Piston selection for stock rebuild w stock fuel Inj. |
tach |
Apr 2 2014, 05:56 PM
Member Group: Members Posts: 79 Joined: 6-November 09 From: Minnesota Member No.: 11,016 Region Association: Upper MidWest |
1974 1.8 914
I am rebuilding the stock engine with the stock 1.8 injection system. What piston and or piston cylinder kit be can used? It seems that most P/C kits require carbs. Thanks. |
yeahmag |
Apr 2 2014, 06:31 PM
Advanced Member Group: Members Posts: 2,443 Joined: 18-April 05 From: Pasadena, CA Member No.: 3,946 Region Association: Southern California |
Any reason not to take the current P/C set to the machinist and having them cleaned up, honed, and new rings? Unless they measure out of spec you can reuse them.
type47 |
Apr 2 2014, 06:54 PM
Black22 |
Apr 2 2014, 09:02 PM
Senior Member Group: Members Posts: 886 Joined: 1-November 07 From: Creswell, OR Member No.: 8,290 Region Association: Pacific Northwest |
Good torque in a 1911. Someday's I wish I had gone to a 2056, but then if I had, I would wish I had gone to a 6! Then I would wish my wallet wasn't empty, so I'm glad I went with a 1911 and Ljet. Keith Black 96mm pistons a matching cylinders. |
Cap'n Krusty |
Apr 2 2014, 09:04 PM
I may have a set of new 1.8 pistons and cylinders in the barn .........................
The Cap'n |
ConeDodger |
Apr 3 2014, 01:55 PM
Apex killer! Group: Members Posts: 23,856 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
Your most critical component choice is your cam not your pistons and cylinders...
Lo-Fi Version | Time is now: 30th December 2024 - 10:58 AM |
