Mblizzard |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,033 Joined: 28-January 13 From: Knoxville Tn Member No.: 15,438 Region Association: South East States ![]() |
I am in.
kkid |
Member ![]() ![]() Group: Members Posts: 343 Joined: 18-December 07 From: Oakland, CA Member No.: 8,483 Region Association: Northern California ![]() |
I have a line on the OEM vinyl from Germany that's correct for our cars. The material that I'm currently using is pretty close, but not 100%. It is a domestic product that is of reasonable quality, but for the purists or those that don't want to pay $70+ from other sources, this is the stuff. I have to bring in a full roll, so it's a significant investment, but I think it's worth it. I'll get pictures up of the material on Friday. This will take about a month before I have material, but who wants it? I bought a set from you here on this site(not via 914rubber.com) last year. It's a stretchy material. I personally like this softer texture better than the stock material. Haven't installed them yet. Is this the one you're currently selling? Any tips on installing this one specifically? Thanks, kkid (IMG:style_emoticons/default/smile.gif) |
malcolm2 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,747 Joined: 31-May 11 From: Nashville Member No.: 13,139 Region Association: South East States ![]() ![]() |
Can we get a status on this GB? I didn't miss it, did I?
Mikey914 |
The rubber man ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,684 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None ![]() ![]() |
Can we get a status on this GB? I didn't miss it, did I? No it's on. Just took awhile to get the material from Germany. It just came in and we are processing. I will have the GB listed on the site soon and will drop PMs to all when these are ready. Should be about a day. |
Matt Romanowski |
Senior Member ![]() ![]() ![]() Group: Members Posts: 878 Joined: 4-January 04 From: Manchester, NH Member No.: 1,507 ![]() |
I'd like in on this too.
Mikey914 |
Good news the material is here. We've started processing it and will be able to ship starting Friday!
As usual I have made some improvements. The pieces are precision cut for an easier installation. We have cut kerfs at the rear section of the pieces, making them easier to stretch down where material normally bunches up more. The real kicker is we have put the holes in the material at the base so that the sail trim can easily be installed. If you are going commando on the trim, you can easily trim the bottom lip 1/8" and install. We do highly recommend using the trim as it helps to keep the edge down. You can find them here - http://www.shop.914rubber.com/914-Sail-Vin...-cut-914GSV.htm Attached thumbnail(s) ![]() |
Mikey914 |
Holes
Attached image(s) ![]() |
Mikey914 |
PMs sent to all that signed up.
Thanks, this will be open til June 1st http://www.shop.914rubber.com/914-Sail-Vin...-cut-914GSV.htm Thanks to all for your support! -Mark AKA Mikey914 |
Harpo |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,304 Joined: 21-August 11 From: Motor City aka Detroit Member No.: 13,469 Region Association: None ![]() |
I want a set, please add me to the list
Thanks David |
carr914 |
Racer from Birth ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 119,313 Joined: 2-February 04 From: Tampa,FL Member No.: 1,623 Region Association: South East States ![]() ![]() |
Yep, I need!
cantley914 |
Pipeline surgeon ![]() ![]() Group: Members Posts: 306 Joined: 15-June 04 From: Cantley, Qc Canada Member No.: 2,210 ![]() |
Count me in for one set also.
Steph |
Mike Bellis |
Resident Electrician ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,345 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None ![]() ![]() ![]() |
I just bought mine. Now I need to find some lower sail trim and clips.
If anyone has a set please PM me. |
Mikey914 |
Harpo |
Pelican has them listed for $31 but I don't believe that includes the clips
DAvid |
Mblizzard |
Got mine today! Looks exactly like the stock! Great job Mark.
ndfrigi |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,933 Joined: 21-August 11 From: Orange County Member No.: 13,474 Region Association: Southern California ![]() ![]() |
PMs sent to all that signed up. Thanks, this will be open til June 1st http://www.shop.914rubber.com/914-Sail-Vin...-cut-914GSV.htm Thanks to all for your support! -Mark AKA Mikey914 Sir Mark, I will take 1 set please! Noel (ndfrigi) |
wobbletop |
Member ![]() ![]() Group: Members Posts: 382 Joined: 8-December 06 From: Ontario, Canada Member No.: 7,335 Region Association: Canada ![]() |
I'd like a set. Do I just order from the website?
Mikey914 |
injunmort |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,024 Joined: 12-April 10 From: sugarloaf ny Member No.: 11,604 Region Association: North East States ![]() |
got mine yesterday, looks great thank you
maf914 |
Not a Guru! ![]() ![]() ![]() ![]() Group: Members Posts: 3,049 Joined: 30-April 03 From: Central Florida Member No.: 632 Region Association: None ![]() ![]() |
Mark, Looks like I missed this GB by a day, but if still available I'll take one set. Thanks as always.
Lo-Fi Version | Time is now: 25th June 2024 - 09:19 PM |
