AE354803 |
Member ![]() ![]() Group: Members Posts: 232 Joined: 13-August 12 From: Southern California Member No.: 14,801 Region Association: Southern California ![]() |
When I pressed the clutch in to start my car (2000 subaru outback 2.5L w/ 5 speed) it went almost all the way to the floor but I was still able to shift (only about 1 inch of travel at the bottom of the pedal travel had any resistance even though the pedal returned fully). When it did have resistance the pedal felt normal and the resistance did not slowly build, it occurred suddenly. After about 30 shifts the problem fixed itself, so I checked when I got home. Fluid is at the Full mark and no obvious leaks.
Car has 210,000 miles and I think it's the original clutch so there is a decent amount of wear on everything. I replaced the MC to slave cylinder line a few years back because it sprung a leak. Only thing I can think of is the clutch MC seals are wearing out or there is some debris in there. Just seemed odd for it to fix itself, I'm guessing it will come back soon. Andy |
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,598 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States ![]() ![]() |
Sounds like a warning shot across the bow to let you know what is coming.
You can reverse bleed a clutch by using an old school oil can ( the hand pump type) and a hose. Fill up a new oil can with fluid, attach the hose to the oil can and the slave bleeder fitting. One the fitting, SLOWLY pump the oil can to push the fluid backwards into the tank.. Keep emptying the tank until the oil can is done....that pushes out the bubbles quite well, and it's simple. You never bleed a clutch by pumping it like brakes....not how that system functions. Sounds like you may need a master or slave, or both very soon. Rich |
Lo-Fi Version | Time is now: 26th June 2024 - 04:28 AM |
