Braker 19., I mean Brakes on the 914 |
Teknon |
Jan 13 2005, 01:27 AM
The more I learn the dumber i think I am Group: Members Posts: 357 Joined: 10-August 04 From: Denver, Colorado Member No.: 2,505 Region Association: Rocky Mountains |
Ok the 914 brake master cylinder is 17mm. A nice upgrade is to the 19mm. I read somewhere (I'm looking for again) that the 23 mm mc can also fit and work. I saw a BMW M3 mc that looks exactly alike. Does that fit. And for what reason can't a mc from any car, so to speak, work.
(IMG:http://www.914world.com/bbs2/html/emoticons/burnout.gif) |
SpecialK |
Jan 13 2005, 01:35 AM
aircraft surgeon Group: Benefactors Posts: 3,211 Joined: 15-March 04 From: Pacific, MO Member No.: 1,797 |
From what I understand, you're not going to gain anything braking performance wise by upgrading the mc alone. You'll end up with less pedal travel, but it won't stop any better unless you upgrade the caliper's as well.
I've gone with a 19mm mc, 320i front brakes, and swapped out the stock prop. valve with a tee for the (stock) rears. I've heard as many good things as bad about this setup (after I already bought all of the parts (IMG:http://www.914world.com/bbs2/html/emoticons/mad.gif) ). I'll have to wait and see for myself. |
lapuwali |
Jan 13 2005, 02:00 AM
An MC with a different bore will change the "feel" of the brakes, but nothing else. All else equal, a smaller MC will give more pedal travel and less pedal force for the same amount of force at the caliper. A larger MC will give less pedal travel and require more force at the pedal. Some people like the harder pedal the 19mm MC gives, so some consider it an upgrade. A 23mm MC with the stock calipers will require you to push VERY hard on the pedal to get much braking force.
This is all relative to the caliper piston area, so if you fit calipers with larger pistons (or more smaller pistons, just so the total area adds up to more than you have now), then it's like fitting a smaller MC. You get more braking for a given pedal force, but you have to push the pedal farther to get it. |
Lo-Fi Version | Time is now: 24th September 2024 - 12:52 PM |
