fasteners. I mean, who does that really? (IMG:style_emoticons/default/confused24.gif) (IMG:style_emoticons/default/laugh.gif)
Krieger |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,799 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None ![]() ![]() |
Looks great Eric! It's very interesting to see how you raised the back end. Is that a cooler on top the tranny?
Sleepin |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,647 Joined: 20-November 07 From: Grand Junction, Co. Member No.: 8,357 Region Association: Rocky Mountains ![]() |
Looking for torque? No Rally Car is complete without a turbo.... (IMG:style_emoticons/default/wink.gif)
sixnotfour |
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,764 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains ![]() ![]() ![]() |
SubArooo
gms |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,717 Joined: 12-March 04 From: Chicagoland Member No.: 1,785 Region Association: Upper MidWest ![]() ![]() |
Making great progress!
Lo-Fi Version | Time is now: 3rd April 2025 - 01:12 AM |
