> brake bleeding
hndyhrr
post Mar 31 2014, 10:39 AM
Today we are going to bleed the brakes. Got any good advice. Just finished replacing struts back and front so had to pull it all off.
Thanks
type47
post Mar 31 2014, 10:45 AM
Viermeister
only the standard/obvious:
start with the caliper farthest from the master cylinder work toward closest.
I would suggest using a human to pump the brakes; some have trouble with power bleeders; Motive pressure not so much as Minivac suction
yeahmag
post Mar 31 2014, 03:56 PM
Best money I've spent was on a Motiv. I use it on all my cars/karts including the 914.
rgolia
post Mar 31 2014, 04:46 PM
GeoJoe
orthobiz
post Apr 2 2014, 07:41 PM
QUOTE(yeahmag @ Mar 31 2014, 05:56 PM) *
Does the Universal Kit have the proper screw cap for the 914? Or do you have to buy a separate adapter??
Paul
yeahmag
post Apr 2 2014, 09:27 PM
Buy the European one if I remember correctly.
McMark
post Apr 2 2014, 10:28 PM
914 Freak!
Install plugs in the master cylinder outlets and pump until bubbles stop coming up into the reservoir and the pedal is 100%, absolutely rock hard. Then add in the lines one at a time and rebleed.
ConeDodger
post Apr 3 2014, 01:53 PM
Apex killer!
QUOTE(McMark @ Apr 2 2014, 08:28 PM) *
(IMG:style_emoticons/default/agree.gif) And if you are going to use the Motiv (and I have one and do use it) always do the old fashioned two person method at least a couple rotations and give that pedal a good stomping! (IMG:style_emoticons/default/evilgrin.gif)
- Lo-Fi Version Time is now: 26th December 2024 - 09:36 PM
