DougC |
Senior Member ![]() ![]() ![]() Group: Members Posts: 949 Joined: 6-July 04 From: Dallas, TX Member No.: 2,307 ![]() |
OK so is it true that an engine, lets say a 350 that is bored .60 over will be harder to keep cool?
Doug C |
Mueller |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 17,146 Joined: 4-January 03 From: Antioch, CA Member No.: 87 Region Association: None ![]() ![]() |
yes.....in some cases you might weaken the wall enough for a failure...the blocks can be sonic tested for weak bores....
SLITS |
"This Utah shit is HARSH!" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None ![]() ![]() |
If you want to overbore that far, get an early 350 - 2 piece rear main seal with a block casting of 010.
Do not try to overbore the later (one piece rear seal) thinwall castings. |
Lo-Fi Version | Time is now: 23rd June 2024 - 02:15 PM |
