Engine Bay Water Drain Hose? |
lsintampa |
May 22 2014, 03:37 PM
Senior Member Group: Members Posts: 520 Joined: 28-January 13 From: Tampa, FL Member No.: 15,441 Region Association: South East States |
I can't seem to locate any source for the water drain hoses (those in the engine bay on the left and right side - that attach to the funnels that collect water from the big water drip pan).
Assume they are NLA. Any aftermarket stuff or is it just old used stock? I guess I can do my own hose connections - local hardware store route, I just thought if they were around, it may be nice to add. One side is fine (pass), the driver side is busted up. Any sources for decent replacements? Thanks, Len |
bdstone914 |
May 22 2014, 03:44 PM
bdstone914 Group: Members Posts: 4,735 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
I can't seem to locate any source for the water drain hoses (those in the engine bay on the left and right side - that attach to the funnels that collect water from the big water drip pan). Assume they are NLA. Any aftermarket stuff or is it just old used stock? I guess I can do my own hose connections - local hardware store route, I just thought if they were around, it may be nice to add. One side is fine (pass), the driver side is busted up. Any sources for decent replacements? Thanks, Len If you go to the garden section of a local Lowes or Home Depot they carry irrigation tubing in 20 foot lenghts for $20. It is 1" id compared to the OE 25mm. Works great and the same tubing as the front blower box drains. Only visible difference is the ridges are a spiral and the original are rings. So the clamp goes over a ridge. |
Kansas 914 |
May 22 2014, 03:51 PM
I can't seem to locate any source for the water drain hoses (those in the engine bay on the left and right side - that attach to the funnels that collect water from the big water drip pan). Assume they are NLA. Any aftermarket stuff or is it just old used stock? I guess I can do my own hose connections - local hardware store route, I just thought if they were around, it may be nice to add. One side is fine (pass), the driver side is busted up. Any sources for decent replacements? Thanks, Len If you go to the garden section of a local Lowes or Home Depot they carry irrigation tubing in 20 foot lenghts for $20. It is 1" id compared to the OE 25mm. Works great and the same tubing as the front blower box drains. Only visible difference is the ridges are a spiral and the original are rings. So the clamp goes over a ridge. (IMG:style_emoticons/default/agree.gif) That is what I used. This is a picture (only one had) of the same hose up front. |
TheCabinetmaker |
May 22 2014, 04:20 PM
I drive my car everyday Group: Members Posts: 8,325 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
Bug haus carries the originals for the ghia. They are too short for the 914, but they are being made. I've talked to Eric about contacting the manufacture to make some for us but no luck yet. They don't think they could sell enough to make it worth their trouble. That doesn't make sense to me. Didn't they make more 914s than ghias?
bandjoey |
May 22 2014, 04:32 PM
bandjoey Group: Members Posts: 4,930 Joined: 26-September 07 From: Bedford Tx Member No.: 8,156 Region Association: Southwest Region |
Flexible washing machine drain hose works too. Hardware store is our friend!
zambezi |
May 22 2014, 04:35 PM
Senior Member Group: Members Posts: 711 Joined: 14-April 08 From: Lafayette, LA Member No.: 8,920 Region Association: South East States |
02loftsmoor |
May 22 2014, 05:11 PM
Senior Member Group: Members Posts: 577 Joined: 26-June 11 From: Ft. Worth TX Member No.: 13,243 Region Association: Southwest Region |
some out of the box thinking, thanks guys. one more thing that I don't have to fiddle with. I know Right were to go
lsintampa |
May 22 2014, 07:20 PM
Thanks,
Was at Home Depot today, no luck... will try Lowes / Ace tomorrow (IMG:style_emoticons/default/smile.gif) |
76-914 |
May 24 2014, 08:46 AM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,647 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
I couldn't find it at my Lowe's or Home Depot, either. Some handle it some don't. Order online if your area stores don't stock it.
lsintampa |
May 24 2014, 08:56 AM
I couldn't find it at my Lowe's or Home Depot, either. Some handle it some don't. Order online if your area stores don't stock it. Got it at Lowes.... thanks!!!! (IMG:style_emoticons/default/piratenanner.gif) |
Chris H. |
May 24 2014, 10:00 AM
Senior Member Group: Members Posts: 4,049 Joined: 2-January 03 From: Chicago 'burbs Member No.: 73 Region Association: Upper MidWest |
Didn't they make more 914s than ghias? I doubt it, they made the Ghias from 1956 to 1974. Of course not all years of the ghia used this type of airbox drain hose. OK you guys made me look on this one...and...there were more ghias. Wasn't sure which way it would go myself since they were known for being "hand made" for a while. If you just count the type 1's there were 438,477 Ghias recorded as being produced. Peak production was over 100 of those little guys a day assuming there was a 2 week break and weekends off. Ghia Production #'s |
maf914 |
May 24 2014, 04:20 PM
Good thread, because I too need these corrugated hoses for my rain tray. I had removed them and while cleaning them with a brush one simply broke. Aged brittle plastic I assume.
