2 Pages V < 1 2
> Replacement Fuel Pump - What do you do with Third Fuel Line?
913B
post Jun 21 2014, 09:31 PM
Post #21
QUOTE(JawjaPorsche @ May 18 2014, 05:30 PM) *
No need to move your pump to the front, just relocate to the firewall. I moved mine 15 years ago and never had a problem. The original location is just too damn hot for a fuel pump.
Chris at Tangerine Racing is great. Got my steel tunnel lines from him. Get new rubber grommets too for firewall. Here is link to video to install lines: https://www.youtube.com/watch?v=hxFRQTWLetw
There are two plastic fuel lines that go from fuel pump to engine bay that probably needs to be replaced too. Chris has those too. Replace fuel sock in tank too.
I had to get a fuel line adapter piece from Chris too.
Good Luck!
I am in this exact situation with a replacement bosch pump.Does that fuel filter in your picture solve the problem of the 1/2" inlet of the bosch pump. What is the dimensions of the in and out ports of the filter. Do you know the p/n by chance and where you purchase it.
Thank you
2 Pages V < 1 2
- Lo-Fi Version Time is now: 13th March 2025 - 03:57 AM
