Cam Gears, What to use? |
-JR- |
Jan 12 2005, 02:04 AM
Life goes faster at 150MPH Group: Members Posts: 276 Joined: 12-May 04 From: Victoria BC Canada Member No.: 2,055 |
All aftermarket cams or special grinds all seem to require a bolt on cam gear.
So I'm wondering what the difference is between the stock cam gear and the aftermarkets ones that are !NOT! a straight cut gears? I suppose the real root of this question is if I could grind off or dill out the rivets on a stock gear and bolt that gear onto an aftermarket cam. Thanks! -JR- |
Lo-Fi Version | Time is now: 22nd June 2024 - 09:47 PM |
