whoa.., steerinh/horn |
topdog |
Apr 19 2014, 06:43 AM
Newbie Group: Members Posts: 9 Joined: 7-December 13 From: salem, AR Member No.: 16,739 Region Association: None |
attempting to correct minor up/down movement of steering wheel. po replaced oem wheel with a momo. removed horn button and nut but wheel won't slide up and off. steering shaft looks to be misaligned with steering wheel splines just enough to bind it. i buttoned it back up until i could consult with you guys and now the slop is gone but when i turn the ignition switch on the horn blows. disconnected hot wire at horn and awaiting advice. thank you, thank you.
Lo-Fi Version | Time is now: 26th June 2024 - 06:42 AM |
