Type 4 |
Member ![]() ![]() Group: Members Posts: 412 Joined: 30-September 04 From: Costa Mesa Calif. Member No.: 2,866 ![]() |
These guy will rebuild your rear calipers for $110
Good guys fast turn around. www.goldlinebrakes.com |
Allan |
Teenerless Weenie ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,373 Joined: 5-July 04 From: Western Mesopotamia Member No.: 2,304 Region Association: Southern California ![]() |
I'm guessing that is each?
Eric_Shea |
PMB Performance ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 19,279 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains ![]() ![]() |
I'll do them for $95.00 plus cores and shipping. (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif)
* Dissassemble * Bead Blast * Yellow Zinc Plating * Hone Cylinders * New Piston and Adjuster Rebuild Kits * Reassemble Like new... |
Allan |
Hey Eric, can you do them in red?
Type 4 |
Eric that is a good price. I will send you a set.
Eric_Shea |
That is "each" and yes... I can do "Red".
Carlitos Way |
I did it MY WAY ![]() ![]() ![]() Group: Members Posts: 1,337 Joined: 14-September 04 From: Simi Valley, CA Member No.: 2,757 Region Association: Southern California ![]() |
I got a nice set from Eric... and his prices have gone down!!!
They work great. Thanks Eric |
Eric_Shea |
Thanks Carlos...
I think you're looking at the "per piece" price however. They're $190.00 for a pair "rebuilt". Yours were $100.00 a pair "as is". They were in great shape though. Glad they worked... (IMG:http://www.914world.com/bbs2/html/emoticons/smilie_pokal.gif) How'd everything work out for you?? M/C? Brakes? Lines? |
IronHillRestorations |
I. I. R. C. ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,734 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None ![]() ![]() |
That's a killer price! |
groot |
Dis member ![]() ![]() ![]() Group: Members Posts: 896 Joined: 17-December 03 From: Michigan Member No.: 1,444 ![]() |
Hey, Eric,
You may have a customer is me. A question for you first, though. Background: I moved my 914 front calipers to the rear, and used "M" calipers in the front... per the rules for E-production. All new plumbing with a Wilwood dual M/C setup. Under hard braking the right rear locks up first. My thought is that something's wrong with my caliper(s)..... or maybe my mounting. Any thoughts? I bought rebuild kits for all of the calipers, but I like the idea of replacing the pistons, too. |
Eric_Shea |
Kevin,
Based on what you mentioned (all new plumbing etc.) It sounds like a sticking piston. It happened to me the first time I rebuild the m-calipers on my -6. I'm not sure if you need a new piston but a cylinder hone and some 600grit on the pistons should be enough to make it like new. I used new rubber lines and rebuilt them again honing the cylinder etc. Problem solved. |
Britain Smith |
Nano Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,354 Joined: 27-February 03 From: Hillsboro, OR Member No.: 364 ![]() |
Hey Eric,
How hard would it be to rebuild calipers from an '87 Carrera? I would like to get mine powdercoated red and all the hardware plated, I don't think the rebuild kits are all that much. -Britain |
Eric_Shea |
Shouldn't be too difficult. Kits are around $25.00 each. Not sure about the powdercoating issue. Brakes can get very hot. I think there's specialty paints that actually might react better.
Carlitos Way |
Eric, They're working great. Only one "run" so far... for the Hangover Rally... but they kept me out of the cliffs and the mountain sides... even with Jay Leno's chin on my rear end... And yes, it was a great deal, and yes, I'm more than grateful for them. Carlos |
DJsRepS |
Member ![]() ![]() Group: Members Posts: 431 Joined: 4-November 04 From: Sarasota Florida Member No.: 3,060 ![]() |
Discount Auto Parts sold me one that leaked out the adj bolt. It has an Oring that was the wrong size and cut it in two when they forced it in the hole.
Lo-Fi Version | Time is now: 24th June 2024 - 05:48 AM |
