lapuwali |
Not another one! ![]() ![]() ![]() ![]() Group: Benefactors Posts: 4,526 Joined: 1-March 04 From: San Mateo, CA Member No.: 1,743 ![]() ![]() |
You're not going to get D-Jet to work with a 2270. You'll need to use aftermarket EFI, or stick with carbs. 96mm with the 2.0 stroke gives 2056cc, which is a mild bump over the stock 2.0 size, and aftermarket 96mm parts are cheaper than stock replacement parts, generally. I believe you can get a 2056 to work with D-Jet. |
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,598 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States ![]() ![]() |
If you are starting with a 2.0 liter and you have all (ALL) the fins on your current cylinders, get them honed out to 96mm and get new pistons.
You will want to rework the rods if you had slap to begin with, also check the rod clearance on the existing crank before you remove the rods. If you find to much play, you will need to take a really good look at the crank to ensure its a good base to build from. I have a friend that has a very strong 2.6 liter motor with cast iron cylinder...never had oil cooling other than stock, but now he does....it goes about 5-7k before a refresh... But, a properly cooled 2270 or larger have been built in europe for many years, lots of info across the pond and lots of experienced builders that have done it all, you name it they have built it. Rich |
Jake Raby |
Engine Surgeon ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,394 Joined: 31-August 03 From: Lost Member No.: 1,095 Region Association: South East States ![]() |
Actually, the TIV is falling off in Germany these days.
With the new laws and etc in the fatherland many tuners that were once on top of the world have fallen off or went out of business. Even in their day the Germans didn't do alot with small bores. They were into short stroke large bore engines with super long duration cams and hardly any lift. This was great for high speeds on the Autobahn but wasn't very good for acceleration... The 2270 may have been done in a multitude of locations, but it was perfected right here under my roof- Thats a guarantee. I have 107 different proven combinations of 2270 and have used that base for more R&D than anything else combined. |
Bleyseng |
Aircooled Baby! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,035 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest ![]() |
Djet works just fine with a 2056cc, atleast mine has for 5 years. I have dyno'd it at 95hp at the rear wheels. Geoff |
newdeal2 |
Unregistered ![]() |
Jake, This sounds promising. After sucessfully building a semi stock 2.0 I think I am ready to consider building one of your 2270 kits. When will the details and pricing be available? Will you be providing cores? |
Jake Raby |
Patience Jedi..
It all will be self explanatory very soon! The custom aspect of the kits is gone forever, but they will still be 100% dynamically balanced like always and will have all machine and clearance work done for you I still have not made my mind up on doing case machine work, but I am leaning towards doing it for an added charge only on the 2270 and larger kits, or simply providing very detailed instructions and tools to do it all yourself. Case work really bogs my machines down. |
Lo-Fi Version | Time is now: 25th June 2024 - 11:40 PM |