But it makes me wonder why VW/Porsche used corrugated tubing in the first place. Why not smooth tubing, which seems would drain faster and collect less debris? Was it for flexibility? (IMG:style_emoticons/default/idea.gif) |
bdstone914 |
May 24 2014, 04:48 PM
The ridges are only on the outside so they have no effect on flow. It dose make the tube stiffer so it will not easily deform.
cary |
Sep 21 2014, 05:52 PM
Just spent the better part of the afternoon looking for drain hose for our rain tray and fresh air blower. No go at Lowes, Ace, Home Depot, Morlan Plumbing or Fry's. Lowes had a black washer drain hose. But not uniform all the way down.
I know I found it 10 years ago. But both Lowes and Home Depot dropped that bulk line. (IMG:style_emoticons/default/sad.gif) So I came back home to the web and did some more digging. Here's what I found. http://www.thepondoutlet.com/home/tpo/page...ree_tubing.html So I'll head to garden center at Home Depot and dig around the pond building supplies. I'll follow Mike's install with the spring loaded washer clamps. Looks tidy. I'll let you know if it will stay on by itself. |
cary |
Sep 21 2014, 05:56 PM
More research ..............
http://www.homedepot.com/p/Beckett-1-in-Co...uct_description 20 feet .......... even tells what aisle its on. LOL. |
BeatNavy |
Sep 21 2014, 06:24 PM
Certified Professional Scapegoat Group: Members Posts: 2,944 Joined: 26-February 14 From: Easton, MD Member No.: 17,042 Region Association: MidAtlantic Region |
I was selling some of THIS a few weeks ago. I bought 20 feet and started selling the surplus in 16" pairs for $5 to $7 (primarily for shipping cost). It works like a champ both as fresh air tubing as well as for rain tubes. I may buy another 20 feet and cut it up for people here. Make sure whatever you get is 1 inch.
cary |
Sep 21 2014, 06:26 PM
Grabbed a tape measure before I left.
cary |
Sep 22 2014, 09:24 PM
Back from Home Depot.
20 feet. Clamps at McMasterCarr. http://www.mcmaster.com/#standard-hose-clamps/=tub3jq |
malcolm2 |
Sep 23 2014, 07:49 AM
Advanced Member Group: Members Posts: 2,747 Joined: 31-May 11 From: Nashville Member No.: 13,139 Region Association: South East States |
I bought the thicker stuff. It is difficult to work with, but might last an extra long time. IIRC I did not have to use the clamps on the engine lid cause the stuff is stiff. After I bought 20' and used 6 of it, I realized that it came in the vinyl style. I even had some for a rain barrel that I installed and accidentally bought 2 diverters. I consider myself a "closet" environmentalist. (IMG:style_emoticons/default/blink.gif) If I were to do it again, I would go with the thinner, rain barrel material vs. the thicker fish pond material. Just my 2 cents for future lookers. I have plenty of the stiff material if anyone is interested. |
lsintampa |
Sep 23 2014, 08:22 AM
I bought the thicker stuff. It is difficult to work with, but might last an extra long time. IIRC I did not have to use the clamps on the engine lid cause the stuff is stiff. After I bought 20' and used 6 of it, I realized that it came in the vinyl style. I even had some for a rain barrel that I installed and accidentally bought 2 diverters. I consider myself a "closet" environmentalist. (IMG:style_emoticons/default/blink.gif) If I were to do it again, I would go with the thinner, rain barrel material vs. the thicker fish pond material. Just my 2 cents for future lookers. I have plenty of the stiff material if anyone is interested. (IMG:style_emoticons/default/agree.gif) That fish pond stuff is way too rigid / thick - it is what I ended up with but working with it is a challenge. |
Lo-Fi Version | Time is now: 26th December 2024 - 03:42 PM |
