Cracked piston skirt for a big bore kit: machine or replace? |
porkchopexpress |
Apr 2 2014, 06:12 PM
Newbie Group: Members Posts: 39 Joined: 18-August 12 From: Tucson, AZ Member No.: 14,821 Region Association: Southwest Region |
I recently picked up a 73 1.7 (was originally told it was a 1.8.... didn't think to check the engine stamp to verify. (IMG:style_emoticons/default/headbang.gif) but I got it for a song).
I also and looking at picking up a big bore kit (94mm by Kolbenschmidt) for trade. The original plan was they should bolt onto the 1.8 and be a pretty easy setup. With the 1.7, I understand I will need to have some head work done to accept the larger cylinders and pistons. Here is my dilemma: one of the pistons has a chipped skirt. The cause of the broken piece is unknown. I realize it MIGHT work to just use it as is, but as the person who is offering these in trade so rightly stated: " Emotional side of me says I don't like putting an engine together with something I know is not quite perfect" So I figure my options are to a) get all the piston skirts machined off to match b) inquire on the classified section if anyone has a single 94 mm Kolbenschmidt they would be willing to sell (hopefully cheap since its only one!) Anyone have input on the first option to machine off all the skirts to match? Thanks as always! (IMG:style_emoticons/default/beerchug.gif) |
Dr Evil |
Apr 2 2014, 06:15 PM
Send me your transmission! Group: Members Posts: 23,032 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region |
Toss it and get another.
Apr 2 2014, 06:17 PM
Custom Member Group: Members Posts: 24,646 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
A perfect situation where JB Weld might come in useful.
yeahmag |
Apr 2 2014, 06:33 PM
Advanced Member Group: Members Posts: 2,442 Joined: 18-April 05 From: Pasadena, CA Member No.: 3,946 Region Association: Southern California |
JB won't hold up in an environment like this. You need to user Crazy Glue or maybe Gorilla Glue if you have lot's of water in the oil (it's activated by water).
messix |
Apr 2 2014, 06:37 PM
AKA "CLUTCH KILLER"! Group: Members Posts: 6,995 Joined: 14-April 05 From: between shit kickers and pinky lifters/ puget sound wa.north of Seattle south of Canada Member No.: 3,931 Region Association: Pacific Northwest |
it's a paper weight!
the weight of the piston is now different to the others and will throw of the balance of the rotating assembly. that is the really big problem ! the other issues would be the stability of the piston would be off also and it would rock in the cylinder enough to gall the walls. if this guy thinks it would run ok with it.... I question the rest of the parts. |
stugray |
Apr 2 2014, 06:47 PM
Advanced Member Group: Members Posts: 3,825 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None |
I am pretty sure I have a set with one bad piston.
The wrist pin would not go in on just one. Let me check. |
VaccaRabite |
Apr 2 2014, 06:51 PM
En Garde! Group: Admin Posts: 13,593 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
Big bore is usually a 96mm piston (or larger), not a 94. Sure about the piston size? Or are you just getting stock 2.0 pistons and the seller is calling them "big bore."
Zach |
wndsnd |
Apr 2 2014, 07:14 PM
You wanted a horse, but got a goat. Nobody wants a goat.... Group: Members Posts: 2,861 Joined: 12-February 12 From: North Shore, MA Member No.: 14,124 Region Association: North East States |
Jake Raby |
Apr 2 2014, 07:21 PM
Engine Surgeon Group: Members Posts: 9,398 Joined: 31-August 03 From: Lost Member No.: 1,095 Region Association: South East States |
I thought this was an April fool's joke.. Seriously?
Johny Blackstain |
Apr 2 2014, 07:26 PM
Walnut Elite Stratocaster player Group: Members Posts: 3,434 Joined: 5-December 06 From: The Shenandoah River Member No.: 7,318 Region Association: MidAtlantic Region |
I'm gonna go out on limb here & be politically incorrect & say screw the paperweight, make it an ashtray.
Java2570 |
Apr 2 2014, 07:29 PM
Senior Member Group: Members Posts: 649 Joined: 7-May 11 From: Fishers, IN Member No.: 13,035 Region Association: Upper MidWest |
or a cupholder!
cary |
Apr 2 2014, 07:31 PM
wndsnd |
Apr 2 2014, 07:37 PM
timothy_nd28 |
Apr 2 2014, 08:26 PM
Maybe if I was stranded on a deserted island, I'd consider the glue (IMG:style_emoticons/default/blink.gif)
Allan |
Apr 2 2014, 08:41 PM
Butt plug... (IMG:style_emoticons/default/KMA.gif)
0396 |
Apr 2 2014, 09:14 PM
Advanced Member Group: Members Posts: 2,046 Joined: 13-October 03 From: L.A. Calif Member No.: 1,245 Region Association: Southern California |
A perfect situation where JB Weld might come in useful. Ya think? Why not just bench grind it flat and then do the other side? Reply to my own reply. It's called "blueprinting an engine". I read it in another thread.... Actually, it is blue printing...you will need to reduce the other three and keep it under 1500 rpm...oh just short shift. (IMG:style_emoticons/default/biggrin.gif) |
porkchopexpress |
Apr 2 2014, 10:09 PM
Seems as though most people didn't read the full post. My bottom line question was can I machine off all the slipper skirts so all the pistons match. If that wasn't clear, then that's on me and my bad. I have seen several new big bore kits that have pistons that do not have those slipper skirts so it seemed like a valid question.
Consensus seems to be, "bad idea" Additionally, I am doing all of this on a budget. Would love to have the cash to send an engine out to one of the guru's on here and have them do it for me, but for now, that's just not in the budget. And in case you didn't notice the "Newbie" designation, I still have a lot to learn. And I enjoy learning so its great to ask about these things to try to figure out what I can, or am willing, to do myself. I am all for being sarcastic, and can take and dish with anyone.... just wish some of you might have added something valuable to say along with it. Even if its "no clue" Next time I will be less likely to ask, which sucks. |
Mike Bellis |
Apr 2 2014, 10:22 PM
Resident Electrician Group: Members Posts: 8,346 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None |
Bad idea.
How many times do you want to rebuild it? Just install it like it is. It will make a cool slapping sound. People may even think it's a rod knock. But you'll know better, laughing all the way with your self machining pistons and bent crank... (IMG:style_emoticons/default/evilgrin.gif) |
Valy |
Apr 2 2014, 10:30 PM
Senior Member Group: Members Posts: 1,677 Joined: 6-April 10 From: Sunnyvale, CA Member No.: 11,573 Region Association: Northern California |
To your questions:
$200 will get you a new set of 94mm AA pistons, cylinders and rings. $230 for a new single piston and cylinder from Mahle (German). I think KS that you have are NLA. Either choice is better and cheaper than what you try to do. |
cary |
Apr 2 2014, 10:53 PM
Lo-Fi Version | Time is now: 2nd December 2024 - 02:10 PM |
